Won't run on battery power
Re: Won't run on battery power
Postby Sprite » Mon Feb 07, 2022 1:22 am
I think you are right. The normal qualified fast-charger should active like this.
However, the fast-charger in china maybe not very reliable. One of my Bluetooth ear-pods, the package said that do not use the fast charger. I think issues that fast-charger damage ear-pods often happens.
Hm, that's fair enough. Guess it's good advice to not use cheapo USB chargers, fast or not to begin with :)
Stumpy_L
Postby Stumpy_L » Mon Feb 07, 2022 11:27 am
I installed the AMS1117 with a 330 uF cap across the output and it still doesn't work. Seems like it should, maybe it has to do with this ESP32 board I have some others on order. I do notice that the red LED flickers a bit, maybe as it's drawing current it dips the power although when I put a meter on the 3.3v it's steady. I did have this working, not with the battery power, with a Arduino Nano. I use a RTC for the sleep mode. I'm going to try getting that to work again too see if that will work using the battery. It won't have the WiFi for ThingSpeak but I could connect the home base unit for that.
John
Users browsing this forum: ChatGPT-User, Qwantbot and 2 guests
