Inputting audio to an ESP32 from an INMP441 I2S microphone: success
walinsky
Re: Inputting audio to an ESP32 from an INMP441 I2S microphone: success
Postby walinsky » Mon Oct 02, 2023 6:47 pm
I had the same problems a few weeks ago. And finally solved it in a different thread.
khanhbkisp
Postby khanhbkisp » Mon Oct 30, 2023 4:41 pm
Hi, I do exactly the same as chris_oz but in IDF 4.4.3. But after read I2S, my buffer32 is all zero. When I change to 16 bits per sample, it works. But with 16 bits per sample, when I test with 500Hz, it seems like it's not working correctly. I just really want to know why 32 bits per sample not working in this case.
This is my i2s configuration:
// Set up I2S Processor configuration
void i2s_install() {
  i2s_config_t i2s_config = {
    .mode = (i2s_mode_t)(I2S_MODE_MASTER | I2S_MODE_RX),
    .sample_rate = 4000, // or 44100 if you like
    .bits_per_sample = I2S_BITS_PER_SAMPLE_32BIT,
    .channel_format = I2S_CHANNEL_FMT_ONLY_LEFT, // Ground the L/R pin on the INMP441.
    .communication_format = (i2s_comm_format_t)(I2S_COMM_FORMAT_STAND_I2S),
    .intr_alloc_flags = ESP_INTR_FLAG_LEVEL1,
    .dma_buf_count = bufferCount,
    .dma_buf_len = bufferLen,
    .use_apll = false,
    .tx_desc_auto_clear = false,
    .fixed_mclk = 0,
  i2s_driver_install(I2S_PORT, &i2s_config, 0, NULL);
And this is how I read I2S:
while (1)
        vTaskDelay(1); // Feed for watchdog, if not watchdog timer will be triggered!
        i2s_read(I2S_PORT, &buffer32, sizeof(buffer32), &bytesRead, 100);
        int samplesRead = bytesRead / 4;
        for (uint8_t i = 0; i < samplesRead; i++) {
            uint8_t mid = buffer32[i * 4 + 2];
            uint8_t msb = buffer32[i * 4 + 3];
            uint16_t raw = (((uint32_t)msb) << 8) + ((uint32_t)mid);
            memcpy(&buffer16[i], &raw, sizeof(raw)); // Copy so sign bits aren't interfered with somehow.
            printf("%d %d %d\n", 3000, -3000, buffer16[i]);
Is there any problem with I2S protocol in this version of IDF ? Has anyone ever encountered this problem? If yes and solved the problem please help me.
bstolk
Postby bstolk » Sat Dec 09, 2023 7:13 pm
And that's it! You've got an array of 16-bit signed samples that are good to go.
Can you tell me... those samples you end up with, are they R,L,R,L,R,L...
Or only L?
Thanks!
wangnick
Postby wangnick » Tue Dec 12, 2023 6:38 pm
Try I2S_CHANNEL_FMT_ONLY_RIGHT to receive the data from the "left" INMP441 channel (i.e. the data that the INMP441 provides in the first half of the sampling period when WS is LOW and the L/R pin is tied to GND). For me that does the trick.
KR, Sebastian
