How to use virtual file system.?
jgfrmesp
Re: How to use virtual file system.?
Postby jgfrmesp » Tue May 16, 2017 7:51 am
@perryc:
Can you somehow share your code? I can not send you a pm (it seems that this is blocked for new users; why?)
Jaap
Fugazi
Postby Fugazi » Tue May 16, 2017 4:26 pm
I have it working now, works very well, reading and writing a file to flash.
I am using it with ardunio and had to increase the task stack to run the espidf vfs_fat example.
Should be able to compile the wear leveling code example and add the custom file partition for the filesystem and it will work.
Phil.
jgfrmesp
Postby jgfrmesp » Wed May 17, 2017 11:14 am
Interesting.
How was it done?
loboris
Postby loboris » Wed May 17, 2017 4:44 pm
Yes, that precisely the case. Spiffs raw (so without vfs) works fine.
As soon as I use the vfs part (I used the code at https://github.com/nkolban/esp32-snippe ... vfs/spiffs)m I can not read the file back (I can not see if it is written in the first place).
Best,
Jaap
Take a look at: viewtopic.php?f=18&t=1901
Laila_
Postby Laila_ » Thu May 18, 2017 5:22 pm
Hello, I'm new on ESP32 ( have only little experience in programming) and currently working on a simple webserver. ESP starts in AP-mode.
I hope to find a solution for the following issue and kindly ask for help: :)
I would like to load a file that contains my html-code.
I tried to simply use the FS.h library and the code that was used on ESP8266 since I could not find a reference guide for the ESP32 libraries that i undestood.
I compiled in Arduino IDE and also PlatformIO.
In Arduino I used the library from espressif github https://github.com/espressif/arduino-esp32
Error is: " 'SPIFFS' was not declared in this scope "
Heres the important part of my code:
#include <FS.h>
#include <WiFi.h>
#define DEBUGMODE 1
/*Wifi Access data*/
const char* ssid_ap = "AccessPoint";
const char* password_ap = "12345678";
const char * ssid_sta     = "<SSID>";
const char * password_sta = "<Password>";
/* set global variables */
byte WiFiMode = 0;  // WIFI_STA = 1 = Workstation  WIFI_AP = 2  = Accesspoint
int request_counter;
String sHTML;
String sHTMLRequest;
/* Create instance of server on Port 80 */
WiFiServer server(80);
WiFiClient client;
/*start serial communication */
  SPIFFS.format();
  Serial.println("Spiffs formatted");
/* start WiFi as workstation (STA), if not possible
   start as Acess Point initialize server */
  WiFi_Start_STA();
  if (WiFiMode == 0) WiFi_Start_AP();
  /* Check if a client has connected */
  client = server.available();
  if (!client)
    return;
 /*Wait for the client to send data */
  Serial.println("neuer Client verbunden");
  /*Count Aufruf der Seite: */
  request_counter ++;
  unsigned long clTimeout = millis()+250;
  while(!client.available() && (millis()<clTimeout) )
    delay(1);
  if(millis()>clTimeout)
    Serial.println("time-out bei Client-Verbindung!");
    return;
/****** open html files  *******/
  SPIFFS.begin();
  File f = SPIFFS.open("/home.txt", "r");
  if (!f) {
  Serial.println("file open failed");
    f.close();
perryc
Postby perryc » Thu May 18, 2017 10:59 pm
Sorry for slow reply jgfrmesp - I'd not seen this thread was still active. Is there any reason we'd not want to move on to using the wear leveling driver that's now in the esp-idf? So far it's been working well in my tests other than I've not solved how to flash a prebuilt filesystem.
Perry
Users browsing this forum: Qwantbot and 3 guests
