ESP32-C3 (External Flash)
ThunderGod
Postby ThunderGod » Fri Jun 24, 2022 11:24 pm
Hello there,
I have recently designed and made my first test board around the ESP32-C3 SoC - which is a SoC that has no embedded Flash memory.
For the external memory I have chosen to use ZB25D40BTIG - 4M Nor Flash Memory, an equivalent to the GD25Q40C from GigaDevice which seems to be on the list of supported Vendors.
All attempts to flash an arbitrary ESP-IDF example yield the same result:
A fatal error occurred: Packet content transfer stopped (received 8 bytes)
The SPI interface between the SoC & Flash is most likely fine, so is there something that I should do in the "menuconfig" to get flashing to work?
PS. If you don't want to bother answering in detail, feel free to post a link to any resource that may be of help.
Thanks!
Re: ESP32-C3 (External Flash)
Postby Sprite » Fri Jun 24, 2022 11:46 pm
Can you post the entire output of what esptool says? Also, you're using an ESP32C3 without built-in flash, right?
ThunderGod
Postby ThunderGod » Sat Jun 25, 2022 12:05 am
Yes, I'm using the ESP32-C3 SoC without any embedded Flash.
jocic@jocic-VivoBook-15-ASUS-Laptop-X540MA-A543MA:~/blink-test$ idf.py -p /dev/ttyUSB0 flash
Executing action: flash
Running ninja in directory /home/jocic/blink-test/build
Executing "ninja flash"...
[1/5] cd /home/jocic/blink-test/build/.../home/jocic/blink-test/build/blink.bin
blink.bin binary size 0x28fb0 bytes. Smallest app partition is 0x100000 bytes. 0xd7050 bytes (84%) free.
[2/5] Performing build step for 'bootloader'
[1/1] cd /home/jocic/blink-test/build/bootloader/esp-idf/esptool_py && /home/jocic/.espressif/python_env/idf4.4_py3.8_env/bin/python /home/jocic/.esp/esp-idf-v4.4/components/partition_table/check_sizes.py --offset 0x8000 bootloader 0x0 /home/jocic/blink-test/build/bootloader/bootloader.bin
Bootloader binary size 0x4d80 bytes. 0x3280 bytes (39%) free.
[2/3] cd /home/jocic/.esp/esp-idf-v4.4...nents/esptool_py/run_serial_tool.cmake
esptool.py esp32c3 -p /dev/ttyUSB0 -b 460800 --before=default_reset --after=hard_reset write_flash --flash_mode dio --flash_freq 80m --flash_size 2MB 0x0 bootloader/bootloader.bin 0x10000 blink.bin 0x8000 partition_table/partition-table.bin
esptool.py v3.2-dev
Serial port /dev/ttyUSB0
Connecting...
Chip is ESP32-C3 (revision 3)
Features: Wi-Fi
Crystal is 40MHz
MAC: 7c:df:a1:b4:c7:c0
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
Configuring flash size...
Flash will be erased from 0x00000000 to 0x00004fff...
Flash will be erased from 0x00010000 to 0x00038fff...
Compressed 19840 bytes to 11999...
CMake Error at run_serial_tool.cmake:56 (message):
  /home/jocic/.esp/esp-idf-v4.4/components/esptool_py/esptool/esptool.py
  --chip esp32c3 failed
FAILED: CMakeFiles/flash
cd /home/jocic/.esp/esp-idf-v4.4/components/esptool_py && /usr/bin/cmake -D IDF_PATH="/home/jocic/.esp/esp-idf-v4.4" -D SERIAL_TOOL="/home/jocic/.espressif/python_env/idf4.4_py3.8_env/bin/python /home/jocic/.esp/esp-idf-v4.4/components/esptool_py/esptool/esptool.py --chip esp32c3" -D SERIAL_TOOL_ARGS="--before=default_reset --after=hard_reset write_flash @flash_args" -D WORKING_DIRECTORY="/home/jocic/blink-test/build" -P /home/jocic/.esp/esp-idf-v4.4/components/esptool_py/run_serial_tool.cmake
ninja failed with exit code 1
And here are the connections, just in case.
