The TWAI error message happens when I turn on task watchdog. I have no clue why that is happening but is not the foremost concern. I'm concerned about the MQTT hardlocks.E.g., this log message
"E (5056) McuCanBusChannel_Esp32: FAILED to Queue TWAI Message for Transmit!"
before the reboot, is that expected to be happening?
If not, I'd first go looking into where/why this happens, checking (error) return values to locate and identify the problem.
I'm not in a position to post my entire codebase for my project. What I posted above was meant to just show how I've been mitigating the issue.
Here is the entirety of the MCU layer I have for my MQTT subsystem:
static void MCU_Default_MQTT5EventRouter(void *handler_args, esp_event_base_t base, int32_t event_id, void *event_data);
// Class Constructor
MCU_MQTT_Client_ESP32::MCU_MQTT_Client_ESP32(void)
esp_log_level_set( MCU_LOG_Tag, MQTT_MCU_CLIENT_LOG_LEVEL);
esp_log_level_set( "mqtt5_client", MQTT_ESP32API_CLIENT_LOG_LEVEL);
esp_log_level_set( "MQTT5EventHandler", MQTT_MCU_CLIENT_LOG_LEVEL);
ESP_LOGI(MCU_LOG_Tag, "[0x%p] MCU_MQTT_Client_ESP32 Startup..", this);
// Link User Property Array and Conection Property Structures for use by class.
void MCU_MQTT_Client_ESP32::SET_PropertyStructures_ESP32( esp_mqtt5_user_property_item_t UserProperties[], int NumItems, esp_mqtt_client_config_t *mqtt5_cfg, esp_mqtt5_connection_property_config_t* ConnConfig )
ESP_LOGI(MCU_LOG_Tag, "SET_PropertyStructures_ESP32 [0x%p]", UserProperties);
UserPropertyArray = UserProperties;
UserPropertyArrayLength = NumItems;
ESP_LOGI(MCU_LOG_Tag, "[0x%p] Publish_ESP32: UserPropertyArray=[%p %d]", this, UserPropertyArray, UserPropertyArrayLength );
MQTT5_ConnectionConfig = mqtt5_cfg;
MQTT5_ConnectionProperty = ConnConfig;
// Set Broker Connection Info
void MCU_MQTT_Client_ESP32::SET_BrokerConnInfo_ESP32( std::string BrokerURI, std::string UserName, std::string Password)
strcpy( (char*)MQTT5_ConnectionConfig->broker.address.uri, BrokerURI.c_str() );
strcpy( (char*)MQTT5_ConnectionConfig->credentials.username, UserName.c_str() );
strcpy( (char*)MQTT5_ConnectionConfig->credentials.authentication.password, Password.c_str());
MQTT5_ConnectionConfig->network.disable_auto_reconnect = true; // TODO: Set These externally?
// Set Last Will Info
// TODO: Set up Will Topic to use the standard formatting once we have it.
void MCU_MQTT_Client_ESP32::SET_LastWillInfo_ESP32( std::string TopicBase, std::string WillMsg )
strcpy( (char*)MQTT5_ConnectionConfig->session.last_will.topic, (TopicBase + "/lastwill").c_str() );
strcpy( (char*)MQTT5_ConnectionConfig->session.last_will.msg, WillMsg.c_str() );
MQTT5_ConnectionConfig->session.last_will.msg_len = WillMsg.length();
MQTT5_ConnectionConfig->session.last_will.qos = 1; // TODO: Set These externally?
MQTT5_ConnectionConfig->session.last_will.retain = true; // TODO: Set These externally?
