ESP32-S2 with Arduino IDE
espiando
Re: ESP32-S2 with Arduino IDE
Postby espiando » Thu Oct 21, 2021 4:26 pm
thanks to all, it worked yesterday.
I manage to install again Arduino with ESP 2.0 ( Clean install) and now is working without any problem
Da Flex
Postby Da Flex » Thu Oct 21, 2021 6:41 pm
@johnfrancisbarjols
You don't have that chip. "ESP32-S2" has to be written on the chip.
Select the right chip on the board manager.
johnfrancisbarjols
Postby johnfrancisbarjols » Fri Oct 22, 2021 7:11 pm
Ok thanks , I have tried all the other listed EPS32 boards that I can find.......uploaded the suggested windows drivers..... the pc makes a little dingaling when I plug it in. I selected ESP32 DEV MODULE as the board in IDE .........but grayed out port
Da Flex
Postby Da Flex » Mon Oct 25, 2021 2:52 pm
@johnfrancisbarjols
Then your chip isn't supported yet. ESP32 on Arduino is pretty new. You can:
- buy an S2 or C3, who already have Arduino support
- use the command line tool esp-idf
Marios
Postby Marios » Sat Oct 30, 2021 12:50 am
I bought an ESP-S2-DevKitM-1 and I want to use the Arduino Ide, I am looking for the procedure to install the software, could you help me.
I would also like to know if the procedure to install the ESP-C3-DevKitM-1 works for the ESP-S2-DevKitM-1.
Da Flex
Postby Da Flex » Fri Nov 05, 2021 11:17 pm
@Marios
These instructions work for C3 and S2. After installation you have to select each board separately to program it.
https://docs.espressif.com/projects/ard ... installing
Users browsing this forum: ChatGPT-User, Google [Bot] and 1 guest
