Re: PCB check, and ideas
Posted: Tue Feb 07, 2023 12:23 am
Okay, good that you posted that schematic because if you built this, poor Q1 would have died almost immediately.
- Q1 is a BJT, and those need their base current limited. You want a series resistor of 10K or something between Vbus and the base of the transistor.
- Q1 as you have it in circuit right now will short BAT+ directly to ground. Did you intend to have a pull-up from BAT+ to EN instead of a short? If so, you forgot that
again an 10K resistor will do.
