VSC installation BUG
chegewara
Re: VSC installation BUG
Postby chegewara » Thu Dec 08, 2022 1:41 am
I did read, and i also checked (not very thorough, but enough) you latest logs.
When you solve this issue it should be fine, or maybe new errors will popup:
C:/esp-idf/components/log/include/esp_log.h:265:27: error: format '%d' expects argument of type 'int', but argument 7 has type 'uint32_t' {aka 'long unsigned int'} [-Werror=format=]
In all previous versions the components compiled correctly.
Yes, it compiled in v4.x.x, but from v5.0 some things changed, especialy how you print log numbers.
This is no longer valid:
 '%d'
All your errors, or most of them, are related to this issue:
https://github.com/espressif/esp-idf/issues/9511
Of course you may ignore my answers if you wish.
Baldhead
Postby Baldhead » Thu Dec 08, 2022 2:07 pm
@cheguewara,
I've already told you, that the problem is mdns library.
Mdns library is esp-idf fork.
If i change all local mdns library, when i update the esp-idf again, the problem turns again.
And even before i run "idf.py add-dependency espressif/mdns==1.0.3", there were no esp_log problems, and my components librarys were not added in the compilation.
For me, the problem is another one.
Baldhead
Postby Baldhead » Thu Dec 08, 2022 2:53 pm
@cheguewara,
How to solve this problem in this issue "https://github.com/espressif/esp-idf/issues/9511" ?
Component directory /home/chegewara/esp/master/components/asio does not contain a CMakeLists.txt file. No component will be added
Baldhead
Postby Baldhead » Thu Dec 08, 2022 5:26 pm
@cheguewara,
Compilation without add mdns lib ( without run "idf.py add-dependency espressif/mdns==1.0.3" ).
Executing task: cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DESP_PLATFORM=1 -B c:\esp32-Proj\WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022\build -S c:\esp32-Proj\WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022
-- Found Git: C:/.espressif/tools/idf-git/2.30.1/cmd/git.exe (found version "2.30.1.windows.1")
-- Component directory C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/communication does not contain a CMakeLists.txt file. No component will be added
-- Component directory C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui does not contain a CMakeLists.txt file. No component will be added
-- The C compiler identification is GNU 11.2.0
-- The CXX compiler identification is GNU 11.2.0
-- Found assembler: C:/.espressif/tools/xtensa-esp32s3-elf/esp-2022r1-11.2.0/xtensa-esp32s3-elf/bin/xtensa-esp32s3-elf-gcc.exe
-- Check for working C compiler: C:/.espressif/tools/xtensa-esp32s3-elf/esp-2022r1-11.2.0/xtensa-esp32s3-elf/bin/xtensa-esp32s3-elf-gcc.exe - skipped
-- Check for working CXX compiler: C:/.espressif/tools/xtensa-esp32s3-elf/esp-2022r1-11.2.0/xtensa-esp32s3-elf/bin/xtensa-esp32s3-elf-g++.exe - skipped
-- Project is not inside a git repository, or git repository has no commits; will not use 'git describe' to determine PROJECT_VER.
-- Building ESP-IDF components for target esp32s3
CMake Error at C:/esp-idf/tools/cmake/build.cmake:245 (message):
  Failed to resolve component 'mdns'.
  C:/esp-idf/tools/cmake/build.cmake:281 (__build_resolve_and_add_req)
  C:/esp-idf/tools/cmake/build.cmake:574 (__build_expand_requirements)
  C:/esp-idf/tools/cmake/project.cmake:440 (idf_build_process)
  CMakeLists.txt:17 (project)
See also "C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/build/CMakeFiles/CMakeOutput.log".
 *  The terminal process "C:\Windows\System32\WindowsPowerShell\v1.0\powershell.exe -Command cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DESP_PLATFORM=1 -B c:\esp32-Proj\WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022\build -S c:\esp32-Proj\WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022" terminated with exit code: 1.
Baldhead
Postby Baldhead » Thu Dec 08, 2022 7:14 pm
I run this now: "idf.py add-dependency espressif/mdns^1.0.7" and the mdns lib format logs errors disappeared.
I also fixed some format logs errors from my files and now the compilation log stayed like this:
Executing task: cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DESP_PLATFORM=1 -B c:\esp32-Proj\WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022\build -S c:\esp32-Proj\WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022 -B c:\esp32-Proj\WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022\build -S c:\esp32-Proj\WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022 -B c:\esp32-Proj\WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022\build -S c:\esp32-Proj\WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022 -B c:\esp32-Proj\WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022\build -S c:\esp32-Proj\WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022 -B c:\esp32-Proj\WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022\build -S c:\esp32-Proj\WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022 -B c:\esp32-Proj\WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022\build -S c:\esp32-Proj\WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022 -B c:\esp32-Proj\WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022\build -S c:\esp32-Proj\WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022 -B c:\esp32-Proj\WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022\build -S c:\esp32-Proj\WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022 -B c:\esp32-Proj\WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022\build -S c:\esp32-Proj\WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022 -B c:\esp32-Proj\WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022\build -S c:\esp32-Proj\WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022
Processing 2 dependencies:
[1/2] espressif/mdns (1.0.7)
[2/2] idf (5.0.0)
-- Project sdkconfig file C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/sdkconfig
-- Looking for sys/types.h
-- Looking for sys/types.h - found
-- Looking for stdint.h
-- Looking for stdint.h - found
-- Looking for stddef.h
-- Looking for stddef.h - found
-- Check size of time_t
-- Check size of time_t - done
-- Found Python3: C:/.espressif/python_env/idf5.0_py3.8_env/Scripts/python.exe (found version "3.8.7") found components: Interpreter
-- Performing Test C_COMPILER_SUPPORTS_WFORMAT_SIGNEDNESS
-- Performing Test C_COMPILER_SUPPORTS_WFORMAT_SIGNEDNESS - Success
-- App "wss_server" version: 1
-- Adding linker script C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/build/esp-idf/esp_system/ld/memory.ld
-- Adding linker script C:/esp-idf/components/esp_system/ld/esp32s3/sections.ld.in
-- Adding linker script C:/esp-idf/components/esp_rom/esp32s3/ld/esp32s3.rom.ld
-- Adding linker script C:/esp-idf/components/esp_rom/esp32s3/ld/esp32s3.rom.api.ld
-- Adding linker script C:/esp-idf/components/esp_rom/esp32s3/ld/esp32s3.rom.libgcc.ld
-- Adding linker script C:/esp-idf/components/esp_rom/esp32s3/ld/esp32s3.rom.newlib.ld
-- Adding linker script C:/esp-idf/components/esp_rom/esp32s3/ld/esp32s3.rom.version.ld
-- Adding linker script C:/esp-idf/components/soc/esp32s3/ld/esp32s3.peripherals.ld
-- Components: app_trace app_update bootloader bootloader_support bt cmock console cxx driver drv efuse esp-tls esp_adc esp_app_format esp_common esp_eth esp_event esp_gdbstub esp_hid esp_http_client esp_http_server esp_https_ota esp_https_server esp_hw_support esp_lcd esp_local_ctrl esp_netif esp_partition esp_phy esp_pm esp_psram esp_ringbuf esp_rom esp_system esp_timer esp_wifi espcoredump espressif__mdns esptool_py fatfs freertos global_conf hal heap http_parser idf_test ieee802154 json log lvgl lwip main mbedtls mqtt my_wifi my_wss_server newlib nvs_flash openthread partition_table perfmon protobuf-c protocomm pthread sdmmc soc spi_flash spiffs tcp_transport touch_element ui_images ulp unity usb vfs wear_levelling wifi_provisioning wpa_supplicant xtensa
-- Component paths: C:/esp-idf/components/app_trace C:/esp-idf/components/app_update C:/esp-idf/components/bootloader C:/esp-idf/components/bootloader_support C:/esp-idf/components/bt C:/esp-idf/components/cmock C:/esp-idf/components/console C:/esp-idf/components/cxx C:/esp-idf/components/driver C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/drv C:/esp-idf/components/efuse C:/esp-idf/components/esp-tls C:/esp-idf/components/esp_adc C:/esp-idf/components/esp_app_format C:/esp-idf/components/esp_common C:/esp-idf/components/esp_eth C:/esp-idf/components/esp_event C:/esp-idf/components/esp_gdbstub C:/esp-idf/components/esp_hid C:/esp-idf/components/esp_http_client C:/esp-idf/components/esp_http_server C:/esp-idf/components/esp_https_ota C:/esp-idf/components/esp_https_server C:/esp-idf/components/esp_hw_support C:/esp-idf/components/esp_lcd C:/esp-idf/components/esp_local_ctrl C:/esp-idf/components/esp_netif C:/esp-idf/components/esp_partition C:/esp-idf/components/esp_phy C:/esp-idf/components/esp_pm C:/esp-idf/components/esp_psram C:/esp-idf/components/esp_ringbuf C:/esp-idf/components/esp_rom C:/esp-idf/components/esp_system C:/esp-idf/components/esp_timer C:/esp-idf/components/esp_wifi C:/esp-idf/components/espcoredump C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/managed_components/espressif__mdns C:/esp-idf/components/esptool_py C:/esp-idf/components/fatfs C:/esp-idf/components/freertos C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/global_conf C:/esp-idf/components/hal C:/esp-idf/components/heap C:/esp-idf/components/http_parser C:/esp-idf/components/idf_test C:/esp-idf/components/ieee802154 C:/esp-idf/components/json C:/esp-idf/components/log C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/lvgl C:/esp-idf/components/lwip C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/main C:/esp-idf/components/mbedtls C:/esp-idf/components/mqtt C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/communication/my_wifi C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/communication/my_wss_server C:/esp-idf/components/newlib C:/esp-idf/components/nvs_flash C:/esp-idf/components/openthread C:/esp-idf/components/partition_table C:/esp-idf/components/perfmon C:/esp-idf/components/protobuf-c C:/esp-idf/components/protocomm C:/esp-idf/components/pthread C:/esp-idf/components/sdmmc C:/esp-idf/components/soc C:/esp-idf/components/spi_flash C:/esp-idf/components/spiffs C:/esp-idf/components/tcp_transport C:/esp-idf/components/touch_element C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/ui_images C:/esp-idf/components/ulp C:/esp-idf/components/unity C:/esp-idf/components/usb C:/esp-idf/components/vfs C:/esp-idf/components/wear_levelling C:/esp-idf/components/wifi_provisioning C:/esp-idf/components/wpa_supplicant C:/esp-idf/components/xtensa
