If that was really necessary, you'd use gptimer_set_raw_count(...).it is necessary that when the timer starts, an interruption immediately occurs
The exact frequency of the timer
MicroController
Re: The exact frequency of the timer
MicroController
How many bits in a row?I need to read data strictly simultaneously from 8 sensors via UART. Hardware UART is not suitable for this, so I'm writing my own.
For short data bursts of a few bytes, busy-polling may be a good option (no CPU time "wasted" for entering and exiting the ISR), like
uint32_t bit_cnt = byte_cnt * 10;
uint32_t start = esp_cpu_get_cycle_count();
for (uint32_t bit = bit_cnt; bit != 0; --bit) {
while( (esp_cpu_get_cycle_count() - start) < cpu_cycles_per_bit ) {
// Do nothing.
// Sample all 8 data lines, store result in buffer here.
start += cpu_cycles_per_bit; // Time for the next bit.
Thanks, I'll try.If that was really necessary, you'd use gptimer_set_raw_count(...).
It is necessary to send 8 bytes of a common command to the sensors, and receive 11 bytes at the same time from 8 sensors. With a speed of 115200. And repeat all this with a frequency of 100 Hz.How many bits in a row?
MicroController
And the data sent by all the sensors is synchronous and "in phase" to within a fraction of 1 bit?
Instead of using a timer at a fixed frequency, you can also investigate using the common GPIO interrupt (gpio_isr_register(...)) for all the RX signals; i.e., register all 8 input states + timestamp whenever any of the RX signals change. In the worst-case, this yields one (GPIO) interrupt per bit (e.g. when 0xAA is sent), but can avoid interrupts while no bits change (e.g. when 0xFF is sent). This also has the benefit of being "naturally" synchronized to the (start of the) RX signals.
However, 11 bytes is less than 1 ms @ 115200bps, so I wouldn't have too many concerns with trying the busy-polling approach which makes more CPU time available for processing each bit before the next one arrives, if that matters.
Just checking: the bitrate sounds suspiciously like something you should use an UART for... isn't that an option?
Yes, initially I planned to use a hardware UART. But it only works with one RX, and I need 8 at the same time. That is, so that each clock cycle is read not 1 bit, but 8 bits in parallel.Just checking: the bitrate sounds suspiciously like something you should use an UART for... isn't that an option?
MicroController
Timer-triggered GPIO DMA would be a great feature to have in future ESPs
I ran into such a problem: when issuing 8 bytes of a command sequentially through one GPIO on a timer, some other processes are periodically wedged into the process. As a result, timings are broken, and some commands are not recognized. How can I prohibit all other interrupts except the timer for the time of issuing the command? Not FreeRTOS, I haven't grown up to it yet. As simple as possible.
I disable interrupts via esp_intr_noniram_disable before forming the command and then turn it back on. It has become noticeably better, but there remains some process that blocks transmission for 40 ms once every 5 seconds. Disabled WDT in the config. What can influence this?
Users browsing this forum: meta-externalagent, Qwantbot and 2 guests
