ESP32 DEVKITV1, pins 36 (HALL VP) and 39 (HALL VN)
Dremkin
Postby Dremkin » Mon Jun 13, 2022 6:30 pm
I'm trying to use these two contacts for simple input. Pull-up resistor 1k. As a result, it turns out that these two contacts are interconnected - if pin 36 is connected to ground, then pin 39 is also connected to ground..
Can these pins be used as two separate inputs?
Code: Untitled.c Select all
int pinTest1 = 36;
int pinTest2 = 39;
void setup() {
Serial.begin(9600);
pinMode(pinTest1, INPUT_PULLUP);
pinMode(pinTest2, INPUT_PULLUP);
byte lastState1 = 0;
byte lastState2 = 0;
void loop() {
byte statePin1 = digitalRead(pinTest1);
if(lastState1 != statePin1){
Serial.print(" Pin "); Serial.print(pinTest1); Serial.print(" = "); Serial.println(statePin1);
if(statePin1 == HIGH) Serial.println();
lastState1 = statePin1;
byte statePin2 = digitalRead(pinTest2);
if(lastState2 != statePin2){
Serial.print(" Pin "); Serial.print(pinTest2); Serial.print(" = "); Serial.println(statePin2);
if(statePin2 == HIGH) Serial.println();
lastState2 = statePin2;
Users browsing this forum: Applebot, Google [Bot], PerplexityBot and 4 guests