-- Configuring done
-- Generating done
-- Build files have been written to: C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/build
 *  Executing task: ninja
[12/990] Generating ../../partition_table/partition-table.bin
Partition table binary generated. Contents:
# ESP-IDF Partition Table
nvs,data,nvs,0x9000,24K,
phy_init,data,phy,0xf000,4K,
factory,app,factory,0x10000,1M,
[523/990] Performing configure step for 'bootloader'
-- App "bootloader" version: v5.0
-- Adding linker script C:/esp-idf/components/bootloader/subproject/main/ld/esp32s3/bootloader.ld
-- Adding linker script C:/esp-idf/components/bootloader/subproject/main/ld/esp32s3/bootloader.rom.ld
-- Components: bootloader bootloader_support efuse esp_app_format esp_common esp_hw_support esp_rom esp_system esptool_py freertos hal log main micro-ecc newlib partition_table soc spi_flash xtensa
-- Component paths: C:/esp-idf/components/bootloader C:/esp-idf/components/bootloader_support C:/esp-idf/components/efuse C:/esp-idf/components/esp_app_format C:/esp-idf/components/esp_common C:/esp-idf/components/esp_hw_support C:/esp-idf/components/esp_rom C:/esp-idf/components/esp_system C:/esp-idf/components/esptool_py C:/esp-idf/components/freertos C:/esp-idf/components/hal C:/esp-idf/components/log C:/esp-idf/components/bootloader/subproject/main C:/esp-idf/components/bootloader/subproject/components/micro-ecc C:/esp-idf/components/newlib C:/esp-idf/components/partition_table C:/esp-idf/components/soc C:/esp-idf/components/spi_flash C:/esp-idf/components/xtensa
-- Configuring done
-- Generating done
-- Build files have been written to: C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/build/bootloader
[621/990] Performing build step for 'bootloader'
[1/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/lldesc.c.obj
[2/106] Building C object esp-idf/xtensa/CMakeFiles/__idf_xtensa.dir/xt_trax.c.obj
[3/106] Building C object esp-idf/xtensa/CMakeFiles/__idf_xtensa.dir/eri.c.obj
[4/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/gpio_periph.c.obj
[5/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/gdma_periph.c.obj
[6/106] Generating project_elf_src_esp32s3.c
[7/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/dedic_gpio_periph.c.obj
[8/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/i2c_periph.c.obj
[9/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/sdm_periph.c.obj
[10/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/dport_access_common.c.obj
[11/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/adc_periph.c.obj
[12/106] Building C object CMakeFiles/bootloader.elf.dir/project_elf_src_esp32s3.c.obj
[13/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/ledc_periph.c.obj
[14/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/lcd_periph.c.obj
[15/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/interrupts.c.obj
[16/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/mcpwm_periph.c.obj
[17/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/i2s_periph.c.obj
[18/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/pcnt_periph.c.obj
[19/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/rtc_io_periph.c.obj
[20/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/sdmmc_periph.c.obj
[21/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/spi_periph.c.obj
[22/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/timer_periph.c.obj
[23/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/rmt_periph.c.obj
[24/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/sdio_slave_periph.c.obj
[25/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/touch_sensor_periph.c.obj
[26/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/temperature_sensor_periph.c.obj
[27/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/usb_otg_periph.c.obj
[28/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/usb_periph.c.obj
[29/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/uart_periph.c.obj
[30/106] Building C object esp-idf/hal/CMakeFiles/__idf_hal.dir/esp32s3/efuse_hal.c.obj
[31/106] Building C object esp-idf/hal/CMakeFiles/__idf_hal.dir/mmu_hal.c.obj
[32/106] Building C object esp-idf/hal/CMakeFiles/__idf_hal.dir/cache_hal.c.obj
[33/106] Building C object esp-idf/hal/CMakeFiles/__idf_hal.dir/efuse_hal.c.obj
[34/106] Building C object esp-idf/hal/CMakeFiles/__idf_hal.dir/mpu_hal.c.obj
[35/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_clock_init.c.obj
[36/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_random.c.obj
[37/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_mem.c.obj
[38/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/bootloader_flash/src/bootloader_flash.c.obj
[39/106] Building C object esp-idf/esp_app_format/CMakeFiles/__idf_esp_app_format.dir/esp_app_desc.c.obj
[40/106] Building C object esp-idf/micro-ecc/CMakeFiles/__idf_micro-ecc.dir/uECC_verify_antifault.c.obj
[41/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_common_loader.c.obj
[42/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_common.c.obj
[43/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/bootloader_flash/src/bootloader_flash_config_esp32s3.c.obj
[44/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_efuse.c.obj
[45/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_clock_loader.c.obj
[46/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/bootloader_flash/src/flash_qio_mode.c.obj
[47/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_init.c.obj
[48/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_random_esp32s3.c.obj
[49/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/flash_encrypt.c.obj
[50/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/esp_image_format.c.obj
[51/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/secure_boot.c.obj
[52/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_utility.c.obj
[53/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/flash_partitions.c.obj
[54/106] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/esp32s3/esp_efuse_table.c.obj
[55/106] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/esp32s3/esp_efuse_fields.c.obj
[56/106] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/esp32s3/esp_efuse_rtc_calib.c.obj
[57/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/esp32s3/bootloader_soc.c.obj
[58/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_console_loader.c.obj
[59/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_panic.c.obj
[60/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/esp32s3/bootloader_sha.c.obj
[61/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_console.c.obj
[62/106] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/esp32s3/esp_efuse_utility.c.obj
[63/106] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32s3/chip_info.c.obj
[64/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/esp32s3/bootloader_esp32s3.c.obj
[65/106] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32s3/rtc_pm.c.obj
[66/106] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32s3/rtc_time.c.obj
[67/106] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32s3/rtc_sleep.c.obj
[68/106] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/src/esp_efuse_fields.c.obj
[69/106] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/src/esp_efuse_api.c.obj
[70/106] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/src/esp_efuse_utility.c.obj
[71/106] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/esp_memory_utils.c.obj
[72/106] Building C object esp-idf/esp_system/CMakeFiles/__idf_esp_system.dir/esp_err.c.obj
[73/106] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/cpu.c.obj
[74/106] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/src/efuse_controller/keys/with_key_purposes/esp_efuse_api_key.c.obj
[75/106] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32s3/rtc_clk_init.c.obj
[76/106] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32s3/rtc_init.c.obj
[77/106] Building C object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_sys.c.obj
[78/106] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32s3/rtc_clk.c.obj
[79/106] Building C object esp-idf/esp_common/CMakeFiles/__idf_esp_common.dir/src/esp_err_to_name.c.obj
[80/106] Building C object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_crc.c.obj
[81/106] Building C object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_uart.c.obj
[82/106] Building C object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_spiflash.c.obj
[83/106] Building C object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_regi2c.c.obj
[84/106] Building C object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_efuse.c.obj
[85/106] Building ASM object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_longjmp.S.obj
[86/106] Building C object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_systimer.c.obj
[87/106] Building C object esp-idf/log/CMakeFiles/__idf_log.dir/log_buffers.c.obj
[88/106] Building C object esp-idf/log/CMakeFiles/__idf_log.dir/log.c.obj
[89/106] Building C object esp-idf/log/CMakeFiles/__idf_log.dir/log_noos.c.obj
[90/106] Building C object esp-idf/main/CMakeFiles/__idf_main.dir/bootloader_start.c.obj
[91/106] Linking C static library esp-idf\log\liblog.a
[92/106] Linking C static library esp-idf\esp_rom\libesp_rom.a
[93/106] Linking C static library esp-idf\esp_common\libesp_common.a
[94/106] Linking C static library esp-idf\esp_hw_support\libesp_hw_support.a
[95/106] Linking C static library esp-idf\esp_system\libesp_system.a
[96/106] Linking C static library esp-idf\efuse\libefuse.a
[97/106] Linking C static library esp-idf\bootloader_support\libbootloader_support.a
[98/106] Linking C static library esp-idf\esp_app_format\libesp_app_format.a
[99/106] Linking C static library esp-idf\hal\libhal.a
[100/106] Linking C static library esp-idf\micro-ecc\libmicro-ecc.a
[101/106] Linking C static library esp-idf\soc\libsoc.a
[102/106] Linking C static library esp-idf\xtensa\libxtensa.a
[103/106] Linking C static library esp-idf\main\libmain.a
[104/106] Linking C executable bootloader.elf
[105/106] Generating binary image from built executable
esptool.py v4.4
Creating esp32s3 image...
