Uncorrect ADC iniziatization with I2S
Gianluca.Loi
Re: Uncorrect ADC iniziatization with I2S
Postby Gianluca.Loi » Thu Apr 22, 2021 7:04 am
Hello klaetze,
Which IDF are you using? Before pointing to 2Msps, did you try with slower sampling rate?
Could you show me some of your code?
I don't call bootloader_random_disable() function because it is called by the fw start-up routine.
Gianluca.
klaetze
Postby klaetze » Thu Apr 22, 2021 9:24 am
Hi Gianluca,
thanks for your reply,
I tried several sampling rates from 3 kHz to 100 kHz but it didn't work for any of them.
I am using the esp-idf version 4.1.
Here is the code that I used. I reused quite a lot of Your code.
#define TAG                         "I2S"
#define SAMPLE_RATE                 5000
#define I2S_UNIT			(0)
#define DMA_BUF_COUNT               4
#define DMA_BUF_LEN                 1024
#define ADC_UNIT                    1
#define ADC_CHANNEL         		0
#define NUM_SAMPLES                 1024
xQueueHandle adc_i2s_event_queue;
uint8_t adc_i2s_event_queue_size = 1;
i2s_event_t adc_i2s_evt;
static void adc_i2s_init(void)
	esp_err_t ret = ESP_OK;
	i2s_config_t adc_i2s_config =
			.mode = I2S_MODE_MASTER | I2S_MODE_RX | I2S_MODE_ADC_BUILT_IN,
			.sample_rate = SAMPLE_RATE,
			.bits_per_sample = I2S_BITS_PER_SAMPLE_16BIT,
			.communication_format = I2S_COMM_FORMAT_I2S_MSB,
			.channel_format = I2S_CHANNEL_FMT_ONLY_LEFT,
			.intr_alloc_flags = 0,
			.dma_buf_count = DMA_BUF_COUNT,
			.dma_buf_len = DMA_BUF_LEN,
			.use_apll = 1,//false,
			.tx_desc_auto_clear = true
	static const i2s_pin_config_t pin_config = {
		.bck_io_num = 32,							// Sample f(Hz) (= sample f * 2)  on this pin (optional).
		.ws_io_num = 33,							// Left/Right   (= sample f)      on this pin (optional).
		.data_out_num = I2S_PIN_NO_CHANGE,
		.data_in_num = I2S_PIN_NO_CHANGE
	//install and start i2s driver
    ret = i2s_driver_install(I2S_UNIT, &adc_i2s_config, adc_i2s_event_queue_size , &adc_i2s_event_queue);
	if (ret  != ESP_OK)
		ESP_LOGE(TAG, "i2s_driver_install operation error = %i", ret);
	// Output sample clock & left/right signals to measure with oscilloscope (optional).
	i2s_set_pin(I2S_UNIT, &pin_config);
	//init ADC pad
	ret = i2s_set_adc_mode(ADC_UNIT, ADC_CHANNEL);
	if (ret  != ESP_OK)
		ESP_LOGE(TAG, "i2s_set_adc_mode_custom operation error = %i", ret);
	vTaskDelay(2000);
static void adc_i2s_enable(void)
	ESP_ERROR_CHECK(i2s_zero_dma_buffer(I2S_UNIT));
	ret = i2s_adc_enable(I2S_UNIT);
	if (ret  != ESP_OK)
		ESP_LOGE(TAG, "i2s_adc_enable_custom operation error = %i", ret);
static void adc_i2s_disable(void)
	i2s_adc_disable(I2S_UNIT);
static void adc_i2s_restore_sampling(void)
	adc_i2s_disable();
	vTaskDelay(100);
	adc_power_on();
	adc_i2s_init();
	adc_i2s_enable();
#define I2S_MAX_CHANNELS 1
// Convert DMA 16bit (Chan 4b + ADC 12b) => 12bit, and print them in the same order each time.
void i2s_print_adc_data(uint8_t* s_buff, uint32_t len)
	uint16_t dac_value[] = 		// Max 8 ADC1 input channels/pins.
