Ok, I ended up solving this rookie mistake.
Had to do with my local implementation of the source files with the arduino ide that I am using.
I found out the real directory that was used, included the file properly and it worked.
Ping from ESP32
Re: Ping from ESP32
I'm trying to use ping API of ESP8266_RTOS_SDK but there is a problem with ping_init() function, i'm including two libs ping.h and esp_ping.h. The functions of esp_ping are working fine, but the linker do not recognize ping_init of ping.h calling: " undefined reference to `ping_init' " when i try to make the project.
Someone could help me?
fruityTomatoe
Re: Ping from ESP32
I am also seeing the undefined reference to `ping_init' " issue. Did you have a solution?I'm trying to use ping API of ESP8266_RTOS_SDK but there is a problem with ping_init() function, i'm including two libs ping.h and esp_ping.h. The functions of esp_ping are working fine, but the linker do not recognize ping_init of ping.h calling: " undefined reference to `ping_init' " when i try to make the project.
Re: Ping from ESP32
try to include "ping/ping.h".
The ping.h path is not in the compiler paths configuration.
Mirko
Mirko
nopnop2002
- Contact:
Re: Ping from ESP32
Finally I succeeded in pinging using ESP-IDE.
It is published here.
https://github.com/nopnop2002/esp-idf-ping
Re: Ping from ESP32
Frustrating how esp-idf examples are so overcomplicated. Examples provided in this thread from years ago do not work, as ping_init() is deprecated. Here's a nice simple method to ping 8.8.8.8 with latest IDF, and utilizing the overcomplicated example from the idf documentation here: https://docs.espressif.com/projects/esp ... _echo.html
Don't forget to connect to wifi/ethernet FIRST!
static void on_ping_success(esp_ping_handle_t hdl, void *args)
// optionally, get callback arguments
// const char* str = (const char*) args;
// printf("%s\r\n", str); // "foo"
uint8_t ttl;
uint16_t seqno;
uint32_t elapsed_time, recv_len;
ip_addr_t target_addr;
esp_ping_get_profile(hdl, ESP_PING_PROF_SEQNO, &seqno, sizeof(seqno));
esp_ping_get_profile(hdl, ESP_PING_PROF_TTL, &ttl, sizeof(ttl));
esp_ping_get_profile(hdl, ESP_PING_PROF_IPADDR, &target_addr, sizeof(target_addr));
esp_ping_get_profile(hdl, ESP_PING_PROF_SIZE, &recv_len, sizeof(recv_len));
esp_ping_get_profile(hdl, ESP_PING_PROF_TIMEGAP, &elapsed_time, sizeof(elapsed_time));
printf("%d bytes from %s icmp_seq=%d ttl=%d time=%d ms\n",
recv_len, inet_ntoa(target_addr.u_addr.ip4), seqno, ttl, elapsed_time);
ESP_LOGW("pingSuccess", "");
static void on_ping_timeout(esp_ping_handle_t hdl, void *args)
uint16_t seqno;
printf("From %s icmp_seq=%d timeout\n", inet_ntoa(target_addr.u_addr.ip4), seqno);
ESP_LOGW("pingTimeout", "");
static void on_ping_end(esp_ping_handle_t hdl, void *args)
uint32_t transmitted;
uint32_t received;
uint32_t total_time_ms;
esp_ping_get_profile(hdl, ESP_PING_PROF_REQUEST, &transmitted, sizeof(transmitted));
esp_ping_get_profile(hdl, ESP_PING_PROF_REPLY, &received, sizeof(received));
esp_ping_get_profile(hdl, ESP_PING_PROF_DURATION, &total_time_ms, sizeof(total_time_ms));
printf("%d packets transmitted, %d received, time %dms\n", transmitted, received, total_time_ms);
void app_main(void)
//CONNECT TO WIFI FIRST!
//destination
ip4_addr_t gw;
gw.addr = ipaddr_addr("8.8.8.8");
esp_ping_config_t ping_config = ESP_PING_DEFAULT_CONFIG();
ip_addr_t ping_target;
ping_target.u_addr.ip4 = gw;
ping_config.target_addr = ping_target;
ping_config.count = 5;
ping_config.interval_ms = 5000;
ping_config.timeout_ms = 1000;
/* set callback functions */
esp_ping_callbacks_t cbs;
cbs.on_ping_success = on_ping_success;
cbs.on_ping_timeout = on_ping_timeout;
cbs.on_ping_end = on_ping_end;
//cbs.cb_args = "foo"; // arguments that will feed to all callback functions, can be NULL
//cbs.cb_args = eth_event_group;
esp_ping_handle_t ping;
esp_ping_new_session(&ping_config, &cbs, &ping);
esp_ping_start(ping);
maddogmaycry
Re: Ping from ESP32
#include "lwip/err.h"
#include "lwip/sockets.h"
#include "lwip/sys.h"
#include <lwip/netdb.h>
#include "lwip/api.h"
#include "ping/ping_sock.h"
static void test_on_ping_success(esp_ping_handle_t hdl, void *args){
uint8_t ttl;
uint16_t seqno;
esp_ping_stop(hdl);
esp_ping_delete_session(hdl);
static void test_on_ping_timeout(esp_ping_handle_t hdl, void *args){
uint16_t seqno;
esp_ping_stop(hdl);
static void test_on_ping_end(esp_ping_handle_t hdl, void *args){
uint32_t received;
esp_ping_stop(hdl);
void ping(const char * host){
struct hostent *he;
he = netconn_gethostbyname(host, &target_addr);
if(he == 0){
esp_ping_config_t ping_config = {
.interval_ms = 1000,
.timeout_ms = 1000,
.data_size = 64,
.tos = 0,
.task_stack_size = 2048,
.task_prio = 2,
.interface = 0,
.target_addr = target_addr,
.count = 5
cbs.on_ping_success = test_on_ping_success;
cbs.on_ping_timeout = test_on_ping_timeout;
cbs.on_ping_end = test_on_ping_end;
}Code: Select all
ping("any_host_you_want_or_ip");
//If dns server not response ping newer been happend
ping("www.google.com");
//Ping regular ip v4 ip
ping("192.168.1.1");
//If you want ip4_addr_t struct, then convert it to char[]
const char * ip = (char*)ip4addr_ntoa(&ip_info->ip);
ping(ip);
sara_patel
Re: Ping from ESP32
Hi can u provide a code for sending ping on all interfaces?
I tried adding interface index but that gives be error on Ping handle being NUll