Merged 1 ELF section
Successfully created esp32s3 image.
Generated C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/build/bootloader/bootloader.bin
[106/106] cmd.exe /C "cd /D C:\esp32-Proj\WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022\build\bootloader\esp-idf\esptool_py && C:\.espressif\python_env\idf5.0_py3.8_env\Scripts\python.exe C:/esp-idf/components/partition_table/check_sizes.py --offset 0x8000 bootloader 0x0 C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/build/bootloader/bootloader.bin"
Bootloader binary size 0x5150 bytes. 0x2eb0 bytes (36%) free.
[903/990] Building C object esp-idf/lvgl/CMakeFiles/__idf_lvgl.dir/src/lv_hal/lv_hal_tick.c.obj
C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/lvgl/src/lv_hal/lv_hal_tick.c:51:1: warning: ignoring attribute 'section (".iram1.1")' because it conflicts with previous 'section (".iram1.0")' [-Wattribute
   51 | {
In file included from C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/lvgl/src/lv_hal/lv_hal_tick.c:13:
C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/lvgl/src/lv_hal/include/lv_hal_tick.h:43:28: note: previous declaration here
   43 | LV_ATTRIBUTE_TICK_INC void lv_tick_inc(uint32_t tick_period);
[970/990] Building C object esp-idf/main/CMakeFiles/__idf_main.dir/src/my_app.c.obj
C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/main/src/my_app.c:394:1: warning: ignoring attribute 'section (".iram1.4")' because it conflicts with previous 'section (".iram1.3")' [-Wattributes]
  394 | {
C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/main/src/my_app.c:36:23: note: previous declaration here
   36 | static void IRAM_ATTR lv_tick_task();
C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/main/src/my_app.c:538:13: warning: 'toggle_manually' defined but not used [-Wunused-function]
  538 | static void toggle_manually()
[973/990] Building C object esp-idf/my_wss_server/CMakeFiles/__idf_my_wss_server.dir/src/my_login.c.obj
FAILED: esp-idf/my_wss_server/CMakeFiles/__idf_my_wss_server.dir/src/my_login.c.obj
C:\.espressif\tools\xtensa-esp32s3-elf\esp-2022r1-11.2.0\xtensa-esp32s3-elf\bin\xtensa-esp32s3-elf-gcc.exe -DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\" -DUNITY_INCLUDE_CONFIG_H -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/build/config -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/communication/my_wss_server/src/include -IC:/esp-idf/components/newlib/platform_include -IC:/esp-idf/components/freertos/FreeRTOS-Kernel/include -IC:/esp-idf/components/freertos/esp_additions/include/freertos -IC:/esp-idf/components/freertos/FreeRTOS-Kernel/portable/xtensa/include -IC:/esp-idf/components/freertos/esp_additions/include -IC:/esp-idf/components/esp_hw_support/include -IC:/esp-idf/components/esp_hw_support/include/soc -IC:/esp-idf/components/esp_hw_support/include/soc/esp32s3 -IC:/esp-idf/components/esp_hw_support/port/esp32s3/. -IC:/esp-idf/components/esp_hw_support/port/esp32s3/private_include -IC:/esp-idf/components/heap/include -IC:/esp-idf/components/log/include -IC:/esp-idf/components/soc/include -IC:/esp-idf/components/soc/esp32s3/. -IC:/esp-idf/components/soc/esp32s3/include -IC:/esp-idf/components/hal/esp32s3/include -IC:/esp-idf/components/hal/include -IC:/esp-idf/components/hal/platform_port/include -IC:/esp-idf/components/esp_rom/include -IC:/esp-idf/components/esp_rom/include/esp32s3 -IC:/esp-idf/components/esp_rom/esp32s3 -IC:/esp-idf/components/esp_common/include -IC:/esp-idf/components/esp_system/include -IC:/esp-idf/components/esp_system/port/soc -IC:/esp-idf/components/esp_system/port/include/private -IC:/esp-idf/components/xtensa/include -IC:/esp-idf/components/xtensa/esp32s3/include -IC:/esp-idf/components/lwip/include -IC:/esp-idf/components/lwip/include/apps -IC:/esp-idf/components/lwip/include/apps/sntp -IC:/esp-idf/components/lwip/lwip/src/include -IC:/esp-idf/components/lwip/port/esp32/include -IC:/esp-idf/components/lwip/port/esp32/include/arch -IC:/esp-idf/components/esp_http_server/include -IC:/esp-idf/components/http_parser -IC:/esp-idf/components/esp-tls -IC:/esp-idf/components/esp-tls/esp-tls-crypto -IC:/esp-idf/components/mbedtls/port/include -IC:/esp-idf/components/mbedtls/mbedtls/include -IC:/esp-idf/components/mbedtls/mbedtls/library -IC:/esp-idf/components/mbedtls/esp_crt_bundle/include -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/managed_components/espressif__mdns/include -IC:/esp-idf/components/console -IC:/esp-idf/components/vfs/include -IC:/esp-idf/components/esp_netif/include -IC:/esp-idf/components/esp_event/include -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/communication/my_wifi/src/include -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/main/src/include -IC:/esp-idf/components/esp_ringbuf/include -IC:/esp-idf/components/efuse/include -IC:/esp-idf/components/efuse/esp32s3/include -IC:/esp-idf/components/driver/include -IC:/esp-idf/components/driver/deprecated -IC:/esp-idf/components/driver/esp32s3/include -IC:/esp-idf/components/esp_pm/include -IC:/esp-idf/components/esp_app_format/include -IC:/esp-idf/components/bootloader_support/include -IC:/esp-idf/components/bootloader_support/bootloader_flash/include -IC:/esp-idf/components/esp_partition/include -IC:/esp-idf/components/app_update/include -IC:/esp-idf/components/spi_flash/include -IC:/esp-idf/components/pthread/include -IC:/esp-idf/components/esp_timer/include -IC:/esp-idf/components/app_trace/include -IC:/esp-idf/components/nvs_flash/include -IC:/esp-idf/components/esp_phy/include -IC:/esp-idf/components/esp_phy/esp32s3/include -IC:/esp-idf/components/wpa_supplicant/include -IC:/esp-idf/components/wpa_supplicant/port/include -IC:/esp-idf/components/wpa_supplicant/esp_supplicant/include -IC:/esp-idf/components/esp_wifi/include -IC:/esp-idf/components/unity/include -IC:/esp-idf/components/unity/unity/src -IC:/esp-idf/components/cmock/CMock/src -IC:/esp-idf/components/esp_adc/include -IC:/esp-idf/components/esp_adc/interface -IC:/esp-idf/components/esp_adc/esp32s3/include -IC:/esp-idf/components/esp_adc/deprecated/include -IC:/esp-idf/components/esp_eth/include -IC:/esp-idf/components/esp_gdbstub/include -IC:/esp-idf/components/esp_gdbstub/xtensa -IC:/esp-idf/components/esp_gdbstub/esp32s3 -IC:/esp-idf/components/esp_hid/include -IC:/esp-idf/components/tcp_transport/include -IC:/esp-idf/components/esp_http_client/include -IC:/esp-idf/components/esp_https_ota/include -IC:/esp-idf/components/esp_lcd/include -IC:/esp-idf/components/esp_lcd/interface -IC:/esp-idf/components/protobuf-c/protobuf-c -IC:/esp-idf/components/protocomm/include/common -IC:/esp-idf/components/protocomm/include/security -IC:/esp-idf/components/protocomm/include/transports -IC:/esp-idf/components/esp_local_ctrl/include -IC:/esp-idf/components/esp_psram/include -IC:/esp-idf/components/espcoredump/include -IC:/esp-idf/components/espcoredump/include/port/xtensa -IC:/esp-idf/components/wear_levelling/include -IC:/esp-idf/components/sdmmc/include -IC:/esp-idf/components/fatfs/diskio -IC:/esp-idf/components/fatfs/vfs -IC:/esp-idf/components/fatfs/src -IC:/esp-idf/components/idf_test/include -IC:/esp-idf/components/idf_test/include/esp32s3 -IC:/esp-idf/components/ieee802154/include -IC:/esp-idf/components/json/cJSON -IC:/esp-idf/components/mqtt/esp-mqtt/include -IC:/esp-idf/components/perfmon/include -IC:/esp-idf/components/spiffs/include -IC:/esp-idf/components/touch_element/include -IC:/esp-idf/components/ulp/ulp_common/include -IC:/esp-idf/components/ulp/ulp_common/include/esp32s3 -IC:/esp-idf/components/usb/include -IC:/esp-idf/components/wifi_provisioning/include -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/drv/src/include -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/lvgl/src/lv_core/include -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/lvgl/src/lv_draw/include -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/lvgl/src/lv_font/include -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/lvgl/src/lv_hal/include -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/lvgl/src/lv_misc/include -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/lvgl/src/lv_objx/include -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/lvgl/src/lv_themes/include -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/global_conf -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/ui_images/src/include -mlongcalls  -fdiagnostics-color=always -ffunction-sections -fdata-sections -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wextra -Wno-unused-parameter -Wno-sign-compare -Wno-enum-conversion -gdwarf-4 -ggdb -Og -fmacro-prefix-map=C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022=. -fmacro-prefix-map=C:/esp-idf=/IDF -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -DconfigENABLE_FREERTOS_DEBUG_OCDAWARE=1 -std=gnu17 -Wno-old-style-declaration -D_GNU_SOURCE -DIDF_VER=\"v5.0\" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS -MD -MT esp-idf/my_wss_server/CMakeFiles/__idf_my_wss_server.dir/src/my_login.c.obj -MF esp-idf\my_wss_server\CMakeFiles\__idf_my_wss_server.dir\src\my_login.c.obj.d -o esp-idf/my_wss_server/CMakeFiles/__idf_my_wss_server.dir/src/my_login.c.obj -c C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/communication/my_wss_server/src/my_login.c
C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/communication/my_wss_server/src/my_login.c:4:10: fatal error: esp_https_server.h: No such file or directory
    4 | #include <esp_https_server.h>
compilation terminated.
