[Solved?] Cannot connect to ESP32-C3 USB/JTAG outside of bootloader
klushund
Re: [Solved?] Cannot connect to ESP32-C3 USB/JTAG outside of bootloader
Postby klushund » Fri Jul 28, 2023 1:21 pm
I have the same problem here with ESP32-C3 V0.4 boards (But with a V0.3 version debugging works fine: flashing without boot mode). The problematic board is not able to flash without boot mode (
** Flashing Failed **
-1
), but OpenOCD connects using the
-c "gdb_memory_map disable"
switch. Suspend, Resume, Single Step Into work. Also the call stacks and variable contents are displayed correctly.
But breakpoints do not work: The ones set during startup are ignored, and adding one while haltet results in the (repeatet) terminal output:
Guru Meditation Error: Core  0 panic'ed (Cache error).
ibus tried to write cache
Setting breakpoint at 0x42009fae and returning...
Step over results in the same panic. Changes of variables are simply ignored.
Has anyone a clue how I can solve this problem?
Users browsing this forum: Baidu [Spider], PerplexityBot, Qwantbot and 2 guests