// MQTT Client Connection Process
esp_mqtt_client_handle_t MCU_MQTT_Client_ESP32::MCU_init(void)
#ifdef MAGIC_HARDLOCK_FIX_A
ESP_LOGV(MCU_LOG_Tag, "esp_mqtt_client_init...");
#endif
client_handle = esp_mqtt_client_init(MQTT5_ConnectionConfig);
#ifdef MAGIC_HARDLOCK_FIX_B
ESP_LOGV(MCU_LOG_Tag, "esp_mqtt5_client_set_user_properties...");
#endif
esp_mqtt5_client_set_user_property(&MQTT5_ConnectionProperty->user_property, UserPropertyArray, UserPropertyArrayLength);
esp_mqtt5_client_set_user_property(&MQTT5_ConnectionProperty->will_user_property, UserPropertyArray, UserPropertyArrayLength);
#ifdef MAGIC_HARDLOCK_FIX_C
ESP_LOGV(MCU_LOG_Tag, "esp_mqtt5_client_set_connect_property...");
#endif
esp_mqtt5_client_set_connect_property(client_handle, MQTT5_ConnectionProperty);
#ifdef MAGIC_HARDLOCK_FIX_D
ESP_LOGV(MCU_LOG_Tag, "esp_mqtt5_client_delete_user_property...");
#endif
esp_mqtt5_client_delete_user_property(MQTT5_ConnectionProperty->user_property);
esp_mqtt5_client_delete_user_property(MQTT5_ConnectionProperty->will_user_property);
#ifdef MAGIC_HARDLOCK_FIX_E
ESP_LOGV(MCU_LOG_Tag, "esp_mqtt_client_register_event...");
#endif
esp_mqtt_client_register_event(client_handle, (esp_mqtt_event_id_t)ESP_EVENT_ANY_ID, MCU_Default_MQTT5EventRouter, (void *)this);
ESP_LOGD(MCU_LOG_Tag, "MCU_MQTT_Client_ESP32::MCU_init() == %p", client_handle );
#endif
return client_handle;
void MCU_MQTT_Client_ESP32::MCU_Connect(void)
ESP_LOGD(MCU_LOG_Tag, "[%p:%u] Connecting to MQTT Broker... %p", this, __LINE__, client_handle);
#endif
vTaskDelay(50);
esp_err_t ret = esp_mqtt_client_start(client_handle);
if(ret)
ESP_LOGE(MCU_LOG_Tag, "Could not start MQTT Client!");
else
ESP_LOGI(MCU_LOG_Tag, " MCU_MQTT_Client_ESP32 Connected with Client Handle: [%p]", client_handle);
void MCU_MQTT_Client_ESP32::MCU_Disonnect(void)
ESP_LOGD(MCU_LOG_Tag, "Disconnecting from MQTT Broker...");
#endif
esp_mqtt_client_stop(client_handle);
ESP_LOGI(MCU_LOG_Tag, " MCU_MQTT_Client_ESP32 disconnected.");
#endif
// MQTT Subscrition Activation
// TRIMMED VERSION - culled out the Subscriber Properties parts
void MCU_MQTT_Client_ESP32::Subscribe_ESP32(void* MCUClientHandle, char* Topic, int QoS )
ESP_LOGD(MCU_LOG_Tag, "[0x%p] MCU_MQTT_PubSub_ESP32 Subscribing...", this);
#endif
esp_mqtt_client_handle_t tClient = (esp_mqtt_client_handle_t)MCUClientHandle;
ESP_LOGV(MCU_LOG_Tag, " esp_mqtt_client_subscribe...");
#endif
int msg_id = esp_mqtt_client_subscribe(tClient, Topic, QoS);
ESP_LOGD(MCU_LOG_Tag, ESC_FGCOLOR_BRIGHT_YELLOW "[0x%p] MCU_MQTT_PubSub_ESP32 Subscribed! (msg_id=%d)", this, msg_id);
#endif
// MQTT Publish Topic
void MCU_MQTT_Client_ESP32::Publish_ESP32( void* MCUClientHandle, char* Topic, char* Message, int QoS, int RetainTopic )
ESP_LOGV(MCU_LOG_Tag, "[0x%p] MCU_MQTT_PubSub_ESP32 Publishing...[%s]", this, Topic);
ESP_LOGV(MCU_LOG_Tag, "[0x%p] Publish_ESP32: UserPropertyArray=[%p %d]", this, UserPropertyArray, UserPropertyArrayLength );
ESP_LOGV(MCU_LOG_Tag, "[0x%p] Publish_ESP32: MCUClientHandle=[%p]", this, MCUClientHandle);
ESP_LOGV(MCU_LOG_Tag, "[0x%p] Publish_ESP32: PubTopic=%s", this, Topic );
ESP_LOGV(MCU_LOG_Tag, "[0x%p] Publish_ESP32: PubMessage=[%s]", this, Message );