[974/990] Building C object esp-idf/my_wss_server/CMakeFiles/__idf_my_wss_server.dir/src/webSocket_server.c.obj
FAILED: esp-idf/my_wss_server/CMakeFiles/__idf_my_wss_server.dir/src/webSocket_server.c.obj
C:\.espressif\tools\xtensa-esp32s3-elf\esp-2022r1-11.2.0\xtensa-esp32s3-elf\bin\xtensa-esp32s3-elf-gcc.exe -DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\" -DUNITY_INCLUDE_CONFIG_H -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/build/config -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/communication/my_wss_server/src/include -IC:/esp-idf/components/newlib/platform_include -IC:/esp-idf/components/freertos/FreeRTOS-Kernel/include -IC:/esp-idf/components/freertos/esp_additions/include/freertos -IC:/esp-idf/components/freertos/FreeRTOS-Kernel/portable/xtensa/include -IC:/esp-idf/components/freertos/esp_additions/include -IC:/esp-idf/components/esp_hw_support/include -IC:/esp-idf/components/esp_hw_support/include/soc -IC:/esp-idf/components/esp_hw_support/include/soc/esp32s3 -IC:/esp-idf/components/esp_hw_support/port/esp32s3/. -IC:/esp-idf/components/esp_hw_support/port/esp32s3/private_include -IC:/esp-idf/components/heap/include -IC:/esp-idf/components/log/include -IC:/esp-idf/components/soc/include -IC:/esp-idf/components/soc/esp32s3/. -IC:/esp-idf/components/soc/esp32s3/include -IC:/esp-idf/components/hal/esp32s3/include -IC:/esp-idf/components/hal/include -IC:/esp-idf/components/hal/platform_port/include -IC:/esp-idf/components/esp_rom/include -IC:/esp-idf/components/esp_rom/include/esp32s3 -IC:/esp-idf/components/esp_rom/esp32s3 -IC:/esp-idf/components/esp_common/include -IC:/esp-idf/components/esp_system/include -IC:/esp-idf/components/esp_system/port/soc -IC:/esp-idf/components/esp_system/port/include/private -IC:/esp-idf/components/xtensa/include -IC:/esp-idf/components/xtensa/esp32s3/include -IC:/esp-idf/components/lwip/include -IC:/esp-idf/components/lwip/include/apps -IC:/esp-idf/components/lwip/include/apps/sntp -IC:/esp-idf/components/lwip/lwip/src/include -IC:/esp-idf/components/lwip/port/esp32/include -IC:/esp-idf/components/lwip/port/esp32/include/arch -IC:/esp-idf/components/esp_http_server/include -IC:/esp-idf/components/http_parser -IC:/esp-idf/components/esp-tls -IC:/esp-idf/components/esp-tls/esp-tls-crypto -IC:/esp-idf/components/mbedtls/port/include -IC:/esp-idf/components/mbedtls/mbedtls/include -IC:/esp-idf/components/mbedtls/mbedtls/library -IC:/esp-idf/components/mbedtls/esp_crt_bundle/include -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/managed_components/espressif__mdns/include -IC:/esp-idf/components/console -IC:/esp-idf/components/vfs/include -IC:/esp-idf/components/esp_netif/include -IC:/esp-idf/components/esp_event/include -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/communication/my_wifi/src/include -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/main/src/include -IC:/esp-idf/components/esp_ringbuf/include -IC:/esp-idf/components/efuse/include -IC:/esp-idf/components/efuse/esp32s3/include -IC:/esp-idf/components/driver/include -IC:/esp-idf/components/driver/deprecated -IC:/esp-idf/components/driver/esp32s3/include -IC:/esp-idf/components/esp_pm/include -IC:/esp-idf/components/esp_app_format/include -IC:/esp-idf/components/bootloader_support/include -IC:/esp-idf/components/bootloader_support/bootloader_flash/include -IC:/esp-idf/components/esp_partition/include -IC:/esp-idf/components/app_update/include -IC:/esp-idf/components/spi_flash/include -IC:/esp-idf/components/pthread/include -IC:/esp-idf/components/esp_timer/include -IC:/esp-idf/components/app_trace/include -IC:/esp-idf/components/nvs_flash/include -IC:/esp-idf/components/esp_phy/include -IC:/esp-idf/components/esp_phy/esp32s3/include -IC:/esp-idf/components/wpa_supplicant/include -IC:/esp-idf/components/wpa_supplicant/port/include -IC:/esp-idf/components/wpa_supplicant/esp_supplicant/include -IC:/esp-idf/components/esp_wifi/include -IC:/esp-idf/components/unity/include -IC:/esp-idf/components/unity/unity/src -IC:/esp-idf/components/cmock/CMock/src -IC:/esp-idf/components/esp_adc/include -IC:/esp-idf/components/esp_adc/interface -IC:/esp-idf/components/esp_adc/esp32s3/include -IC:/esp-idf/components/esp_adc/deprecated/include -IC:/esp-idf/components/esp_eth/include -IC:/esp-idf/components/esp_gdbstub/include -IC:/esp-idf/components/esp_gdbstub/xtensa -IC:/esp-idf/components/esp_gdbstub/esp32s3 -IC:/esp-idf/components/esp_hid/include -IC:/esp-idf/components/tcp_transport/include -IC:/esp-idf/components/esp_http_client/include -IC:/esp-idf/components/esp_https_ota/include -IC:/esp-idf/components/esp_lcd/include -IC:/esp-idf/components/esp_lcd/interface -IC:/esp-idf/components/protobuf-c/protobuf-c -IC:/esp-idf/components/protocomm/include/common -IC:/esp-idf/components/protocomm/include/security -IC:/esp-idf/components/protocomm/include/transports -IC:/esp-idf/components/esp_local_ctrl/include -IC:/esp-idf/components/esp_psram/include -IC:/esp-idf/components/espcoredump/include -IC:/esp-idf/components/espcoredump/include/port/xtensa -IC:/esp-idf/components/wear_levelling/include -IC:/esp-idf/components/sdmmc/include -IC:/esp-idf/components/fatfs/diskio -IC:/esp-idf/components/fatfs/vfs -IC:/esp-idf/components/fatfs/src -IC:/esp-idf/components/idf_test/include -IC:/esp-idf/components/idf_test/include/esp32s3 -IC:/esp-idf/components/ieee802154/include -IC:/esp-idf/components/json/cJSON -IC:/esp-idf/components/mqtt/esp-mqtt/include -IC:/esp-idf/components/perfmon/include -IC:/esp-idf/components/spiffs/include -IC:/esp-idf/components/touch_element/include -IC:/esp-idf/components/ulp/ulp_common/include -IC:/esp-idf/components/ulp/ulp_common/include/esp32s3 -IC:/esp-idf/components/usb/include -IC:/esp-idf/components/wifi_provisioning/include -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/drv/src/include -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/lvgl/src/lv_core/include -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/lvgl/src/lv_draw/include -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/lvgl/src/lv_font/include -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/lvgl/src/lv_hal/include -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/lvgl/src/lv_misc/include -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/lvgl/src/lv_objx/include -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/lvgl/src/lv_themes/include -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/global_conf -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/ui_images/src/include -mlongcalls  -fdiagnostics-color=always -ffunction-sections -fdata-sections -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wextra -Wno-unused-parameter -Wno-sign-compare -Wno-enum-conversion -gdwarf-4 -ggdb -Og -fmacro-prefix-map=C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022=. -fmacro-prefix-map=C:/esp-idf=/IDF -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -DconfigENABLE_FREERTOS_DEBUG_OCDAWARE=1 -std=gnu17 -Wno-old-style-declaration -D_GNU_SOURCE -DIDF_VER=\"v5.0\" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS -MD -MT esp-idf/my_wss_server/CMakeFiles/__idf_my_wss_server.dir/src/webSocket_server.c.obj -MF esp-idf\my_wss_server\CMakeFiles\__idf_my_wss_server.dir\src\webSocket_server.c.obj.d -o esp-idf/my_wss_server/CMakeFiles/__idf_my_wss_server.dir/src/webSocket_server.c.obj -c C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/communication/my_wss_server/src/webSocket_server.c
C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/communication/my_wss_server/src/webSocket_server.c:9:10: fatal error: esp_https_server.h: No such file or directory
    9 | #include <esp_https_server.h>
[976/990] Building C object esp-idf/drv/CMakeFiles/__idf_drv.dir/src/hw_lcd_dma.c.obj
C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/drv/src/hw_lcd_dma.c:181:1: warning: ignoring attribute 'section (".iram1.10")' because it conflicts with previous 'section (".iram1.9")' [-Wattributes]
  181 | {
C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/drv/src/hw_lcd_dma.c:94:23: note: previous declaration here
   94 | static IRAM_ATTR void hw_lcd_dma_isr(void* args);
[977/990] Building C object esp-idf/my_wifi/CMakeFiles/__idf_my_wifi.dir/src/my_wifi.c.obj
C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/communication/my_wifi/src/my_wifi.c:173:13: warning: 'set_unique_hostname' defined but not used [-Wunused-function]
  173 | static void set_unique_hostname()
[978/990] Building C object esp-idf/drv/CMakeFiles/__idf_drv.dir/src/hw_lcd.c.obj
C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/drv/src/hw_lcd.c:140:1: warning: ignoring attribute 'section (".iram1.4")' because it conflicts with previous 'section (".iram1.3")' [-Wattributes]
  140 | {
C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/drv/src/hw_lcd.c:104:23: note: previous declaration here
  104 | static IRAM_ATTR void hw_lcd_isr(void* args);
 *  The terminal process "C:\Windows\System32\WindowsPowerShell\v1.0\powershell.exe -Command ninja " terminated with exit code: 1.
