Programming in C++
rosimildo
Re: Programming in C++
Postby rosimildo » Fri Dec 09, 2016 12:39 am
If I use any std C++ stuff, and I include "stdc++ library, I get this link error:
/opt/esp32/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/4.8.5/../../../../xtensa-esp32-elf/lib/libstdc++.a(vterminate.o):(.literal._ZN9__gnu_cxx27__verbose_terminate_handlerEv+0x8): undefined reference to `_impure_ptr'
collect2: error: ld returned 1 exit status
Does anyone knows how to solve it ?
If I remove the references to "std::string" for example and don't link "stdc++", the program links fine.
kolban
Postby kolban » Thu Jan 12, 2017 11:19 pm
bump ... I just ran into the exact same issue.
WiFive
Postby WiFive » Thu Jan 12, 2017 11:26 pm
kolban
Postby kolban » Sun Mar 05, 2017 4:39 pm
Earlier in this thread there was a discussion on the naming conflicts in a C++ application if we try and create methods with the same names as LWIP #defines. For example, if I try and create a method called "connect" or "close" or "send" we fail because those appear to be #defined against the lwip functions. Has anyone found a workaround? Espressif commented back in November that they had an idea as to a way to fix but didn't elaborate on it.
Beck-Sisyphus
Postby Beck-Sisyphus » Sun May 14, 2017 1:17 pm
Hi ESP_igrr and kolban,
May I know the current process to support C++11 thread/concurrency library?
I wish to perform matrix operations in ESP32, and C++"Eigen.h" library would be a good fit. Eigen does depends on a C library called LAPACK, but I failed to link the library to my program, and LAPACK wasn't friendly for starters. Does looking forward for a guide to setup the Makefile to compile C++ library in the main project.
Best,
Beck
kolban
Postby kolban » Sun May 14, 2017 3:35 pm
While the C++ standard library does provide a "threading model" ... see for example:
http://www.cplusplus.com/reference/thread/thread/
To the best of my knowledge this has not been mapped in the ESP-IDF to the FreeRTOS "task" model. Thus if you have pre-existing (non ESP32 originated code) that leverages the "std::thread" class, it won't work (opinion). In theory, it would be possible to map the C++ threading packages to FreeRTOS but I have no knowledge of whether that is a task to be attempted.
igrr
Postby igrr » Mon May 15, 2017 11:10 am
Mapping STL concurrency library to FreeRTOS is possible, and has been done in some other MCU programming environments, but we don't have this feature planned at the moment.
gigijoe
Postby gigijoe » Fri Aug 04, 2017 10:25 am
Hello
I rename the main.c to main.cpp but the compiler just want main.c ...
$ make
CC main.o
xtensa-esp32-elf-gcc: error: /home/gigijoe/ESP32/SGM9200/main/./main.c: No such file or directory
xtensa-esp32-elf-gcc: fatal error: no input files
compilation terminated.
I'm running with latest SDK, any one have idea ?
kolban
Postby kolban » Mon Aug 07, 2017 4:57 am
I have sometimes seen that if one renames a source from X.c to X.cpp but has not issued a "make clean" then the build system seems to somehow "remember" that source was once "X.c". Can you try a "make clean" and then a full re-build and see if that helps?
gigijoe
Postby gigijoe » Mon Aug 07, 2017 11:19 am
Hello kolban
Yes, make clean works
Now the build system compile main.cpp
Thank you
Users browsing this forum: Baidu [Spider], ChatGPT-User, Google [Bot] and 2 guests
