Re: help with bundles for GPIO
Posted: Fri Jun 21, 2024 7:18 pm
Correct. That's why you may want to use open drain mode.in both output input mode, setting the output high, reading the input is kind of pointless because it will also be high same as low.
For a better understanding, I suggest you look at the GPIO matrix and IOMUX in the TRM. It shows which settings/bits affect a pin at which level.
As I said: Tri-stating a pin means disabling its output, which is done via bits in the IOMUX's registers, not via the dedicated GPIO port of the CPU.but then how to clear bits, I can only write a bit.
Not really. There is no requirement for a register to read the same value which was written to it.If the input and output can co-exist then we need two registers for that, not one
For example, in the ESPs there are a few hardware FIFO buffers, each accessed via a single register so that a write enqueues data to be sent while a read retrieves data previously received.
