ESP-OTA setup esp_ota_ops.h: No such file or directory
djoshi
Postby djoshi » Mon Mar 14, 2022 4:26 pm
Hi All
I am trying to run the following code to update the ESP32
void update_fwm(void)
        .url = "https://abc.com/ESP32/Device1/fmw.bin",
        //.cert_pem = (char *)server_cert_pem_start,
    esp_err_t ret = esp_https_ota(&config);
    if (ret == ESP_OK) {
        esp_restart();
    } else {
        return ESP_FAIL;
    return ESP_OK;
When I perform a build
I get the following
../main/azure_iot_freertos_esp32_main.c:23:11: fatal error: esp_ota_ops.h: No such file or directory
  #include "esp_https_ota.h"
From my understanding, all the header files are dealt with by the compiler. Is there a reason why it's giving be this error? Do i need to add this file some specify it.
SHouldent this be all in ESP32 folder?
mschultz
Re: ESP-OTA setup esp_ota_ops.h: No such file or directory
Postby mschultz » Mon Mar 14, 2022 11:32 pm
Not sure I can help you, aside from saying that at least for the ESP-IDF master branch (5.0) the header file you're looking for is in
esp_idf_dir/components/esp_https_ota/include/esp_https_ota.h
If I add a
in one of my ESP projects, the compiler finds and includes it just fine.
Users browsing this forum: Google [Bot], Qwantbot, Semrush [Bot] and 2 guests
