Latest IDF extension for VSCode has broken my compiler
orbitcoms
Re: Latest IDF extension for VSCode has broken my compiler
Postby orbitcoms » Fri May 07, 2021 6:11 am
Currently I use the IDF terminal "idf.py flash monitor" when I make changes to the spiffs folders and use the compile/flash/monitor icon when only changing code.
Hope they fix the function soon, bit inconvenient doing 2 different processes and remembering I need to do it by command line if programming spiffs flash.
stdenits
Postby stdenits » Fri May 07, 2021 12:04 pm
Right click at ESP IDF extension -> Install another version -> Choose 1.0.2 -> Reload VS Code -> Done.
Now, when the chip is flashed, the files will be uploaded.
bunfight
Postby bunfight » Thu May 13, 2021 4:14 pm
"ESP IDF extension -> Install another version " is greyed out and cannot be selected.
At @ext:espressif.esp-idf-extension there is not an option to choose a different version.
I wish to roll back to 1.02; any suggestions would be most welcome. Thanks.
bunfight
Postby bunfight » Fri May 14, 2021 10:08 am
I Uninstalled 1.03 then installed 1.02 from https://github.com/espressif/vscode-esp ... tag/v1.0.2. Project now builds and flashes OK.
ESP-IDF now highlights "update to 1.03" but "Install Another Version" is not greyed out and many previous versions can be selected whereas this option was unavailable when 1.03 was installed.
Awsmtek
Postby Awsmtek » Mon Apr 21, 2025 2:05 am
Hello!
I had the same issue.
The solution that I found is to install ninja (it was absent):
sudo apt install ninja-build
If you're using Windows, please follow installation guide from official ninja website.
Hope it'll help .
Users browsing this forum: Qwantbot, YisouSpider and 1 guest
