Code: Untitled.txt Select all
Here's how I did a pan and tilt platform with the ESP32-CAM - https://robotzero.one/pan-and-tilt-cont ... esp32-cam/ There might be some helpful code in the tutorial.Hi Mad scientist,
I am trying to do like you did and have the servo and cam both work at the same time. Can you explain how you got around sending servo and the cam over wireless at the same time?
Thank you very much
Thanks - I have seen that one. Just trying to figure out how I can send the servo values from my computer (I have another program that is generating where the servos should move to).Here's how I did a pan and tilt platform with the ESP32-CAM - https://robotzero.one/pan-and-tilt-cont ... esp32-cam/ There might be some helpful code in the tutorial.Hi Mad scientist,
Thank you very much
