Built-in JTAG is unable to automatically flash on ESP32-C3-DevKitC-02
blanchehermine
Re: Built-in JTAG is unable to automatically flash on ESP32-C3-DevKitC-02
Postby blanchehermine » Mon Mar 27, 2023 4:40 am
Could you see what happens when you manually run esptool forcing it to use the USB-JTAG-serial dance?
Yes, it flashes that way from the user app. And reset is also performed at the end of the flashing.
I had to modify that command to the following line in order for it to work:
esptool.py --chip esp32c3 -p COM37 -b 460800 --before=usb_reset --after=hard_reset write_flash --flash_mode dio --flash_freq 80m --flash_size 4MB 0x0 build/bootloader/bootloader.bin 0x10000 build/test.bin 0x8000 build/partition_table/partition-table.bin
Log:
Code: Untitled.bsh Select all
e:\ESP\projects\test>esptool.py --chip esp32c3 -p COM37 -b 460800 --before=usb_reset --after=hard_reset write_flash --flash_mode dio --flash_freq 80m --flash_size 4MB 0x0 build/bootloader/bootloader.bin 0x10000 build/test.bin 0x8000 build/partition_table/partition-table.bin
esptool.py v4.5.1
Serial port COM37
Connecting...
Chip is ESP32-C3 (revision v0.3)
Features: WiFi, BLE
Crystal is 40MHz
MAC: 7c:df:a1:b3:96:74
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
Configuring flash size...
Flash will be erased from 0x00000000 to 0x00004fff...
Flash will be erased from 0x00010000 to 0x0003cfff...
Compressed 20192 bytes to 12374...
Wrote 20192 bytes (12374 compressed) at 0x00000000 in 0.3 seconds (effective 545.7 kbit/s)...
Hash of data verified.
Compressed 181040 bytes to 96201...
Wrote 181040 bytes (96201 compressed) at 0x00010000 in 1.7 seconds (effective 845.3 kbit/s)...
Compressed 3072 bytes to 103...
Wrote 3072 bytes (103 compressed) at 0x00008000 in 0.1 seconds (effective 372.4 kbit/s)...
Leaving...
Hard resetting via RTS pin...
Some other notes:
- If you put the board manually into boot mode, then USB-JTAG COM-port disappears and you have to plug / unplug the cable several times before if finally re-appears.
- If flashed from the boot mode using that command, it doesn't reset into user app and stays in the boot mode after flashing (whereas when flashed from the user app, it resets properly).
Postby Sprite » Mon Mar 27, 2023 7:51 am
Hm, then that detection is what goes wrong. Aside from manually flashing, I unfortunately can't tell you how to fix it... Something is messing with esp-tool figuring out that it's actually talking to an USB device, but my knowledge of Windows doesn't go far enough to have any idea what that could be.
blanchehermine
Postby blanchehermine » Wed Mar 29, 2023 5:29 am
Ok, got it.
If it's a bug I hope it gets fixed in the future releases. Meanwhile I'll be using VSCode with OpenOCD.