Postby Sprite » Sat Jun 25, 2022 3:02 am
How did you pick those GPIOs? They're certainly not the default ones for the main flash. As a reference, look at figure 5 of the c3-wroom-02 datasheet.
ThunderGod
Postby ThunderGod » Sat Jun 25, 2022 7:18 am
I was referring to the datasheet, in particular Table 6 and the following:
"ESP32-C3 features three SPI interfaces (SPI0, SPI1, and SPI2). SPI0 and SPI1 can be configured to operate in
SPI memory mode, while SPI2 can be configured to operate in general-purpose SPI modes."
Pins from 19-24 are probably the default ones, could it be that only some configuration parameter needs to be changed?
Postby Sprite » Sat Jun 25, 2022 10:21 am
Those are the defaults for SPI2, iirc; not for the main SPI flash. I think you can still fix this by burning the efuses that tell the chip which pins to use for the main flash, look here for more info.
Generally, it's advised when designing a PCB to look at the hardware design guidelines and follow the examples there unless there's a good reason to deviate.
ThunderGod
Postby ThunderGod » Sat Jun 25, 2022 2:56 pm
You are right, thank you for your replies!
indigilog
Postby indigilog » Fri Jan 05, 2024 8:33 am
Hi, I am facing the same issue with my custom ESP32-C3 board. I used the default pins for the SPI flash. I am using Winbond's W25Q128JVSIQ chip for flash. But when I try to flash the board I am getting
esptool.py v4.7.dev2
Serial port COM26
Connecting...
Chip is ESP32-C3 (QFN32) (revision v0.4)
Features: WiFi, BLE
Crystal is 40MHz
MAC: 48:31:b7:35:8b:9c
Uploading stub...
Running stub...
Stub running...
Changed.
Warning: Could not auto-detect Flash size (FlashID=0xffff03, SizeID=0xff), defaulting to 4MB
Flash will be erased from 0x00000000 to 0x00005fff...
Flash will be erased from 0x00010000 to 0x0003efff...
Flash params set to 0x022f
Compressed 20496 bytes to 12566...
I checked the efuse dump
espefuse.py v4.7.dev2
Connecting...
Detecting chip type... ESP32-C3
BLOCK0          (                ) [0 ] read_regs: 00000000 00000000 00000000 00000000 80000000 00000000
MAC_SPI_8M_0    (BLOCK1          ) [1 ] read_regs: b7358b9c 00004831 00000000 03100000 41d1c340 00070a90
BLOCK_SYS_DATA  (BLOCK2          ) [2 ] read_regs: b5bbfdf0 d4d4d60f 7947a468 9d497ef2 97b4ca29 ca762483 a6498624 00000009
BLOCK_USR_DATA  (BLOCK3          ) [3 ] read_regs: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
BLOCK_KEY0      (BLOCK4          ) [4 ] read_regs: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
BLOCK_KEY1      (BLOCK5          ) [5 ] read_regs: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
BLOCK_KEY2      (BLOCK6          ) [6 ] read_regs: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
BLOCK_KEY3      (BLOCK7          ) [7 ] read_regs: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
BLOCK_KEY4      (BLOCK8          ) [8 ] read_regs: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
BLOCK_KEY5      (BLOCK9          ) [9 ] read_regs: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
BLOCK_SYS_DATA2 (BLOCK10         ) [10] read_regs: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
BLOCK0          (                ) [0 ] err__regs: 00000000 00000000 00000000 00000000 00000000 00000000
EFUSE_RD_RS_ERR0_REG        0x00000000
EFUSE_RD_RS_ERR1_REG        0x00000000
and efuse summary
Connecting...
