Re: Setting up Development Toolchain for ESP32
Posted: Wed May 24, 2017 9:50 am
that no rule to make target, sounds to me like IDF_PATH is not set.
where you set it?Ok, but how to set the IDF_PATH?
..$ echo $IDF_PATH
pbl@pbl-Komputer MINGW64 ~
$ echo $IDF_PATH
C:/msys32/home/pawel/esp/esp-idfCode: Select all
$ echo $IDF_PATH
C:/msys32/home/pawel/esp/esp-idffrom your first post:hi Rudi
C:\msys32\home\pawel\esp\esp-idf - is empty at the momentCode: Select all
pbl@pbl-Komputer MINGW64 ~ $ echo $IDF_PATH C:/msys32/home/pawel/esp/esp-idf
Regards,
Pawel
you must get the exported path "c:/ESP/esp-idf"1. I have downloaded the esp32_win32_msys2_environment_and_toolchain-20170330,
2. then made git clone --recursive https://github.com/espressif/esp-idf.git in under a directory C:\ESP\esp-idf
3. Downloaded the template into directory myapp2 git clone https://github.com/espressif/esp-idf-template.git myapp2
4. Exported export IDF_PATH="C:\ESP\esp-idf"
5. Then hit the make command to compile the project. make
cd ~/esp
~/esp/esp-idf
$ echo $IDF_PATH
c:/msys32/home
pbl
pawel
$ python -V
make -v
$ python -V
Python 2.7.11
or likewise and you have the esp-idf in c:\esp\esp-idf$ make -v
GNU Make 4.2.1
Gebaut für i686-pc-msys
Copyright (C) 1988-2016 Free Software Foundation, Inc.
Lizenz GPLv3+: GNU GPL Version 3 oder später <http://gnu.org/licenses/gpl.html>
Dies ist freie Software: Sie können sie nach Belieben ändern und weiter verteilen.
Soweit es die Gesetze erlauben gibt es KEINE GARANTIE.
export IDF_PATH="C:/msys32/home/Krzysztof/esp/esp-idf"
export IDF_PATH="C:/ESP/esp-idf"
How can I fix it?there are two users show thenCODE: SELECT ALL
pbl
pawel
Answare:
$ python -V
-bash: python: No command found
