Page 2 of 2
Re: Help! ESP32 burnt by Motor Drive Module.
Posted: Tue Apr 09, 2019 12:10 pm
by username
its possible. Another option to try on a new motor driver board to help is to put a 100 or 220 Ohm resistor in series with your 2 control wires and PWM wire to your driver board.
Posted: Fri Apr 12, 2019 10:02 am
by human890209
Thanks. I will try that. Could you tell me the physics theory of the small resistor? Do they protect the ESP32 from shortcut or something else?
Posted: Fri Apr 12, 2019 11:19 am
by username
resistors limit current. the higher the value the more they limit. For example, if you set a GPIO pin high, but that pin is shorted to gnd for whatever reason you will wind up blowing that pin. However, if you had a series resistor in line with that pin and this happened you would protect that pin from that happening.
Posted: Sat Apr 13, 2019 4:24 am
by human890209
I understand now. Thanks.