=== Run "summary" command ===
EFUSE_NAME (Block) Description  = [Meaningful Value] [Readable/Writeable] (Hex Value)
Calibration fuses:
K_RTC_LDO (BLOCK1)                                 BLOCK1 K_RTC_LDO                                   = 24 R/W (0b0000110)
K_DIG_LDO (BLOCK1)                                 BLOCK1 K_DIG_LDO                                   = -28 R/W (0b1000111)
V_RTC_DBIAS20 (BLOCK1)                             BLOCK1 voltage of rtc dbias20                      = 56 R/W (0x0e)
V_DIG_DBIAS20 (BLOCK1)                             BLOCK1 voltage of digital dbias20                  = -8 R/W (0x82)
DIG_DBIAS_HVT (BLOCK1)                             BLOCK1 digital dbias when hvt                      = -16 R/W (0b10100)
THRES_HVT (BLOCK1)                                 BLOCK1 pvt threshold when hvt                      = 1800 R/W (0b0111000010)
TEMP_CALIB (BLOCK2)                                Temperature calibration data                       = -6.9 R/W (0b101000101)
OCODE (BLOCK2)                                     ADC OCode                                          = 76 R/W (0x4c)
ADC1_INIT_CODE_ATTEN0 (BLOCK2)                     ADC1 init code at atten0                           = 1516 R/W (0b0101111011)
ADC1_INIT_CODE_ATTEN1 (BLOCK2)                     ADC1 init code at atten1                           = -56 R/W (0b1000001110)
ADC1_INIT_CODE_ATTEN2 (BLOCK2)                     ADC1 init code at atten2                           = -144 R/W (0b1000100100)
ADC1_INIT_CODE_ATTEN3 (BLOCK2)                     ADC1 init code at atten3                           = -628 R/W (0b1010011101)
ADC1_CAL_VOL_ATTEN0 (BLOCK2)                       ADC1 calibration voltage at atten0                 = -304 R/W (0b1001001100)
ADC1_CAL_VOL_ATTEN1 (BLOCK2)                       ADC1 calibration voltage at atten1                 = -96 R/W (0b1000011000)
ADC1_CAL_VOL_ATTEN2 (BLOCK2)                       ADC1 calibration voltage at atten2                 = -292 R/W (0b1001001001)
ADC1_CAL_VOL_ATTEN3 (BLOCK2)                       ADC1 calibration voltage at atten3                 = -420 R/W (0b1001101001)
Config fuses:
WR_DIS (BLOCK0)                                    Disable programming of individual eFuses           = 0 R/W (0x00000000)
RD_DIS (BLOCK0)                                    Disable reading from BlOCK4-10                     = 0 R/W (0b0000000)
DIS_ICACHE (BLOCK0)                                Set this bit to disable Icache                     = False R/W (0b0)
DIS_TWAI (BLOCK0)                                  Set this bit to disable CAN function               = False R/W (0b0)
DIS_DIRECT_BOOT (BLOCK0)                           Disable direct boot mode                           = False R/W (0b0)
UART_PRINT_CONTROL (BLOCK0)                        Set the default UARTboot message output mode       = Enable R/W (0b00)
ERR_RST_ENABLE (BLOCK0)                            Use BLOCK0 to check error record registers         = with check R/W (0b1)
BLOCK_USR_DATA (BLOCK3)                            User data
   = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 R/W
BLOCK_SYS_DATA2 (BLOCK10)                          System data part 2 (reserved)
Flash fuses:
FLASH_TPUW (BLOCK0)                                Configures flash waiting time after power-up; in u = 0 R/W (0x0)
                                                   nit of ms. If the value is less than 15; the waiti
                                                   ng time is the configurable value; Otherwise; the
                                                   waiting time is twice the configurable value
FORCE_SEND_RESUME (BLOCK0)                         Set this bit to force ROM code to send a resume co = False R/W (0b0)
                                                   mmand during SPI boot
FLASH_CAP (BLOCK1)                                 Flash capacity                                     = None R/W (0b000)
FLASH_TEMP (BLOCK1)                                Flash temperature                                  = None R/W (0b00)
