vPortCPUAcquireMutexIntsDisabledInternal error
wxy1999
Postby wxy1999 » Fri Apr 22, 2022 5:41 am
I use ESP32 to develop smart furniture system. After the program runs, the system will wake up and issue voice commands, which will cause system crash and vPortCPUAcquireMutexIntsDisabledInternal error, as shown in the detailed log below
assertion "res == coreID || res == portMUX_FREE_VAL" failed: file "/home/shao/WS/Project2_2/esp/esp-adf/esp-idf/components/freertos/portmux_impl.inc.h", line 105, function: vPortCPUAcquireMutexIntsDisabledInternal
abort() was called at PC 0x400d7d63 on core 1
Backtrace: 0x4008e14b:0x3fff2510 0x4008e47d:0x3fff2530 0x400d7d63:0x3fff2550 0x4008b7f9:0x3fff2580 0x4008a740:0x3fff25b0 0x401c9fad:0x3fff25d0
Rebooting...
ets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x1f (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:5576
load:0x40078000,len:9484
load:0x40080400,len:6996
entry 0x40080744
I (29) boot: ESP-IDF v3.2-103-g4aa1058e8 2nd stage bootloader
I (29) boot: compile time 11:49:40
I (29) boot: Enabling RNG early entropy source...
I (32) qio_mode: Enabling default flash chip QIO
I (36) boot: SPI Speed : 40MHz
I (39) boot: SPI Mode : QIO
I (42) boot: SPI Flash Size : 8MB
I (45) boot: Partition Table:
I (48) boot: ## Label Usage Type ST Offset Length
I (54) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (61) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (67) boot: 2 factory factory app 00 00 00010000 00400000
I (74) boot: 3 secadb Unknown data 01 82 00410000 00100000
I (80) boot: 4 unsecadb Unknown data 01 82 00510000 001f0000
I (87) boot: 5 user Unknown data 01 82 00700000 000f0000
I (94) boot: End of partition table
I (97) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x1999a4 (1677732) map
I (597) esp_image: segment 1: paddr=0x001a99cc vaddr=0x3ffb0000 size=0x03d8c ( 15756) load
I (602) esp_image: segment 2: paddr=0x001ad760 vaddr=0x40080000 size=0x00400 ( 1024) load
I (603) esp_image: segment 3: paddr=0x001adb68 vaddr=0x40080400 size=0x024a8 ( 9384) load
I (613) esp_image: segment 4: paddr=0x001b0018 vaddr=0x400d0018 size=0x16c7c4 (1492932) map
I (1056) esp_image: segment 5: paddr=0x0031c7e4 vaddr=0x400828a8 size=0x15238 ( 86584) load
I (1099) boot: Loaded app from partition at offset 0x10000
I (1100) boot: Disabling RNG early entropy source...
E (143) sdmmc_common: sdmmc_init_ocr: send_op_cond (1) returned 0x107
E (143) SDCARD: Failed to initialize the card (ESP_ERR_TIMEOUT). Make sure SD card lines have pull-up resistors in place.
Connect to stored Wi-Fi SSID:Josh PWD:12345678
W (231) JOSHVM_Audio: Before javatask,free heap size = 118720
W (355) WIFI_SERV: Disconnect reason 1.
Reason code: 0:STA_UNKNOWN,1:AUTH_ERROR,2:AP_NOT_FOUND,3:BY_USER
Serial port 0 open successfully
javacall_set_property: key=org.joshvm.ams.appdbpath.root, value=internal/, type=0, replace=1
========CommAppManager.connect
[Device synchronized. Protocol version is 1]
PERIPH_WIFI_CONNECTED [185]
========CommAppManager.disconnect: stop=false
========CommAppManager.disconnect: stop=true
Re: vPortCPUAcquireMutexIntsDisabledInternal error
Postby Sprite » Fri Apr 22, 2022 6:25 am
Okay, what is your question? (Also, whatever it is, it probably helps if you decode that backtrace.)
wxy1999
Postby wxy1999 » Fri Apr 22, 2022 10:07 am
In the use of the development board to develop intelligent furniture , sub the tx and rx to send and receive information, the program runs normally. HC-05 Bluetooth module used, system is easy to cause vPortCPUAcquireMutexIntsDisabledInternal errors after users speak an awakening sound,, And then issued voice control command, the program did not respond.
Postby Sprite » Sun Apr 24, 2022 3:10 am
Note that you're still not asking a question, you're telling us what you did but not what you want from us, what the reason is that you're posting this issue. I'm gonna go on a limb and assume you want help solving whatever causes this vPortCPUAcquireMutexIntsDisabledInternal error, is that correct?
If so, it would really help if we could see your code and that decoded backtrace I mentioned earlier. As that error says, the issue is that something is trying to acquire a mutex while interrupts are disabled (something which typically happens in an interrupt handler), so I'd imagine that you're doing something in an interrupt handler that you should not do. But lacking source code or a decoded backtrace, that's about as much as we can say here.
Users browsing this forum: Semrush [Bot] and 5 guests
