[Video] ESP32 - DS1307 real time clock
gregstewart90
Re: [Video] ESP32 - DS1307 real time clock
Postby gregstewart90 » Fri Apr 14, 2017 6:26 pm
Got it working! Thanks Kolban for your help. My problem was with localtime(). Before using it, you have to call time().
time_t now_after;
time ( &now_after );
char buff_after[100];
strftime (buff_after, 100, "%Y-%m-%dT%H:%M:%S.000", localtime (&now_after));
I do have one problem. Sometimes the reads are okay and other times I get an error on i2c_master_cmd_begin(). The error is ESP_ERR_TIMEOUT. It will work for a long time and then on a reboot wont work. Eventually it starts working again after several reboots. Kolban I am using your code for the DS1307. I found this https://github.com/espressif/esp-idf/issues/422, but the solution didn't help.
Thoughts?
tbnobody
Postby tbnobody » Mon Aug 14, 2017 12:32 am
I am having exactly the same problem. I am using a DS3231 (which is nearly compatible with the DS1307) but I cannot read anything using the ESP-IDF. If I use the Arduino environment (as a component in an IDF project) everything works fine.
The arduino code which I am using is from this site: http://tronixstuff.com/2014/12/01/tutor ... h-arduino/
The IDF code which I am using is from here: https://github.com/nkolban/esp32-snippe ... c/ds1307.c
I am able to write the time but reading just gives me a timeout error:
D (1108) ds3231: >> ds1307
D (1111) ds3231: >> writeValue: 1502670328
D (1115) ds3231:  - Mon Aug 14 00:25:28 2017
E (2120) ds3231: i2c_master_cmd_begin: 263
D (2120) ds3231: time: 14
ESP_ERROR_CHECK failed: esp_err_t 0x107 at 0x400e3aec
kolban
Postby kolban » Thu Aug 17, 2017 3:28 am
I've always needed a logic analyzer (about $5-$10 on ebay) to debug I2C or SPI issues. Looking at the logic train on the wire is (for me) the only way to debug these kinds of issues.
musabaybek
Postby musabaybek » Sat Oct 12, 2019 4:04 pm
The code that is provided here https://github.com/nkolban/esp32-snippe ... c/ds1307.c does not have make file, however I tried to create one and also component.mk files. But I face some errors like; "fatal error: errorhandle_func.h: No such file or directory"
I'm new to esp32 and idf based coding... Can you please help?
cndgeek
Postby cndgeek » Sun Jul 17, 2022 1:29 pm
So much confusion in all the above!!!
This should help everyone sort stuff out:
Code: Untitled.c Select all
/* Constructor for the RTC on the logging shield. */
DFRobot_DS1307 DS1307;
char daynames[]="SUN\0MON\0TUE\0WED\0THU\0FRI\0SAT\0";
// Set the ESP32 time from the RTC.
bool StartRTC() { // See http://www.rinkydinkelectronics.com/resource/DS1307/DS1307.pdf
if( !(DS1307.begin()) ){
Serial.println(F("Communication with DS1307 RTC device failed"));
return 1;
struct dsTimeStruct {
uint16_t tm_sec; /* seconds, range 0 to 59 */
uint16_t tm_min; /* minutes, range 0 to 59 */
uint16_t tm_hour; /* hours, range 0 to 23 */
uint16_t tm_wday; /* day of the week, range 0 to 6 */
uint16_t tm_mday; /* day of the month, range 1 to 31 */
uint16_t tm_mon; /* month, range 1 to 12 (not 0 to 11!) */
uint16_t tm_year; /* The number of years since 1900 */
uint16_t tm_yday; /* day in the year, range 0 to 365 */
uint16_t tm_isdst; /* daylight saving time */
} dstm ={0};
DS1307.getTime((uint16_t *)&dstm); //dstm.tm_mon--; // The month on the DS1307 is 1-12.
Serial.printf("DS1307 time: %s %4d/%02d/%02d %02d:%02d:%02d UTC\r\n", // DS1307 time: SUN 2022/07/17 13:06:10 UTC
&daynames[dstm.tm_wday*4], //Weekday &daynames[(getTimeBuff[3])*4], //Weekday [3]
dstm.tm_year, // Year [6]
dstm.tm_mon, // Month [5]
dstm.tm_mday, // Day [4]
dstm.tm_hour, // Hours dstm.dsRaw[2]
dstm.tm_min, // Mins dstm.dsRaw[1]
dstm.tm_sec // seconds dstm.dsRaw[0]
time_t seconds;
time(&seconds); // Put the time into seconds
struct tm *esptm;
esptm=gmtime(&seconds);
Serial.printf("ESP32 internal time: %s",asctime(esptm)); // ESP32 internal time: Thu Jan 1 00:00:00 1970
//DS1307 format is not same as linux ( they put the tm_wday in the middle, and don't have yday and isdst).
struct tm newdstm; newdstm.tm_sec =dstm.tm_sec; newdstm.tm_min =dstm.tm_min; newdstm.tm_hour=dstm.tm_hour;
newdstm.tm_wday=dstm.tm_wday; newdstm.tm_mday=dstm.tm_mday; newdstm.tm_mon =dstm.tm_mon-1; newdstm.tm_year=dstm.tm_year-1900;
// Serial.printf("newdstm time: %s",asctime(&newdstm)); // newdstm time: Mon Jul 17 13:09:32 2022
struct timeval dstv = { .tv_sec = mktime(&newdstm), .tv_usec = 0}; // &dstm.tm_ds
settimeofday(&dstv, NULL);
time(&seconds); // Put the updated-above time into seconds
esptm=gmtime(&seconds); // Convert epoc-based to D/M/Y...
Serial.printf("new ESP32 internal time: %s",asctime(esptm)); // new ESP32 internal time: Sun Jul 17 13:14:29 2022
return 0;
} // StartRTC