FLASH_VENDOR (BLOCK1)                              Flash vendor                                       = None R/W (0b000)
Identity fuses:
DISABLE_WAFER_VERSION_MAJOR (BLOCK0)               Disables check of wafer version major              = False R/W (0b0)
DISABLE_BLK_VERSION_MAJOR (BLOCK0)                 Disables check of blk version major                = False R/W (0b0)
WAFER_VERSION_MINOR_LO (BLOCK1)                    WAFER_VERSION_MINOR least significant bits         = 4 R/W (0b100)
PKG_VERSION (BLOCK1)                               Package version                                    = 0 R/W (0b000)
BLK_VERSION_MINOR (BLOCK1)                         BLK_VERSION_MINOR                                  = 3 R/W (0b011)
WAFER_VERSION_MINOR_HI (BLOCK1)                    WAFER_VERSION_MINOR most significant bit           = False R/W (0b0)
WAFER_VERSION_MAJOR (BLOCK1)                       WAFER_VERSION_MAJOR                                = 0 R/W (0b00)
OPTIONAL_UNIQUE_ID (BLOCK2)                        Optional unique 128-bit ID
   = f0 fd bb b5 0f d6 d4 d4 68 a4 47 79 f2 7e 49 9d R/W
BLK_VERSION_MAJOR (BLOCK2)                         BLK_VERSION_MAJOR of BLOCK2                        = With calibration R/W (0b01)
WAFER_VERSION_MINOR (BLOCK0)                       calc WAFER VERSION MINOR = WAFER_VERSION_MINOR_HI  = 4 R/W (0x4)
                                                   << 3 + WAFER_VERSION_MINOR_LO (read only)
Jtag fuses:
SOFT_DIS_JTAG (BLOCK0)                             Set these bits to disable JTAG in the soft way (od = 0 R/W (0b000)
                                                   d number 1 means disable ). JTAG can be enabled in
                                                    HMAC module
DIS_PAD_JTAG (BLOCK0)                              Set this bit to disable JTAG in the hard way. JTAG = False R/W (0b0)
                                                    is disabled permanently
Mac fuses:
MAC (BLOCK1)                                       MAC address
   = 48:31:b7:35:8b:9c (OK) R/W
CUSTOM_MAC (BLOCK3)                                Custom MAC address
   = 00:00:00:00:00:00 (OK) R/W
Security fuses:
DIS_DOWNLOAD_ICACHE (BLOCK0)                       Set this bit to disable Icache in download mode (b = False R/W (0b0)
                                                   oot_mode[3:0] is 0; 1; 2; 3; 6; 7)
DIS_FORCE_DOWNLOAD (BLOCK0)                        Set this bit to disable the function that forces c = False R/W (0b0)
                                                   hip into download mode
DIS_DOWNLOAD_MANUAL_ENCRYPT (BLOCK0)               Set this bit to disable flash encryption when in d = False R/W (0b0)
                                                   ownload boot modes
SPI_BOOT_CRYPT_CNT (BLOCK0)                        Enables flash encryption when 1 or 3 bits are set  = Disable R/W (0b000)
                                                   and disables otherwise
SECURE_BOOT_KEY_REVOKE0 (BLOCK0)                   Revoke 1st secure boot key                         = False R/W (0b0)
SECURE_BOOT_KEY_REVOKE1 (BLOCK0)                   Revoke 2nd secure boot key                         = False R/W (0b0)
SECURE_BOOT_KEY_REVOKE2 (BLOCK0)                   Revoke 3rd secure boot key                         = False R/W (0b0)
KEY_PURPOSE_0 (BLOCK0)                             Purpose of Key0                                    = USER R/W (0x0)
KEY_PURPOSE_1 (BLOCK0)                             Purpose of Key1                                    = USER R/W (0x0)
KEY_PURPOSE_2 (BLOCK0)                             Purpose of Key2                                    = USER R/W (0x0)
KEY_PURPOSE_3 (BLOCK0)                             Purpose of Key3                                    = USER R/W (0x0)
KEY_PURPOSE_4 (BLOCK0)                             Purpose of Key4                                    = USER R/W (0x0)
KEY_PURPOSE_5 (BLOCK0)                             Purpose of Key5                                    = USER R/W (0x0)