		{0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF};
	int chan = 0;
	printf( "\tChan[n] : ADC raw\t");
	for (int i = 0; i < len; i += (I2S_MAX_CHANNELS * 2)) {
		for (int j = 0; j < (I2S_MAX_CHANNELS * 2); j += 2) {
			chan = s_buff[i + j + 1] >> 4;				// Cannel nbr is in bit 7:4.
			dac_value[chan] = (((s_buff[i + j + 1] & 0x0F) << 8) | s_buff[i + j + 0 ]);
		for (int j = 0; j < 8; j ++) {
			if(dac_value[j] != 0xFFFF)
				printf( "\t[%d] : %04x", j, dac_value[j]);
	printf("\n\n");
static void adc_task(void *pvParameter)
	size_t bytes_read;
    uint8_t* adc_data_buf = (uint8_t*) calloc(NUM_SAMPLES, sizeof(char));
	adc_i2s_init();
	vTaskDelay(5000 / portTICK_PERIOD_MS);
	adc_i2s_enable();
	while ( 1 )
		if(xQueueReceive(adc_i2s_event_queue, (void * )&adc_i2s_evt, (portTickType)portMAX_DELAY))
			if(adc_i2s_evt.type == I2S_EVENT_RX_DONE)
                //vTaskDelay(3000 / portTICK_PERIOD_MS);
				ret = i2s_read(I2S_UNIT, (char*)adc_data_buf, NUM_SAMPLES, &bytes_read, portMAX_DELAY);
				if (ret  != ESP_OK)
					ESP_LOGE(TAG, "i2s_read operation error = %i", ret);
				if(((adc_data_buf[0]) == 0) && ((adc_data_buf[1]) == 0) && ((adc_data_buf[2]) == 0))
					printf("adc_data_buf[0] = %d adc_data_buf[1] = %d adc_data_buf[2] = %d\n",adc_data_buf[0],adc_data_buf[1],adc_data_buf[2]);
					// If the adc reads zero values, it means it hasn't been started correctly. Restart it again to fix this problem.
					adc_i2s_restore_sampling();
				else
					ESP_LOGW(TAG, "RESTARTING");
					vTaskDelay(1000);
					// Restart is done to reproduce this problem
					esp_restart();
	adc_i2s_disable(); // Unreachable
esp_err_t app_main()
	esp_log_level_set("I2S", ESP_LOG_INFO);
	xTaskCreate( adc_task, "example_i2s_adc_dac", 4096, NULL, 5, NULL);
	while(1)
	return ESP_OK;
Gianluca.Loi
Postby Gianluca.Loi » Thu Apr 22, 2021 10:16 am
hello klaetze,
Giving a quick view of your code I noticed some point.
In your configuration, you set ".bits_per_sample = I2S_BITS_PER_SAMPLE_16BIT,", so, when you make a calloc you will need:
uint16_t* adc_data_buf = (uint16_t*) calloc(NUM_SAMPLES, sizeof(uint16_t));
And so, in your read:
ret = i2s_read(I2S_UNIT, (char*)adc_data_buf, NUM_SAMPLES*2, &bytes_read, portMAX_DELAY);
because you are casting adc_data_buf as a (char*)
Also, try to print the raw value by:
for(int i = 0; i < NUM_SAMPLES; i++)
    ets_printf("%d ", adc_data_buf[i]);
before any calculation on it.
Let me know if you will have any progress.
Regards,
Gianluca.
klaetze
Postby klaetze » Thu Apr 22, 2021 11:23 am
Hi Gianluca,
You are right that doesn't make sense in my code. I changed it according to your suggestions.
The problem unfortunately remains the same.
Gianluca.Loi
Postby Gianluca.Loi » Thu Apr 22, 2021 12:07 pm
Hello klaetze,
try to put ".use_apll = false," and also, which kind of values are you supposed to read?
To do some test, you can try to set up a DAC output and bring it (by a wire for example) to che ADC pin and try to read it in order to have a specific value.
Regars,
Gianluca.
klaetze
Postby klaetze » Thu Apr 22, 2021 1:37 pm
I have already tried both .apll=true, and apll=false, without any difference.
As input I use a cosine wave with a frequency of about 400Hz for testing purposes. I have also used constant values of 2.0V, but the adc display remains zero. :|
klaetze
Postby klaetze » Thu Apr 22, 2021 6:42 pm
With the following code (quite messy) I am able to get realistic adc readings up to a frequency of 10 ksps however as soon as i increase the sampling rate over 10 ksps the adc-readings are all zeros again.