Same problem here:
AND
AND this warning that i dont know what means
Baldhead
Postby Baldhead » Thu Dec 08, 2022 7:49 pm
i need to review and reconfigure all sdkconfig.
The esp_https_server was disabled and WebSocket server support was disable too.
Some bug in esp-idf migration that misconfigured sdkconfig.
Baldhead
Postby Baldhead » Thu Dec 08, 2022 10:48 pm
Compilation log now:
[2/2] idf (5.0.0)
-- Configuring done
-- Generating done
[9/998] Generating ../../partition_table/partition-table.bin
factory,app,factory,0x10000,2M,
storage,data,spiffs,0x210000,960K,
[492/998] Performing configure step for 'bootloader'
-- Configuring done
-- Generating done
[597/998] Performing build step for 'bootloader'
[1/106] Building C object esp-idf/xtensa/CMakeFiles/__idf_xtensa.dir/eri.c.obj
[3/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/gpio_periph.c.obj
[4/106] Generating project_elf_src_esp32s3.c
[5/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/lldesc.c.obj
[6/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/dport_access_common.c.obj
[7/106] Building C object CMakeFiles/bootloader.elf.dir/project_elf_src_esp32s3.c.obj
[8/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/sdm_periph.c.obj
[9/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/dedic_gpio_periph.c.obj
[10/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/adc_periph.c.obj
[11/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/i2c_periph.c.obj
[12/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/gdma_periph.c.obj
[13/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/pcnt_periph.c.obj
[14/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/i2s_periph.c.obj
[15/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/lcd_periph.c.obj
[16/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/interrupts.c.obj
[17/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/mcpwm_periph.c.obj
[18/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/ledc_periph.c.obj
[19/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/rmt_periph.c.obj
[20/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/timer_periph.c.obj
[22/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/sdio_slave_periph.c.obj
[23/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/rtc_io_periph.c.obj
[24/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/sdmmc_periph.c.obj
[25/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/temperature_sensor_periph.c.obj
[26/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/uart_periph.c.obj
[27/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/touch_sensor_periph.c.obj
[29/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/usb_otg_periph.c.obj
[30/106] Building C object esp-idf/hal/CMakeFiles/__idf_hal.dir/cache_hal.c.obj
[31/106] Building C object esp-idf/hal/CMakeFiles/__idf_hal.dir/mpu_hal.c.obj
[32/106] Building C object esp-idf/hal/CMakeFiles/__idf_hal.dir/esp32s3/efuse_hal.c.obj
[34/106] Building C object esp-idf/hal/CMakeFiles/__idf_hal.dir/mmu_hal.c.obj
[35/106] Building C object esp-idf/esp_app_format/CMakeFiles/__idf_esp_app_format.dir/esp_app_desc.c.obj
[36/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_clock_init.c.obj
[38/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_common.c.obj
[39/106] Building C object esp-idf/micro-ecc/CMakeFiles/__idf_micro-ecc.dir/uECC_verify_antifault.c.obj
[40/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_random.c.obj
[41/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_clock_loader.c.obj
[42/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_common_loader.c.obj
[43/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/bootloader_flash/src/bootloader_flash.c.obj
[45/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/bootloader_flash/src/bootloader_flash_config_esp32s3.c.obj
[47/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/secure_boot.c.obj
[48/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_init.c.obj
[49/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_random_esp32s3.c.obj
[50/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/flash_encrypt.c.obj
[51/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/esp_image_format.c.obj
[52/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/flash_partitions.c.obj
[53/106] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/esp32s3/esp_efuse_rtc_calib.c.obj
[54/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_utility.c.obj
[55/106] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/esp32s3/esp_efuse_table.c.obj
[56/106] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/esp32s3/esp_efuse_fields.c.obj
[57/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_console_loader.c.obj
[58/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/esp32s3/bootloader_sha.c.obj
[59/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/esp32s3/bootloader_soc.c.obj
[60/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_console.c.obj
[61/106] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/esp32s3/esp_efuse_utility.c.obj
[62/106] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32s3/rtc_time.c.obj
[63/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_panic.c.obj
[64/106] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32s3/rtc_pm.c.obj
[65/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/esp32s3/bootloader_esp32s3.c.obj
[66/106] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32s3/rtc_sleep.c.obj
[67/106] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/src/esp_efuse_fields.c.obj
[68/106] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32s3/chip_info.c.obj
[69/106] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/src/efuse_controller/keys/with_key_purposes/esp_efuse_api_key.c.obj
[70/106] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/src/esp_efuse_api.c.obj
[72/106] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/src/esp_efuse_utility.c.obj
[73/106] Building C object esp-idf/esp_system/CMakeFiles/__idf_esp_system.dir/esp_err.c.obj
[77/106] Building C object esp-idf/log/CMakeFiles/__idf_log.dir/log_noos.c.obj
[80/106] Building C object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_sys.c.obj
[81/106] Building C object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_crc.c.obj
[82/106] Building C object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_uart.c.obj
[83/106] Building C object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_efuse.c.obj
[84/106] Building ASM object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_longjmp.S.obj
[85/106] Building C object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_systimer.c.obj
[86/106] Building C object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_spiflash.c.obj
[87/106] Building C object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_regi2c.c.obj
[88/106] Building C object esp-idf/log/CMakeFiles/__idf_log.dir/log_buffers.c.obj
[89/106] Building C object esp-idf/main/CMakeFiles/__idf_main.dir/bootloader_start.c.obj
[90/106] Building C object esp-idf/log/CMakeFiles/__idf_log.dir/log.c.obj
esptool.py v4.4
[106/106] cmd.exe /C "cd /D C:\esp32-Proj\WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022\build\bootloader\esp-idf\esptool_py && C:\.espressif\python_env\idf5.0_py3.8_env\Scripts\python.exe C:/esp-idf/components/partition_table/check_sizes.py --offset 0x8000 bootloader 0x0 C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/build/bootloader/bootloader.bin"Bootloader binary size 0x5150 bytes. 0x2eb0 bytes (36%) free.