SECURE_BOOT_EN (BLOCK0)                            Set this bit to enable secure boot                 = False R/W (0b0)
SECURE_BOOT_AGGRESSIVE_REVOKE (BLOCK0)             Set this bit to enable revoking aggressive secure  = False R/W (0b0)
                                                   boot
DIS_DOWNLOAD_MODE (BLOCK0)                         Set this bit to disable download mode (boot_mode[3 = False R/W (0b0)
                                                   :0] = 0; 1; 2; 3; 6; 7)
ENABLE_SECURITY_DOWNLOAD (BLOCK0)                  Set this bit to enable secure UART download mode   = False R/W (0b0)
SECURE_VERSION (BLOCK0)                            Secure version (used by ESP-IDF anti-rollback feat = 0 R/W (0x0000)
                                                   ure)
BLOCK_KEY0 (BLOCK4)
  Purpose: USER
               Key0 or user data
BLOCK_KEY1 (BLOCK5)
  Purpose: USER
               Key1 or user data
BLOCK_KEY2 (BLOCK6)
  Purpose: USER
               Key2 or user data
BLOCK_KEY3 (BLOCK7)
  Purpose: USER
               Key3 or user data
BLOCK_KEY4 (BLOCK8)
  Purpose: USER
               Key4 or user data
BLOCK_KEY5 (BLOCK9)
  Purpose: USER
               Key5 or user data
Spi Pad fuses:
SPI_PAD_CONFIG_CLK (BLOCK1)                        SPI PAD CLK                                        = 0 R/W (0b000000)
SPI_PAD_CONFIG_Q (BLOCK1)                          SPI PAD Q(D1)                                      = 0 R/W (0b000000)
SPI_PAD_CONFIG_D (BLOCK1)                          SPI PAD D(D0)                                      = 0 R/W (0b000000)
SPI_PAD_CONFIG_CS (BLOCK1)                         SPI PAD CS                                         = 0 R/W (0b000000)
SPI_PAD_CONFIG_HD (BLOCK1)                         SPI PAD HD(D3)                                     = 0 R/W (0b000000)
SPI_PAD_CONFIG_WP (BLOCK1)                         SPI PAD WP(D2)                                     = 0 R/W (0b000000)
SPI_PAD_CONFIG_DQS (BLOCK1)                        SPI PAD DQS                                        = 0 R/W (0b000000)
SPI_PAD_CONFIG_D4 (BLOCK1)                         SPI PAD D4                                         = 0 R/W (0b000000)
SPI_PAD_CONFIG_D5 (BLOCK1)                         SPI PAD D5                                         = 0 R/W (0b000000)
SPI_PAD_CONFIG_D6 (BLOCK1)                         SPI PAD D6                                         = 0 R/W (0b000000)
SPI_PAD_CONFIG_D7 (BLOCK1)                         SPI PAD D7                                         = 0 R/W (0b000000)
Usb fuses:
DIS_USB_JTAG (BLOCK0)                              Set this bit to disable function of usb switch to  = False R/W (0b0)
                                                   jtag in module of usb device
DIS_USB_SERIAL_JTAG (BLOCK0)                       USB-Serial-JTAG                                    = Enable R/W (0b0)
USB_EXCHG_PINS (BLOCK0)                            Set this bit to exchange USB D+ and D- pins        = False R/W (0b0)
DIS_USB_SERIAL_JTAG_ROM_PRINT (BLOCK0)             USB printing                                       = Enable R/W (0b0)
DIS_USB_SERIAL_JTAG_DOWNLOAD_MODE (BLOCK0)         Disable UART download mode through USB-Serial-JTAG = False R/W (0b0)
Vdd fuses:
VDD_SPI_AS_GPIO (BLOCK0)                           Set this bit to vdd spi pin function as gpio       = False R/W (0b0)
Wdt fuses:
WDT_DELAY_SEL (BLOCK0)                             RTC watchdog timeout threshold; in unit of slow cl = 40000 R/W (0b00)
                                                   ock cycle
faizannazir289
Postby faizannazir289 » Sat Mar 09, 2024 8:16 pm
espefuse dump -p COM9
espefuse.py v4.7.0
Connecting...
MAC_SPI_8M_0    (BLOCK1          ) [1 ] read_regs: 0c8ea0bc 0000dcda 00000000 03100000 31e06620 0007d281
BLOCK_SYS_DATA  (BLOCK2          ) [2 ] read_regs: 2062b402 55eb1ea9 0def35c6 d511a306 d7466ec9 3a4e1c81 466490e7 0000000a
=== Run "dump" command ===
espefuse summary -p COM9
espefuse.py v4.7.0
Connecting...
