Mysterious voltage drop when ESP32 board is connected
Re: Mysterious voltage drop when ESP32 board is connected
Postby Sprite » Fri Nov 24, 2017 8:29 am
Linear regulation (including the solution with resistors you chose earlier, given you choose resistors low enough to work) will always burn off the excess voltage as heat; no way around that. Look into switched mode power supplies for something that generates less hear; you can get modules like the Murata 7805SR that are plug-in replacements for the 7805 you already use.
Users browsing this forum: Amazon [Bot], Applebot, ChatGPT-User, PerplexityBot, Qwantbot, Semrush [Bot] and 3 guests