ESP_LOGV(MCU_LOG_Tag, "[0x%p] Publish_ESP32: PubQoS=[%d]", this, QoS );
#endif
ESP_LOGV(MCU_LOG_Tag, " esp_mqtt_client_publish... [%p]", tClient);
#endif
#ifndef MQTT_MCU_NPUBLISH_ENQUEUE
int msg_id = esp_mqtt_client_publish(tClient, Topic, Message, 0, QoS, RetainTopic);
#else
int msg_id = esp_mqtt_client_enqueue(tClient, Topic, Message, 0, QoS, RetainTopic, true);
#endif
ESP_LOGD(MCU_LOG_Tag, ESC_BGCOLOR_BRIGHT_WHITE ESC_FGCOLOR_BRIGHT_BLUE "[0x%p] MCU_MQTT_PubSub_ESP32 Published! (msg_id=%d) [%s]" ESC_FGCOLOR_DEFAULT ESC_BGCOLOR_DEFAULT "\n\n" , this, msg_id, Topic);
#endif
msg_id = msg_id + 1;
// Get the User Propery Array pointer
esp_mqtt5_user_property_item_t* MCU_MQTT_Client_ESP32::GET_UserPropertyArray(void)
return UserPropertyArray;
// Get the User Propery Array Length
int MCU_MQTT_Client_ESP32::GET_UserPropertyArrayLength(void)
return UserPropertyArrayLength;
// Overridable Event Router
void MCU_MQTT_Client_ESP32::EventRouter(void)
ESP_LOGE(MCU_LOG_Tag, "MCU_MQTT_Client_ESP32 Default EventRouter EventID=%ld EventData=%p", LastEventID, LastEventData);
// HandleEvent_ESP32
// This function stores incoming MQTT Events and notifies overridable
// event router for event processing.
void MCU_MQTT_Client_ESP32::HandleEvent_ESP32(void *handler_args, esp_event_base_t base, int32_t event_id, void *event_data)
LastEventData = event_data;
LastEventID = event_id;
LastEventReady = true;
EventRouter();
// Static Non-Class Event Router
MCU_MQTT_Client_ESP32 *oClient = (MCU_MQTT_Client_ESP32 *)handler_args;
// ESP_LOGD("MQTT5EventHandler", "[DEFAULT] [0x%p] Event dispatched from event loop base=%s, event_id=%" PRIi32, oClient, base, event_id);
ESP_LOGD("MQTT5EventHandler", "[DEFAULT] [0x%p] Event dispatched from event loop base=%s, event_id=%", oClient, base, event_id);
#endif
oClient->HandleEvent_ESP32(handler_args, base, event_id, event_data);
}Code: Select all
esp_mqtt5_user_property_item_t esp32_mqtt_user_property_array[] = {
{"board", "esp32"},
{"u", "user"},
{"p", "password"}
esp_mqtt_client_config_t esp32_mqtt_connection_config = {
// .broker.address.uri = CONFIG_BROKER_URL,
// .broker.address.uri = "mqtts://mqtt-emqx.earthfuneral.tech",
.broker.address.uri = "mqtts://example.com",
.session.protocol_ver = MQTT_PROTOCOL_V_5,
.network.disable_auto_reconnect = true,
.credentials.username = "",
.credentials.authentication.password = "",
.session.last_will.topic = "/topic/will",
.session.last_will.msg = "i will leave",
.session.last_will.msg_len = 12,
.session.last_will.qos = 1,
.session.last_will.retain = true,
esp_mqtt5_connection_property_config_t esp32_mqtt_connection_property = {
.session_expiry_interval = 10,
.maximum_packet_size = 1024,
.receive_maximum = 65535,
.topic_alias_maximum = 2,
.request_resp_info = true,
.request_problem_info = true,
.will_delay_interval = 10,
.payload_format_indicator = true,
.message_expiry_interval = 10,
.response_topic = "/test/response",
.correlation_data = "",
.correlation_data_len = 0,
Hardlocks occur at the exact same spot for each build (but often different between builds depending on which ESP_LOG lines are active), but it is always when MQTT Connects, Subscribes, Publishes, or Receives using the functions in the code block provided here.
Thanks for looking.
