unnable to run eth2wifi , need help
filip.geib
Re: unnable to run eth2wifi , need help
Postby filip.geib » Sun Oct 24, 2021 4:32 pm
It may be late for you, but I also tried to run eth2wifi, failed first, and finally was successful. I had to make same changes to the ESP-IDF code to get it running on version 4.3. Here I wrote down details:
https://github.com/makischu/ESP_eth2wifi
Hope this is helpful for people in the same situation.
I tried your modifications on my board using KSZ8041 PHY. Unfortunately, I ran into the same problem of dead wifi2eth traffic. With WireShark I'm able to track DHCP request from eth device, then DHCP offer from my router but sadly no response to that - DHCP offer does not make it to eth device. The KSZ8041 PHY was added to esp-idf in version 4.3.1. Do you think that there might be a problem with its drivers? Do you have any suggestions on what I should look for?
Users browsing this forum: Applebot, ChatGPT-User and 1 guest
