Problem with volume control using MAX98357A and I2S on an ESP32
billys7
Postby billys7 » Tue Feb 22, 2022 4:31 pm
I use the following code to reproduce an audio file with ESP32 --> I2S --> MAX98357A with success.
I want to add a software volume, so i add the code in comments. When i uncomment this part of the code the result is very noisy.
Do you have any suggestions ?
Code: Untitled.cpp Select all
#include "driver/i2s.h"
#include "freertos/queue.h"
#include <pgmspace.h>
#include "soundsample.h"
uint16_t readData1, readData2;
uint32_t readData, counter;
//i2s configuration
const int i2s_num = 0;
i2s_config_t i2s_config = {
.mode = (i2s_mode_t)(I2S_MODE_MASTER | I2S_MODE_TX),
.sample_rate = 16000,
.bits_per_sample = I2S_BITS_PER_SAMPLE_16BIT,
.channel_format = I2S_CHANNEL_FMT_ONLY_LEFT,
.communication_format = (i2s_comm_format_t)(I2S_COMM_FORMAT_STAND_I2S),
.intr_alloc_flags = ESP_INTR_FLAG_LEVEL1,
.dma_buf_count = 8,
.dma_buf_len = 1024,
.use_apll = 0,
.tx_desc_auto_clear = true
i2s_pin_config_t pin_config = {
.bck_io_num = 26, //this is BCK pin
.ws_io_num = 25, // this is LRCK pin
.data_out_num = 22, // this is DATA output pin
.data_in_num = I2S_PIN_NO_CHANGE
// .data_in_num = -1 //Not used
int i2s_write_sample_nb(uint32_t sample)
size_t bytes_written;
i2s_write((i2s_port_t)i2s_num, (const char*)&sample, sizeof(uint32_t), &bytes_written, 100);
return bytes_written;
//Main function to play samples from PROGMEM
void playPROGMEMsample(const uint32_t* audioSample)
i2s_driver_install((i2s_port_t)i2s_num, &i2s_config, 0, NULL); //initialize i2s with configurations above
i2s_set_pin((i2s_port_t)i2s_num, &pin_config); //initialize i2s with configurations above
i2s_set_sample_rates((i2s_port_t)i2s_num, 16000); //set sample rates of i2s to sample rate of wav file
while (audioSample)
readData = pgm_read_dword(&audioSample[counter++]);
readData = ((readData>>24)&0xff) | // move byte 3 to byte 0 // Convert big endian to little endian in C
((readData<<8)&0xff0000) | // move byte 1 to byte 2
((readData>>8)&0xff00) | // move byte 2 to byte 1
((readData<<24)&0xff000000); // byte 0 to byte 3
/* Code for volume test
readData1 = uint16_t(readData>>16);
readData1 = readData1 /3;
readData2 = uint16_t(readData);
readData2 = readData2 /3;
readData = uint32_t (readData1 << 16)+ readData2;
i2s_write_sample_nb(readData);
if(counter > 125252) break;
counter = 0;
readData = 0;
i2s_driver_uninstall((i2s_port_t)i2s_num); //stop & destroy i2s driver
void setup()
Serial.begin(115200);
Serial.println("Serial connection OK");
playPROGMEMsample(sample1);
Serial.println("End");
void loop()
soundsample.h
(1.43 MiB) Downloaded 299 times
imanpakii
Re: Problem with volume control using MAX98357A and I2S on an ESP32
Postby imanpakii » Thu Mar 17, 2022 2:41 pm
Did you Fix the problem?
I'm using driver/i2s.h and I would like to change the sound volume also.
Please give me your solution if you have it.
Thank you
Iman
billys7
Postby billys7 » Tue Mar 22, 2022 10:45 pm
I have no solution yet. I think that i must include the i2s_write function in an interrupt - task, so i can use it, only when the buffer will be empty. I read in this forum that i can trigger an event when the buffer is empty but i couldn't understand it. i want to learn more about the function :
"i2s_driver_install(I2S_NUM_0, &i2s_config, 0, NULL);"
i2s_num I2S device number
i2s_config I2S configurations - see i2s_config_t struct
queue_size I2S event queue size/depth. (what does that mean ? How can i know the value ?)
i2s_queue I2S event queue handle, if set NULL, driver will not use an event queue. (When the event will happend ?)
and especially about the last 2 parameters, and the way that i will do the interrupt - task.
Also, in the technical reference, i found the I2S_TX_REMPTY_INT interrupt. It is triggered when the transmit FIFO is empty. I think that this is what i am looking for, but i don't know how can i trigger it.
Unfortunately it is very difficult to find a guide, and the infos are limited.
Users browsing this forum: Baidu [Spider], ChatGPT-User, Google [Bot] and 1 guest
