Thank you! Now there are normal characters showing.. finally. Okay so I could upload a program to my ESP32-S3, and now there is the next problem: I can't exit the bootloader:
- serial_monitor_3.jpg (25.2 KiB) Viewed 1875 times
It always says this message. I uploaded my program with IO0 and IO46 connected to ground, uploaded successfully and now after I reset the chip via the Chip enable connection, It does not want to start normal. I disconnected IO0 and IO46 from ground and they are floating. But it always goes into this boot mode. Does anybody know how I can fix this? I measured on both pins 1.46V, which should be "HIGH" right?
Thanks!