[907/998] Building C object esp-idf/lvgl/CMakeFiles/__idf_lvgl.dir/src/lv_hal/lv_hal_tick.c.objC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/lvgl/src/lv_hal/lv_hal_tick.c:51:1: warning: ignoring attribute 'section (".iram1.1")' because it conflicts with previous 'section (".iram1.0")' [-Wattributes]
   51 | {
[979/998] Building C object esp-idf/main/CMakeFiles/__idf_main.dir/src/my_app.c.obj
  394 | {
[982/998] Building C object esp-idf/my_wss_server/CMakeFiles/__idf_my_wss_server.dir/src/webSocket_server.c.obj
C:\.espressif\tools\xtensa-esp32s3-elf\esp-2022r1-11.2.0\xtensa-esp32s3-elf\bin\xtensa-esp32s3-elf-gcc.exe -DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\" -DUNITY_INCLUDE_CONFIG_H -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/build/config -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/communication/my_wss_server/src/include -IC:/esp-idf/components/newlib/platform_include -IC:/esp-idf/components/freertos/FreeRTOS-Kernel/include -IC:/esp-idf/components/freertos/esp_additions/include/freertos -IC:/esp-idf/components/freertos/FreeRTOS-Kernel/portable/xtensa/include -IC:/esp-idf/components/freertos/esp_additions/include -IC:/esp-idf/components/esp_hw_support/include -IC:/esp-idf/components/esp_hw_support/include/soc -IC:/esp-idf/components/esp_hw_support/include/soc/esp32s3 -IC:/esp-idf/components/esp_hw_support/port/esp32s3/. -IC:/esp-idf/components/esp_hw_support/port/esp32s3/private_include -IC:/esp-idf/components/heap/include -IC:/esp-idf/components/log/include -IC:/esp-idf/components/soc/include -IC:/esp-idf/components/soc/esp32s3/. -IC:/esp-idf/components/soc/esp32s3/include -IC:/esp-idf/components/hal/esp32s3/include -IC:/esp-idf/components/hal/include -IC:/esp-idf/components/hal/platform_port/include -IC:/esp-idf/components/esp_rom/include -IC:/esp-idf/components/esp_rom/include/esp32s3 -IC:/esp-idf/components/esp_rom/esp32s3 -IC:/esp-idf/components/esp_common/include -IC:/esp-idf/components/esp_system/include -IC:/esp-idf/components/esp_system/port/soc -IC:/esp-idf/components/esp_system/port/include/private -IC:/esp-idf/components/xtensa/include -IC:/esp-idf/components/xtensa/esp32s3/include -IC:/esp-idf/components/lwip/include -IC:/esp-idf/components/lwip/include/apps -IC:/esp-idf/components/lwip/include/apps/sntp -IC:/esp-idf/components/lwip/lwip/src/include -IC:/esp-idf/components/lwip/port/esp32/include -IC:/esp-idf/components/lwip/port/esp32/include/arch -IC:/esp-idf/components/esp_https_server/include -IC:/esp-idf/components/esp_http_server/include -IC:/esp-idf/components/http_parser -IC:/esp-idf/components/esp-tls -IC:/esp-idf/components/esp-tls/esp-tls-crypto -IC:/esp-idf/components/mbedtls/port/include -IC:/esp-idf/components/mbedtls/mbedtls/include -IC:/esp-idf/components/mbedtls/mbedtls/library -IC:/esp-idf/components/mbedtls/esp_crt_bundle/include -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/managed_components/espressif__mdns/include -IC:/esp-idf/components/console -IC:/esp-idf/components/vfs/include -IC:/esp-idf/components/esp_netif/include -IC:/esp-idf/components/esp_event/include -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/communication/my_wifi/src/include -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/main/src/include -IC:/esp-idf/components/esp_ringbuf/include -IC:/esp-idf/components/efuse/include -IC:/esp-idf/components/efuse/esp32s3/include -IC:/esp-idf/components/driver/include -IC:/esp-idf/components/driver/deprecated -IC:/esp-idf/components/driver/esp32s3/include -IC:/esp-idf/components/esp_pm/include -IC:/esp-idf/components/esp_app_format/include -IC:/esp-idf/components/bootloader_support/include -IC:/esp-idf/components/bootloader_support/bootloader_flash/include -IC:/esp-idf/components/esp_partition/include -IC:/esp-idf/components/app_update/include -IC:/esp-idf/components/spi_flash/include -IC:/esp-idf/components/pthread/include -IC:/esp-idf/components/esp_timer/include -IC:/esp-idf/components/app_trace/include -IC:/esp-idf/components/nvs_flash/include -IC:/esp-idf/components/esp_phy/include -IC:/esp-idf/components/esp_phy/esp32s3/include -IC:/esp-idf/components/wpa_supplicant/include -IC:/esp-idf/components/wpa_supplicant/port/include -IC:/esp-idf/components/wpa_supplicant/esp_supplicant/include -IC:/esp-idf/components/esp_wifi/include -IC:/esp-idf/components/unity/include -IC:/esp-idf/components/unity/unity/src -IC:/esp-idf/components/cmock/CMock/src -IC:/esp-idf/components/esp_adc/include -IC:/esp-idf/components/esp_adc/interface -IC:/esp-idf/components/esp_adc/esp32s3/include -IC:/esp-idf/components/esp_adc/deprecated/include -IC:/esp-idf/components/esp_eth/include -IC:/esp-idf/components/esp_gdbstub/include -IC:/esp-idf/components/esp_gdbstub/xtensa -IC:/esp-idf/components/esp_gdbstub/esp32s3 -IC:/esp-idf/components/esp_hid/include -IC:/esp-idf/components/tcp_transport/include -IC:/esp-idf/components/esp_http_client/include -IC:/esp-idf/components/esp_https_ota/include -IC:/esp-idf/components/esp_lcd/include -IC:/esp-idf/components/esp_lcd/interface -IC:/esp-idf/components/protobuf-c/protobuf-c -IC:/esp-idf/components/protocomm/include/common -IC:/esp-idf/components/protocomm/include/security -IC:/esp-idf/components/protocomm/include/transports -IC:/esp-idf/components/esp_local_ctrl/include -IC:/esp-idf/components/esp_psram/include -IC:/esp-idf/components/espcoredump/include -IC:/esp-idf/components/espcoredump/include/port/xtensa -IC:/esp-idf/components/wear_levelling/include -IC:/esp-idf/components/sdmmc/include -IC:/esp-idf/components/fatfs/diskio -IC:/esp-idf/components/fatfs/vfs -IC:/esp-idf/components/fatfs/src -IC:/esp-idf/components/idf_test/include -IC:/esp-idf/components/idf_test/include/esp32s3 -IC:/esp-idf/components/ieee802154/include -IC:/esp-idf/components/json/cJSON -IC:/esp-idf/components/mqtt/esp-mqtt/include -IC:/esp-idf/components/perfmon/include -IC:/esp-idf/components/spiffs/include -IC:/esp-idf/components/touch_element/include -IC:/esp-idf/components/ulp/ulp_common/include -IC:/esp-idf/components/ulp/ulp_common/include/esp32s3 -IC:/esp-idf/components/usb/include -IC:/esp-idf/components/wifi_provisioning/include -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/drv/src/include -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/lvgl/src/lv_core/include -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/lvgl/src/lv_draw/include -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/lvgl/src/lv_font/include -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/lvgl/src/lv_hal/include -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/lvgl/src/lv_misc/include -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/lvgl/src/lv_objx/include -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/lvgl/src/lv_themes/include -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/global_conf -IC:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/ui_images/src/include -mlongcalls  -fdiagnostics-color=always -ffunction-sections -fdata-sections -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wextra -Wno-unused-parameter -Wno-sign-compare -Wno-enum-conversion -gdwarf-4 -ggdb -O2 -fmacro-prefix-map=C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022=. -fmacro-prefix-map=C:/esp-idf=/IDF -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -DconfigENABLE_FREERTOS_DEBUG_OCDAWARE=1 -std=gnu17 -Wno-old-style-declaration -D_GNU_SOURCE -DIDF_VER=\"v5.0\" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS -MD -MT esp-idf/my_wss_server/CMakeFiles/__idf_my_wss_server.dir/src/webSocket_server.c.obj -MF esp-idf\my_wss_server\CMakeFiles\__idf_my_wss_server.dir\src\webSocket_server.c.obj.d -o esp-idf/my_wss_server/CMakeFiles/__idf_my_wss_server.dir/src/webSocket_server.c.obj -c C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/communication/my_wss_server/src/webSocket_server.c
C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/communication/my_wss_server/src/webSocket_server.c: In function 'get_clients_message_handler':
C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/communication/my_wss_server/src/webSocket_server.c:194:28: warning: comparison is always true due to limited range of data type [-Wtype-limits]
  194 |     if( (ws_pkt.payload[0] >= 0) && (ws_pkt.payload[0] < web_comm_t_array_size_t) )  // func_index = ws_pkt.payload[0].
C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/communication/my_wss_server/src/webSocket_server.c: In function 'updateServerState':
C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/communication/my_wss_server/src/webSocket_server.c:542:27: warning: comparison is always true due to limited range of data type [-Wtype-limits]
  542 |     if( frame->payload[3] >= 0 && frame->payload[3] <= 100 ) { st.fanSpeed = frame->payload[3]; }
In file included from C:/esp-idf/components/esp_hw_support/include/esp_intr_alloc.h:11,
                 from C:/esp-idf/components/esp_hw_support/include/esp_cpu.h:20,
                 from C:/esp-idf/components/esp_hw_support/include/spinlock.h:11,
                 from C:/esp-idf/components/freertos/FreeRTOS-Kernel/portable/xtensa/include/freertos/portmacro.h:74,
                 from C:/esp-idf/components/freertos/FreeRTOS-Kernel/include/freertos/portable.h:58,
                 from C:/esp-idf/components/freertos/FreeRTOS-Kernel/include/freertos/FreeRTOS.h:70,
                 from C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/communication/my_wss_server/src/webSocket_server.c:4:
C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/communication/my_wss_server/src/webSocket_server.c: In function 'init_webSocket_server':
C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/communication/my_wss_server/src/webSocket_server.c:969:48: error: 'WIFI_EVENT' undeclared (first use in this function); did you mean 'IP_EVENT'?
