Confirmations about ESP32 peripherals
metRo_
Re: Confirmations about ESP32 peripherals
Postby metRo_ » Fri Apr 01, 2016 9:45 am
BTW what is HS1d0-d7 HS1clk HS1cmd ?
8-bit SDIO
Is this SDIO free? Do you think it is possible to use it to drive an LCD using DMA?
and by software can I write to a register and the data is sent out to HS1d0-d7 ? It is faster then clock the 8 bits out.
metRo_
Postby metRo_ » Tue Apr 05, 2016 10:33 pm
Where can I get more information on the sd card interface? I tried Xtensa LX6 documentation but doesn't found any public document. Which would be the maximum clock on this interface?
Postby Sprite » Wed Apr 06, 2016 4:05 am
No idea about the SPI, but the ESP32 is going to have a modified I2S module. The DMA capabilities that has will stay, but it will also be able to output/input parallel data so you can e.g. send images to a parallel LCD using DMA.
star_7
Postby star_7 » Sat Dec 10, 2016 3:48 pm
I want to use I2S module,to read input data.but esp32_datasheet did not say specifically how to use I2S,Can you tell me the specific configuration steps to use?How to operate the register steps?thank you
Postby Sprite » Sun Dec 11, 2016 7:41 am
Sorry, the I2S chapter of the TRM is still in editing. We'll try to update it ASAP, but it'll probably take at least a few more weeks.
Users browsing this forum: Bytespider, ChatGPT-User and 3 guests