#include "esp_log.h"
#include "driver/i2s.h"
#include "soc/syscon_reg.h"
#include "driver/adc.h"
#include "esp_wifi.h"
#include "esp_event_loop.h"
#include "nvs_flash.h"
#include "driver/dac.h"
#define TAG "adc_i2s"
xQueueHandle i2s_event_queue;
i2s_event_t evt;
static EventGroupHandle_t wifi_event_group;
static esp_err_t event_handler(void *ctx, system_event_t *event)
    switch(event->event_id) {
        case SYSTEM_EVENT_STA_START:
            esp_wifi_connect();
        case SYSTEM_EVENT_STA_GOT_IP:
        case SYSTEM_EVENT_STA_DISCONNECTED:
        default:
    return ESP_OK;
#define COSINE
static void dac_task()
	#ifdef COSINE
		dac_cw_config_t cosine = {
			.en_ch = DAC_CHANNEL_1,			// output on pin 25
			.scale = 0x0,
			.phase = 0x2,
			.freq = 500,
			.offset = 1
		ret = dac_cw_generator_config(&cosine);
		if (ret  != ESP_OK)
				ESP_LOGE(TAG, "dac config error = %i", ret);
		else
			printf("config succesful\n");
		ret = dac_cw_generator_enable();
		if (ret  != ESP_OK)
				ESP_LOGE(TAG, "dac enable error = %i", ret);
		else
				printf("enable succesful\n");
		dac_output_enable( DAC_CHANNEL_1);
	#else
		dac_output_enable(DAC_CHANNEL_1);
		dac_output_voltage(DAC_CHANNEL_1, 150);
	#endif
    while(1)
        vTaskDelay(1000/portTICK_PERIOD_MS);
	//dac_output_enable(DAC_CHANNEL_1)
void adc_task()
// initialization
    i2s_config_t i2s_config = {
        .sample_rate =  100000,
        .communication_format = I2S_COMM_FORMAT_I2S,//I2S_COMM_FORMAT_I2S_MSB,
        .intr_alloc_flags = ESP_INTR_FLAG_LEVEL1,
        .dma_buf_count = 2,
        .dma_buf_len = 1024,
        .use_apll = true,
    printf("after config struct\n");
    i2s_driver_install(I2S_NUM_0, &i2s_config, adc_i2s_event_queue_size , &i2s_event_queue);
    printf("driver installed\n");
	i2s_set_pin(I2S_NUM_0, &pin_config);
    ESP_ERROR_CHECK(i2s_set_adc_mode(ADC_UNIT_1, ADC1_CHANNEL_0));
    ESP_ERROR_CHECK(i2s_adc_enable(I2S_NUM_0));
    // workaround
    vTaskDelay(10 / portTICK_PERIOD_MS);
    // enable continuous adc sampling
    SYSCON.saradc_ctrl2.meas_num_limit = 0;
    // channel, attenation, bit width
    SYSCON.saradc_sar1_patt_tab[0] = ((ADC1_CHANNEL_0 << 4) | (ADC_WIDTH_BIT_12 << 2) | ADC_ATTEN_DB_11) << 24;
    // After running WiFi on esp_wifi_set_mode(), the ADC-I2S scanning is stops.
    // init_wifi();
    //dac_task();
    // Read DMA event queue as ADC scanning result
    printf("test\n");
    int i2s_read_len = 1024 * 2;
    size_t bytes_read = 0;
    uint16_t i2s_read_buff[1024];
    printf("while\n");
    while(1) {
        printf("in while\n");
        if (xQueueReceive(i2s_event_queue,(void *)&evt, (portTickType)portMAX_DELAY)) {
            printf("first if\n");
            if (evt.type==2) {
                printf("second if\n");
                i2s_read(I2S_NUM_0, (char*)i2s_read_buff, i2s_read_len, &bytes_read, portMAX_DELAY);
                ESP_LOG_BUFFER_HEX("i2s_read_buff", i2s_read_buff, 16);
void app_main()
    xTaskCreate(dac_task, "DAC_TASK", 4096, NULL, 5, NULL);
    xTaskCreate(adc_task, "ADC TASK", 8192, NULL, 5, NULL);
    while(1)
klaetze
Postby klaetze » Mon Apr 26, 2021 1:46 pm
Hi Guys,
i had to update from esp-idf version 4.1 to 4.2. Now everything is working as it should.
For further questions check out this post: https://github.com/espressif/esp-idf/pull/1991
Gianluca.Loi
Postby Gianluca.Loi » Mon Apr 26, 2021 1:49 pm
Hello Klaetze,
Great!
I haven't answer you yet because I haven't any time to test your fw. I'm glad you solved your problem.
Did you reach 2Msps?
Regards,
Gianluca.
klaetze
Postby klaetze » Mon Apr 26, 2021 7:51 pm
Hi Gianluca,
i measured the Sampling frequency with an oscilloscope and its indeed 2 Msps.
I also made a measurement with a pwm signal of 120 kHz and a duty cycle of 90%. As you can see on the picture it is pretty much 2 Msps.
Users browsing this forum: Amazon [Bot], PerplexityBot and 0 guests
