Page 2 of 2
Re: ESP32 UART Hardware Serial Ports Help
Posted: Thu Jul 14, 2022 12:59 am
by rodmcm
I use Pin 34 for RXD-0 35 for TXD-0 27 for RXD-2 28 for TXD-2
Works fine
Have you seen this?
Posted: Thu Jul 14, 2022 1:58 am
by kpin404
#include <HardwareSerial.h>
HardwareSerial SerialPort(1); // use UART1
void setup()
SerialPort.begin(15200, SERIAL_8N1, 4, 2);
I have connected GPS module to UART1 GPIO9 and GPIO10 and tried to run the code for UART1 in the tutorial as you mentioned above and it switched-on the on board LED as its internally connected to PIN2 of the board and no GPS data in the serial monitor at all. Thanks.
Posted: Thu Jul 14, 2022 4:07 am
by kpin404
Works fine
Have you seen this?
You mean using GPIO pins, as GPIO pin numbering is different than board's actual pin numbers? Thanks.
Posted: Thu Jul 14, 2022 7:16 am
by Momin786
Works fine
Have you seen this?
GPIO9 and GPIO10 do not work with UART1 because they are internally connected to flash. You can other pins.
Posted: Thu Jul 14, 2022 7:25 am
by kpin404
Works fine
Have you seen this?
Okay! let me try with using Pin 34 for RXD-0 35 for TXD-0 27 for RXD-2 28 for TXD-2. Thanks.
Posted: Fri Jul 15, 2022 2:33 am
by Sprite
GPIO34 and up are input-only so they won't work as TX. You can still use them for RX, though (but do note that they also do not support internal pullups/pulldowns)
Posted: Fri Jul 15, 2022 2:41 am
by kpin404
Fixed the issue. I have remapped and tested with all the mentioned pins here i.e. 2,4,13, 25, 26.27,28,32,33,34,35 for ESP32 hardware UART1 serial port use successfully. Thank you all here in the discussion for providing their valuable support to me on this. Thanking you.