  969 |     ESP_ERROR_CHECK(esp_event_handler_register(WIFI_EVENT, WIFI_EVENT_STA_DISCONNECTED, &disconnect_handler, NULL));
C:/esp-idf/components/esp_common/include/esp_err.h:117:30: note: in definition of macro 'ESP_ERROR_CHECK'
  117 |         esp_err_t err_rc_ = (x);                                        \
C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/communication/my_wss_server/src/webSocket_server.c:969:48: note: each undeclared identifier is reported only once for each function it appears in
C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/communication/my_wss_server/src/webSocket_server.c:969:60: error: 'WIFI_EVENT_STA_DISCONNECTED' undeclared (first use in this function)
At top level:
C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/communication/my_wss_server/src/webSocket_server.c:406:13: warning: 'send_Ws_Error_Message_Async_all_clients' defined but not used [-Wunused-function]
  406 | static void send_Ws_Error_Message_Async_all_clients( char* errorMessage, uint8_t errorCommand )
C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/communication/my_wss_server/src/webSocket_server.c:386:13: warning: 'resp_Ws_Error_Message_Async_one_client' defined but not used [-Wunused-function]
  386 | static void resp_Ws_Error_Message_Async_one_client( int sockfd, char* errorMessage, uint8_t errorCommand )
[983/998] Building C object esp-idf/my_wifi/CMakeFiles/__idf_my_wifi.dir/src/my_wifi.c.obj
[985/998] Building C object esp-idf/my_wss_server/CMakeFiles/__idf_my_wss_server.dir/src/my_login.c.obj
C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/communication/my_wss_server/src/my_login.c:66:13: warning: 'is_admin' defined but not used [-Wunused-function]
   66 | static bool is_admin( httpd_req_t *req, int sockfd )
C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/communication/my_wss_server/src/my_login.c:49:18: warning: 'my_login_search_users_login' defined but not used [-Wunused-function]
   49 | static esp_err_t my_login_search_users_login( httpd_req_t *req, uint8_t comm_Operation )
C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/communication/my_wss_server/src/my_login.c:37:25: warning: 'client_hash' defined but not used [-Wunused-variable]
   37 | static ws_client_hash_t client_hash[5];  // ver alocacao dinamica.
[986/998] Building C object esp-idf/drv/CMakeFiles/__idf_drv.dir/src/hw_lcd.c.obj
  140 | {
[987/998] Building C object esp-idf/drv/CMakeFiles/__idf_drv.dir/src/hw_lcd_dma.c.obj
  181 | {
The strange thing is that IP_EVENT work, only WIFI_EVENT problem.
ESP_ERROR_CHECK(esp_event_handler_register(IP_EVENT, IP_EVENT_STA_GOT_IP, &connect_handler, NULL));
Baldhead
Re: VSC installation BUG
Postby Baldhead » Fri Dec 09, 2022 5:07 pm
Some suggestion ????
Baldhead
Postby Baldhead » Fri Dec 09, 2022 5:24 pm
it seems that adding the ' #include "esp_wifi_types.h" ' header solved the problem of 'WIFI_EVENT' undeclared (first use in this function);
Baldhead
Postby Baldhead » Fri Dec 09, 2022 5:53 pm
it looks like it compiled ok now, however, a clearer message of compilation OK should be given by the vsc esp-idf extension.
AND, i dont understand this yet:
-- Component directory C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/communication does not contain a CMakeLists.txt file. No component will be added
-- Component directory C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui does not contain a CMakeLists.txt file. No component will be added
Compilation Log:
Executing task: cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DESP_PLATFORM=1 -B c:\esp32-Proj\WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022\build -S c:\esp32-Proj\WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022 -B c:\esp32-Proj\WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022\build -S c:\esp32-Proj\WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022
-- Found Git: C:/.espressif/tools/idf-git/2.30.1/cmd/git.exe (found version "2.30.1.windows.1")
-- The C compiler identification is GNU 11.2.0
-- The CXX compiler identification is GNU 11.2.0
-- Found assembler: C:/.espressif/tools/xtensa-esp32s3-elf/esp-2022r1-11.2.0/xtensa-esp32s3-elf/bin/xtensa-esp32s3-elf-gcc.exe
-- Check for working C compiler: C:/.espressif/tools/xtensa-esp32s3-elf/esp-2022r1-11.2.0/xtensa-esp32s3-elf/bin/xtensa-esp32s3-elf-gcc.exe - skipped
-- Check for working CXX compiler: C:/.espressif/tools/xtensa-esp32s3-elf/esp-2022r1-11.2.0/xtensa-esp32s3-elf/bin/xtensa-esp32s3-elf-g++.exe - skipped
-- Project is not inside a git repository, or git repository has no commits; will not use 'git describe' to determine PROJECT_VER.
-- Building ESP-IDF components for target esp32s3
Processing 2 dependencies:
[1/2] espressif/mdns (1.0.7)
[2/2] idf (5.0.0)
-- Project sdkconfig file C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/sdkconfig
-- Looking for sys/types.h
-- Looking for sys/types.h - found
-- Looking for stdint.h
-- Looking for stdint.h - found
-- Looking for stddef.h
-- Looking for stddef.h - found
-- Check size of time_t
-- Check size of time_t - done
-- Found Python3: C:/.espressif/python_env/idf5.0_py3.8_env/Scripts/python.exe (found version "3.8.7") found components: Interpreter
-- Performing Test C_COMPILER_SUPPORTS_WFORMAT_SIGNEDNESS
-- Performing Test C_COMPILER_SUPPORTS_WFORMAT_SIGNEDNESS - Success
-- App "wss_server" version: 1
-- Adding linker script C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/build/esp-idf/esp_system/ld/memory.ld
-- Adding linker script C:/esp-idf/components/esp_system/ld/esp32s3/sections.ld.in
-- Adding linker script C:/esp-idf/components/esp_rom/esp32s3/ld/esp32s3.rom.ld
-- Adding linker script C:/esp-idf/components/esp_rom/esp32s3/ld/esp32s3.rom.api.ld
-- Adding linker script C:/esp-idf/components/esp_rom/esp32s3/ld/esp32s3.rom.libgcc.ld
-- Adding linker script C:/esp-idf/components/esp_rom/esp32s3/ld/esp32s3.rom.newlib.ld
-- Adding linker script C:/esp-idf/components/esp_rom/esp32s3/ld/esp32s3.rom.version.ld
-- Adding linker script C:/esp-idf/components/soc/esp32s3/ld/esp32s3.peripherals.ld
-- Components: app_trace app_update bootloader bootloader_support bt cmock console cxx driver drv efuse esp-tls esp_adc esp_app_format esp_common esp_eth esp_event esp_gdbstub esp_hid esp_http_client esp_http_server esp_https_ota esp_https_server esp_hw_support esp_lcd esp_local_ctrl esp_netif esp_partition esp_phy esp_pm esp_psram esp_ringbuf esp_rom esp_system esp_timer esp_wifi espcoredump espressif__mdns esptool_py fatfs freertos global_conf hal heap http_parser idf_test ieee802154 json log lvgl lwip main mbedtls mqtt my_wifi my_wss_server newlib nvs_flash openthread partition_table perfmon protobuf-c protocomm pthread sdmmc soc spi_flash spiffs tcp_transport touch_element ui_images ulp unity usb vfs wear_levelling wifi_provisioning wpa_supplicant xtensa
-- Component paths: C:/esp-idf/components/app_trace C:/esp-idf/components/app_update C:/esp-idf/components/bootloader C:/esp-idf/components/bootloader_support C:/esp-idf/components/bt C:/esp-idf/components/cmock C:/esp-idf/components/console C:/esp-idf/components/cxx C:/esp-idf/components/driver C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/drv C:/esp-idf/components/efuse C:/esp-idf/components/esp-tls C:/esp-idf/components/esp_adc C:/esp-idf/components/esp_app_format C:/esp-idf/components/esp_common C:/esp-idf/components/esp_eth C:/esp-idf/components/esp_event C:/esp-idf/components/esp_gdbstub C:/esp-idf/components/esp_hid C:/esp-idf/components/esp_http_client C:/esp-idf/components/esp_http_server C:/esp-idf/components/esp_https_ota C:/esp-idf/components/esp_https_server C:/esp-idf/components/esp_hw_support C:/esp-idf/components/esp_lcd C:/esp-idf/components/esp_local_ctrl C:/esp-idf/components/esp_netif C:/esp-idf/components/esp_partition C:/esp-idf/components/esp_phy C:/esp-idf/components/esp_pm C:/esp-idf/components/esp_psram C:/esp-idf/components/esp_ringbuf C:/esp-idf/components/esp_rom C:/esp-idf/components/esp_system C:/esp-idf/components/esp_timer C:/esp-idf/components/esp_wifi C:/esp-idf/components/espcoredump C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/managed_components/espressif__mdns C:/esp-idf/components/esptool_py C:/esp-idf/components/fatfs C:/esp-idf/components/freertos C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/global_conf C:/esp-idf/components/hal C:/esp-idf/components/heap C:/esp-idf/components/http_parser C:/esp-idf/components/idf_test C:/esp-idf/components/ieee802154 C:/esp-idf/components/json C:/esp-idf/components/log C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/lvgl C:/esp-idf/components/lwip C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/main C:/esp-idf/components/mbedtls C:/esp-idf/components/mqtt C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/communication/my_wifi C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/communication/my_wss_server C:/esp-idf/components/newlib C:/esp-idf/components/nvs_flash C:/esp-idf/components/openthread C:/esp-idf/components/partition_table C:/esp-idf/components/perfmon C:/esp-idf/components/protobuf-c C:/esp-idf/components/protocomm C:/esp-idf/components/pthread C:/esp-idf/components/sdmmc C:/esp-idf/components/soc C:/esp-idf/components/spi_flash C:/esp-idf/components/spiffs C:/esp-idf/components/tcp_transport C:/esp-idf/components/touch_element C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/components/ui/ui_images C:/esp-idf/components/ulp C:/esp-idf/components/unity C:/esp-idf/components/usb C:/esp-idf/components/vfs C:/esp-idf/components/wear_levelling C:/esp-idf/components/wifi_provisioning C:/esp-idf/components/wpa_supplicant C:/esp-idf/components/xtensa
