I have a esp32-wrover-ie and I am a little bit confused about the voltage of param and flash. From the docs I read "Internal pull-up resistor (R9) for MTDI is not populated in the module, as the flash and SRAM in the module only support a power voltage of 3.3 V (output by VDD_SDIO)." (https://www.espressif.com/sites/default ... eet_en.pdf page 7)
When I look into the Efuse I get:
XPD_SDIO_FORCE (BLOCK0): Ignore MTDI pin (GPIO12) for VDD_SDIO on reset = False R/W (0b0)
XPD_SDIO_REG (BLOCK0): If XPD_SDIO_FORCE, enable VDD_SDIO reg on reset = False R/W (0b0)
XPD_SDIO_TIEH (BLOCK0): If XPD_SDIO_FORCE & XPD_SDIO_REG = 1.8V R/W (0b0)
(Background information: I want to use gpio12 as normal gpio. So why not burn the VDD_SDIO to fixed voltage? It will never change anyway...)
One more question out of curiosity: When I flash the firmware I can see that the module version is V3. In the Efuse setup the silicon revision is 2. Is this right? Or do I have a fake module?
Best,
Jonathan
