Page 2 of 2
Re: miniz library in ROM - usable for application development?
Posted: Mon Jul 09, 2018 3:30 am
by kolban
Thank you sir. I resolved the issue with using the ROM based tinfl_decompress(). I coded something very stupidly. In order to create a buffer to hold the decompressed output I coded:
void app_main() {
   char outputBuffer[32*1024];
   ... rest of code
Does everyone see my mistake above?
The answer is that I am using default ESP-IDF and the stack size of the main FreeRTOS task is 4K. As coded above, I had allocated 32K on a 4K stack. When I then called tinfl_decompress() passing in the outputBuffer as where I wanted my results to go, I was grossly exceeding stack with all manner of strange and unusual breakage.
When corrected to use a malloc() 32K from the heap, everything fell into place and all is now working. Thanks for the notes on the use of miniz in an ESP8266 environment. I had miserably failed to consider that the stub loader was used in both ESP8266 and ESP32.
Posted: Mon May 13, 2019 7:08 am
by fasani
Hello Kolban,
Would please be so kind to share this example with us ?
I've trying to load bytes of a compressed file stored in SPIFFS:
$echo "hello Fibrevillage" | gzip -cf > /data/test.gz
Then uploaded to plataformio using :
pio run --target uploadfs
 if(SPIFFS.begin()) {
   Serial.print("SPIFFS.begin()");
    File cmpFile = SPIFFS.open("/test.gz", FILE_READ);
    char cmpFileBuf[cmpFile.size()];
int filePtr=0;
 while(cmpFile.available()){
  cmpFileBuf[filePtr] = cmpFile.read();
  filePtr++;
 // failing on the decompress part (Just code snippet from while...loop)
 if(remaining_compressed > length) {
      flags |= TINFL_FLAG_HAS_MORE_INPUT;
   status = tinfl_decompress(&inflator, (const mz_uint8 *)cmpFileBuf, &in_bytes, out_buf, next_out, &out_bytes, flags); // Dies
But I fail in the part that is using tinfl_decompress. It could be of great help if someone can post a working example of opening a GZ from SPIFFS and successfully uncompressing it using MINIZ
Posted: Sun Dec 04, 2022 7:47 pm
by StridingDragon
I know, this is an old thread but I just discovered it and it was super helpful! It made the migration from `ZLib` to `miniz` so easy and simple, and it worked with `libPNG` without a single hitch.
The hardest part was actually finding the correct `miniz.c` version for modification, to match the one implemented in the ROM, but if anyone is looking for it, it is actually located in `/esp-idf/components/esptool_py/esptool/flasher_stub/miniz.c`
Posted: Tue Sep 12, 2023 1:27 pm
by ob_seven
Thank you!
I finally discovered WHY I could not link the Miniz in ROM ...
I made the mistake to assume the full miniz was there, but I was wrong.
All was correct, except a linker error at last step in binary generation. No wonder, I was calling mz_compress and mz_uncompress which are not the low level functions.
All is clear now. Took me 3 days to understand.
I will take the Miniz.c adder code, to get the full zlib like APIs...