Calibration fuses:
K_RTC_LDO (BLOCK1)                                 BLOCK1 K_RTC_LDO                                   = -48 R/W (0b1001100)
K_DIG_LDO (BLOCK1)                                 BLOCK1 K_DIG_LDO                                   = 4 R/W (0b0000001)
V_RTC_DBIAS20 (BLOCK1)                             BLOCK1 voltage of rtc dbias20                      = -60 R/W (0x8f)
V_DIG_DBIAS20 (BLOCK1)                             BLOCK1 voltage of digital dbias20                  = 36 R/W (0x09)
THRES_HVT (BLOCK1)                                 BLOCK1 pvt threshold when hvt                      = 2000 R/W (0b0111110100)
TEMP_CALIB (BLOCK2)                                Temperature calibration data                       = -21.700000000000003 R/W (0b111011001)
OCODE (BLOCK2)                                     ADC OCode                                          = 102 R/W (0x66)
ADC1_INIT_CODE_ATTEN0 (BLOCK2)                     ADC1 init code at atten0                           = 1488 R/W (0b0101110100)
ADC1_INIT_CODE_ATTEN1 (BLOCK2)                     ADC1 init code at atten1                           = -28 R/W (0b1000000111)
ADC1_INIT_CODE_ATTEN2 (BLOCK2)                     ADC1 init code at atten2                           = -112 R/W (0b1000011100)
ADC1_INIT_CODE_ATTEN3 (BLOCK2)                     ADC1 init code at atten3                           = -588 R/W (0b1010010011)
ADC1_CAL_VOL_ATTEN0 (BLOCK2)                       ADC1 calibration voltage at atten0                 = -460 R/W (0b1001110011)
ADC1_CAL_VOL_ATTEN1 (BLOCK2)                       ADC1 calibration voltage at atten1                 = -268 R/W (0b1001000011)
ADC1_CAL_VOL_ATTEN2 (BLOCK2)                       ADC1 calibration voltage at atten2                 = -400 R/W (0b1001100100)
ADC1_CAL_VOL_ATTEN3 (BLOCK2)                       ADC1 calibration voltage at atten3                 = -580 R/W (0b1010010001)
Config fuses:
Flash fuses:
Identity fuses:
   = 02 b4 62 20 a9 1e eb 55 c6 35 ef 0d 06 a3 11 d5 R/W
Jtag fuses:
                                                    HMAC module
Mac fuses:
   = dc:da:0c:8e:a0:bc (OK) R/W
Security fuses:
                                                   ownload boot modes
                                                   boot
                                                   ure)
BLOCK_KEY0 (BLOCK4)
  Purpose: USER
               Key0 or user data
BLOCK_KEY1 (BLOCK5)
  Purpose: USER
               Key1 or user data
BLOCK_KEY2 (BLOCK6)
  Purpose: USER
               Key2 or user data
BLOCK_KEY3 (BLOCK7)
  Purpose: USER
               Key3 or user data
BLOCK_KEY4 (BLOCK8)
  Purpose: USER
               Key4 or user data
BLOCK_KEY5 (BLOCK9)
  Purpose: USER
               Key5 or user data
Spi Pad fuses:
Usb fuses:
Vdd fuses:
Wdt fuses:
                                                   ock cycle
 esptool flash_id
esptool.py v4.7.0
Found 3 serial ports
Serial port COM9
Connecting...
Features: WiFi, BLE
Crystal is 40MHz
MAC: dc:da:0c:8e:a0:bc
Uploading stub...
Running stub...
Stub running...
Manufacturer: 3f
Device: ffff
Detected flash size: Unknown
Hard resetting via RTS pin...
flash size unknown
Postby Sprite » Mon Mar 11, 2024 5:44 am
Schematic looks OK, but
Device: ffff
This means there's no communication going on with the chip at all. Check your hardware.
Users browsing this forum: DuckDuckGo [Bot], Google [Bot], Semrush [Bot], trendictionbot and 0 guests
