If I connected ESP C3 pin 18 D- and pin 19 D+ to USB and UBS 5V+ to convertor on the board. And with such a connection, the board should be recognized as an automatic COM port without additional drivers or something else?If you mean the USB-serial-JTAG device, it should simply show up as another serial port; you'd flash in the same way as you would over a 'standard' USB to serial adapter. (Note under Linux and macOS the device nodes may be named different, e.g. /dev/ttyACM0 instead of /dev/ttyUSB0)
ESP32-C3 Mini Devkit: Configure for Built in USB JTAG?
Re: ESP32-C3 Mini Devkit: Configure for Built in USB JTAG?
Yes. (Unless you have an app in flash that reconfigures GPIO18 or GPIO19. In that case, you want to tie GPIO9 low when you reset the chip to force the chip into bootloader mode so you can overwrite that app)
I'm facing the same issue.Yes. (Unless you have an app in flash that reconfigures GPIO18 or GPIO19. In that case, you want to tie GPIO9 low when you reset the chip to force the chip into bootloader mode so you can overwrite that app)
Using a ESP32-C3-MINI devkit, I was able to download and debug my code using a USB cable without a problem (but USB-to-serial bridge was in place).
Then I placed a ESP32-C3-MINI module directly on my custom board, without a USB-to-serial bridge, and brought USB-P/USB-N lines directly to a USB connector on the board. The ESP32-C3-MINI module is brand-new, so probably has default firmware from the factory.
When power is applied to ESP-C3-MINI, the USB device enumerates as a serial port - but then keeps disappearing and re-appearing again.
I followed your suggestion to pull GPIO9 low. This solved the re-numeration problem (virtual COM port is always present). However, I am unable to download firmware to the board from Visual Studio Code. VS Code hangs at this point:
esptool.py v3.1-dev
Serial port COM7
Connecting...
Chip is unknown ESP32-C3 (revision 3)
Features: Wi-Fi
Crystal is 40MHz
MAC: 34:b4:72:76:2d:a8
Uploading stub...
Running stub...Thanks!
This is known behaviour... without firmware, the RTC watchdog resets the chip every so often. In our testing, it was generally possible to flash the chip anyway: as soon as the chip enumerates and is put into download mode, the resets stop. You didn't manage to get this far?When power is applied to ESP-C3-MINI, the USB device enumerates as a serial port - but then keeps disappearing and re-appearing again.
Hm, that is odd. In the esp-idf configuration (Menuconfig, not sure what VS calls it), under 'serial flasher config', can you enable 'Disable download stub', see if that works?
I tried that, but it didn't fix the problem - same behavior, hangs at "Running stub...":In the esp-idf configuration (Menuconfig, not sure what VS calls it), under 'serial flasher config', can you enable 'Disable download stub', see if that works?
esptool.py v3.1-dev
Serial port COM9
Connecting...
Features: Wi-Fi
Crystal is 40MHz
MAC: 7c:df:a1:61:ef:7c
Uploading stub...
Running stub...
Has anyone actually used the built-in USB JTAG on C3?
I have not touched OpenOCD configuration at all - with USB-to-serial bridge everything worked out of the box. But I'm wondering if it's necessary to reconfigure OpenOCD?
When development kit is configured with USB-to-serial bridge, output is as follows:
Also, I noticed that on Windows, the Virtual COM port driver is different when I'm using C3's internal USB JTAG vs. USB-to-serial bridge: when USB-to-serial bridge is used, Windows uses "silabser.sys"... but when C3's internal USB JTAG is used, the driver is "usbser.sys". Could that be an issue?
esptool.py v3.1-dev
Serial port COM8
Connecting....
Features: Wi-Fi
Crystal is 40MHz
MAC: 7c:df:a1:61:f0:30
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
Configuring flash size...
Auto-detected Flash size: 4MB
Flash will be erased from 0x00010000 to 0x00090fff...
Flash will be erased from 0x00000000 to 0x00004fff...
Compressed 527856 bytes to 283343...
Wrote 527856 bytes (283343 compressed) at 0x00010000 in 8.7 seconds (effective 484.7 kbit/s)...
Hash of data verified.
Flash params set to 0x022f
Compressed 18944 bytes to 11308...
Wrote 18944 bytes (11308 compressed) at 0x00000000 in 0.6 seconds (effective 268.5 kbit/s)...
Compressed 3072 bytes to 103...
Wrote 3072 bytes (103 compressed) at 0x00008000 in 0.1 seconds (effective 351.9 kbit/s)...
Hash of data verified.Also, I noticed that on Windows, the Virtual COM port driver is different when I'm using C3's internal USB JTAG vs. USB-to-serial bridge: when USB-to-serial bridge is used, Windows uses "silabser.sys"... but when C3's internal USB JTAG is used, the driver is "usbser.sys". Could that be an issue?
It shouldn't matter. I still think it's odd that the 'do not use stub' thing does not propagate... can you clean your project ('esp-idf fullclean' or simply delete the build directory) and try again?
I deleted the build directory, then checked build/config/sdkconfig.h, and this line is there:It shouldn't matter. I still think it's odd that the 'do not use stub' thing does not propagate... can you clean your project ('esp-idf fullclean' or simply delete the build directory) and try again?
#define CONFIG_ESPTOOLPY_NO_STUB 1Re: ESP32-C3 Mini Devkit: Configure for Built in USB JTAG?
I finally got it to work, but it's not a hardware issue.
Something was not configured right in the ESP-IDF plugin. I ended up uninstalling ESP-IDF, uninstalling VS Code and removing all traces of it from the hard drive (installed plugins, etc.) - and then reinstalling again.
Also had some trouble reinstalling Espressif IDF plugin for Visual Studio:
With version 1.3.0, plugin configuration doesn't work, as I kept getting the "restart Visual Studio Code and run this wizard again" message (no way to configure plugin in the VS Code IDE - maybe it can be done manually, but I don't know how to do it).
So after installing plugin 1.2.0, I was able to configure it successfully, and then flashing the chip via built-in USB also worked without any additional changes.
Glad that you made it work! Strange that a software quirk affected the upload process, though.
Users browsing this forum: Bing [Bot], Qwantbot and 2 guests
