Dear,
In the documentation its written that if flash encryption is enabled the binary after encryption is stored to the IRAM. I couldn't find further details if the whole binary is stored or this is performed somehow partially. Therefore, I would ask if the encryption is enabled the binary size is limited to the IRAM size?
Thank you
Flash encryption size limitation
Re: Flash encryption size limitation
I found this here https://docs.espressif.com/projects/esp ... ption.html
The device is then rebooted to start executing the encrypted image. The firmware bootloader calls the flash decryption block to decrypt the flash contents and then loads the decrypted contents into IRAM.
Ok I see how it is potentially confusing but the cache also works with flash encryption so there is no additional restriction.
Thank you for the answer. I would just ask if the encryption somehow influences on the execution of the program while running or the speed remains the same?
krzywy1607
Up. I have the same question.Thank you for the answer. I would just ask if the encryption somehow influences on the execution of the program while running or the speed remains the same?
Until now we have not experienced any difference and we run a lot of peripherals and wifi.Up. I have the same question.Thank you for the answer. I would just ask if the encryption somehow influences on the execution of the program while running or the speed remains the same?
Users browsing this forum: Bytespider, ChatGPT-User and 1 guest
