Page 2 of 2
Re: ESP32 Can't make an accurate Frequency Counter ???
Posted: Mon Sep 07, 2020 1:25 pm
by plusorc
Thanks for all the people who tried to help
and special thanks to @chegewara for a previous help in a different topic .
The problem was fixed by inverting the Signal , not by any software changes .
It looks like if you hold an INPUT PIN high , you get that behaviour
but if you invert the signal "which I did" , it works with no problems
Have no idea why is that , but the circuit is here and also the code ,so any one interested ..you can try it .
below is the complete circuit for anyone interested
the 2 10K resistors are connected to the 3.3v supply , sorry if that is not very clear (I'm a software guy)
Power for PIC817 and 2N222 is NOT from ESP
2n222 was used to invert the signal and that solved the problem .
as for PCNT , LEDC .. , Those are very good for HIGH Frequencies .. not for 50Hz , it's an overkill for such low frequency
besides I got double that frequency accurately with 2 ESPs
and again the Sketch to read is simple while loops to measure the wavelength
I did put it in a Task , but that is not even necessary , it can be in the main loop and it will give the same results
int FC_PIN = 34 ;
void Get_Cycle_Length(void* arrow)
  for(;;)
    char buf[8] = "";
    volatile int64_t start_time, end_time, cycle_duration ;
    noInterrupts() ;
    while(digitalRead(FC_PIN) != LOW)
    // while(analogRead(FC_PIN) > 0)
        // If we get here while the phase is high .. wait till the phase is LOW
    while(digitalRead(FC_PIN) == LOW)
    // while(analogRead(FC_PIN) == 0)
        // Wait till the LOW Phase ends so we start the timer
    start_time = esp_timer_get_time(); // timer in microSeconds
    while(digitalRead(FC_PIN) == HIGH)
      // another wait till the  HIGH phase ends
      // another wait till we reach the high phase again
    end_time = esp_timer_get_time() ;
    cycle_duration  =  end_time - start_time ;
    interrupts();
    Serial.printf("Start_Time : %jd \t End_Time : %jd \t", start_time, end_time);
    Serial.printf("Duration for 1 Cycle is : %.3f mSec\n", cycle_duration/1000.0);
    //start_time = end_time = cycle_duration = 0 ;
    delay(950); // read wavelength every 950mSec
void setup()
  Serial.begin(115200);
  pinMode(FC_PIN,INPUT);
  noInterrupts() ;
  delay(1000);
  xTaskCreate(Get_Cycle_Length, "Cycle_Length", 8192, NULL,4,NULL);
void loop()
Performance can be watched here , with NO PCNT or ledC or RMT , this is just 50Hz !
https://streamable.com/me5bo8
Posted: Wed Nov 30, 2022 10:25 pm
by Ahmet58
Hello, I've looked at the code a bit and I'm trying to understand it. Didn't you write any code inside the loop? Also, I watched the video in the link. Normally, you were saying that you are trying to count 50hz. I don't understand why it wasn't counted.
Posted: Sun Aug 06, 2023 4:43 pm
by Macckone
The likely cause of issues is a slow rising edge. The usual solution is to implement a schmitt trigger. Which the second transistor will act like.
Posted: Wed Nov 06, 2024 6:08 am
by svedblen
@plusorc
Did you ever find an explanation? Any solution?
Cheers!