-- Configuring done
-- Generating done
 *  Executing task: ninja
[12/998] Generating ../../partition_table/partition-table.bin
Partition table binary generated. Contents:
# ESP-IDF Partition Table
nvs,data,nvs,0x9000,24K,
phy_init,data,phy,0xf000,4K,
[501/998] Performing configure step for 'bootloader'
-- App "bootloader" version: v5.0
-- Adding linker script C:/esp-idf/components/bootloader/subproject/main/ld/esp32s3/bootloader.ld
-- Adding linker script C:/esp-idf/components/bootloader/subproject/main/ld/esp32s3/bootloader.rom.ld
-- Components: bootloader bootloader_support efuse esp_app_format esp_common esp_hw_support esp_rom esp_system esptool_py freertos hal log main micro-ecc newlib partition_table soc spi_flash xtensa
-- Component paths: C:/esp-idf/components/bootloader C:/esp-idf/components/bootloader_support C:/esp-idf/components/efuse C:/esp-idf/components/esp_app_format C:/esp-idf/components/esp_common C:/esp-idf/components/esp_hw_support C:/esp-idf/components/esp_rom C:/esp-idf/components/esp_system C:/esp-idf/components/esptool_py C:/esp-idf/components/freertos C:/esp-idf/components/hal C:/esp-idf/components/log C:/esp-idf/components/bootloader/subproject/main C:/esp-idf/components/bootloader/subproject/components/micro-ecc C:/esp-idf/components/newlib C:/esp-idf/components/partition_table C:/esp-idf/components/soc C:/esp-idf/components/spi_flash C:/esp-idf/components/xtensa
-- Configuring done
-- Generating done
-- Build files have been written to: C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/build/bootloader
[613/998] Performing build step for 'bootloader'
[2/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/dedic_gpio_periph.c.obj
[3/106] Generating project_elf_src_esp32s3.c
[4/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/gdma_periph.c.obj
[5/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/adc_periph.c.obj
[6/106] Building C object esp-idf/xtensa/CMakeFiles/__idf_xtensa.dir/xt_trax.c.obj
[7/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/dport_access_common.c.obj
[9/106] Building C object CMakeFiles/bootloader.elf.dir/project_elf_src_esp32s3.c.obj
[10/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/lldesc.c.obj
[11/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/gpio_periph.c.obj
[12/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/i2c_periph.c.obj
[13/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/i2s_periph.c.obj
[14/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/lcd_periph.c.obj
[15/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/interrupts.c.obj
[16/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/ledc_periph.c.obj
[18/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/rmt_periph.c.obj
[19/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/sdmmc_periph.c.obj
[20/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/pcnt_periph.c.obj
[21/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/rtc_io_periph.c.obj
[23/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/spi_periph.c.obj
[24/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/usb_periph.c.obj
[25/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/timer_periph.c.obj
[26/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/touch_sensor_periph.c.obj
[27/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/temperature_sensor_periph.c.obj
[28/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/usb_otg_periph.c.obj
[29/106] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32s3/uart_periph.c.obj
[30/106] Building C object esp-idf/hal/CMakeFiles/__idf_hal.dir/esp32s3/efuse_hal.c.obj
[31/106] Building C object esp-idf/hal/CMakeFiles/__idf_hal.dir/efuse_hal.c.obj
[32/106] Building C object esp-idf/hal/CMakeFiles/__idf_hal.dir/mpu_hal.c.obj
[33/106] Building C object esp-idf/hal/CMakeFiles/__idf_hal.dir/mmu_hal.c.obj
[34/106] Building C object esp-idf/hal/CMakeFiles/__idf_hal.dir/cache_hal.c.obj
[35/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_mem.c.obj
[37/106] Building C object esp-idf/micro-ecc/CMakeFiles/__idf_micro-ecc.dir/uECC_verify_antifault.c.obj
[39/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_common_loader.c.obj
[40/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/bootloader_flash/src/bootloader_flash.c.obj
[41/106] Building C object esp-idf/esp_app_format/CMakeFiles/__idf_esp_app_format.dir/esp_app_desc.c.obj
[42/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/bootloader_flash/src/bootloader_flash_config_esp32s3.c.obj
[43/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_efuse.c.obj
[44/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/flash_partitions.c.obj
[45/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/bootloader_flash/src/flash_qio_mode.c.obj
[46/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_init.c.obj
[47/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/flash_encrypt.c.obj
[48/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_utility.c.obj
[50/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_random.c.obj
[52/106] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/esp32s3/esp_efuse_fields.c.obj
[53/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/esp_image_format.c.obj
[55/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_panic.c.obj
[56/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/esp32s3/bootloader_esp32s3.c.obj
[57/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_clock_loader.c.obj
[59/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_console.c.obj
[60/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_console_loader.c.obj
[61/106] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/esp32s3/bootloader_soc.c.obj
[62/106] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/src/esp_efuse_api.c.obj
[63/106] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/esp32s3/esp_efuse_rtc_calib.c.obj
[64/106] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/esp32s3/esp_efuse_utility.c.obj
[65/106] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/src/efuse_controller/keys/with_key_purposes/esp_efuse_api_key.c.obj
[66/106] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/src/esp_efuse_utility.c.obj
[68/106] Building C object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_sys.c.obj
[69/106] Building C object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_spiflash.c.obj
[70/106] Building C object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_crc.c.obj
[71/106] Building C object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_uart.c.obj
[72/106] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/esp_memory_utils.c.obj
[74/106] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/cpu.c.obj
[75/106] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32s3/rtc_sleep.c.obj
[76/106] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32s3/rtc_clk.c.obj
[77/106] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32s3/rtc_clk_init.c.obj
[78/106] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32s3/rtc_pm.c.obj
[79/106] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32s3/chip_info.c.obj
[80/106] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32s3/rtc_init.c.obj
[81/106] Building C object esp-idf/esp_common/CMakeFiles/__idf_esp_common.dir/src/esp_err_to_name.c.obj
[82/106] Building C object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_systimer.c.obj
[83/106] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32s3/rtc_time.c.obj
[85/106] Building C object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_efuse.c.obj
[86/106] Building C object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_regi2c.c.obj
[87/106] Building C object esp-idf/log/CMakeFiles/__idf_log.dir/log_noos.c.obj
[88/106] Building C object esp-idf/main/CMakeFiles/__idf_main.dir/bootloader_start.c.obj
[89/106] Building C object esp-idf/log/CMakeFiles/__idf_log.dir/log.c.obj
[90/106] Building C object esp-idf/log/CMakeFiles/__idf_log.dir/log_buffers.c.obj
esptool.py v4.4
[904/998] Building C object esp-idf/lvgl/CMakeFiles/__idf_lvgl.dir/src/lv_hal/lv_hal_tick.c.obj
   51 | {
[978/998] Building C object esp-idf/drv/CMakeFiles/__idf_drv.dir/src/hw_lcd.c.obj
  140 | {
  394 | {
[984/998] Building C object esp-idf/drv/CMakeFiles/__idf_drv.dir/src/hw_lcd_dma.c.obj
  181 | {
[986/998] Building C object esp-idf/my_wifi/CMakeFiles/__idf_my_wifi.dir/src/my_wifi.c.obj
[989/998] Building C object esp-idf/my_wss_server/CMakeFiles/__idf_my_wss_server.dir/src/webSocket_server.c.obj
At top level:
[997/998] Generating binary image from built executable
esptool.py v4.4
Merged 2 ELF sections
Generated C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/build/wss_server.bin
[998/998] cmd.exe /C "cd /D C:\esp32-Proj\WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022\build\esp-idf\esptool_py && C:\.espressif\p...05-2022/build/partition_table/partition-table.bin C:/esp32-Proj/WSS_SERVER_AND_UI_INTEGRATION_S3_16-05-2022/build/wss_server.bin"
wss_server.bin binary size 0x135c50 bytes. Smallest app partition is 0x200000 bytes. 0xca3b0 bytes (39%) free.
