Update 1:ESP32-S3 - TinyUSB - mouse: scroll wheel does not work when mouse is connected to ESP32-S3,but works if to a PC
sraposo
Re: Update 1:ESP32-S3 - TinyUSB - mouse: scroll wheel does not work when mouse is connected to ESP32-S3,but works if to
Postby sraposo » Thu Jan 23, 2025 4:30 am
All you are talking about is still USB specification related and has nothing to do with HID report and data structure which mouse is sending.
Espressif usb hid mouse driver is very simple one (just guessing, never tested it) and probably wont wont with mice when cursor data and wheel data are sent with different report ID, not as one data.
This is example of HID report
    0x05, 0x01,    // UsagePage(Generic Desktop[1])
    0x09, 0x04,    // UsageId(Joystick[4])
    0xA1, 0x01,    // Collection(Application)
    0x85, 0x01,    //     ReportId(1)
    0x09, 0x01,    //     UsageId(Pointer[1])
    0xA1, 0x00,    //     Collection(Physical)
    0x09, 0x30,    //         UsageId(X[48])
    0x09, 0x31,    //         UsageId(Y[49])
    0x15, 0x80,    //         LogicalMinimum(-128)
    0x25, 0x7F,    //         LogicalMaximum(127)
    0x95, 0x02,    //         ReportCount(2)
    0x75, 0x08,    //         ReportSize(8)
    0x81, 0x02,    //         Input(Data, Variable, Absolute, NoWrap, Linear, PreferredState, NoNullPosition, BitField)
    0x05, 0x09,    //         UsagePage(Button[9])
    0x19, 0x01,    //         UsageIdMin(Button 1[1])
    0x29, 0x03,    //         UsageIdMax(Button 3[3])
    0x15, 0x00,    //         LogicalMinimum(0)
    0x25, 0x01,    //         LogicalMaximum(1)
    0x95, 0x03,    //         ReportCount(3)
    0x75, 0x01,    //         ReportSize(1)
    0xC0,          //     EndCollection()
    0x05, 0x02,    //     UsagePage(Simulation Controls[2])
    0x09, 0xBB,    //     UsageId(Throttle[187])
    0x95, 0x01,    //     ReportCount(1)
    0x75, 0x05,    //     ReportSize(5)
    0x81, 0x03,    //     Input(Constant, Variable, Absolute, NoWrap, Linear, PreferredState, NoNullPosition, BitField)
Its for joystick, but it is to show you what i mean.
I already found, studied and made experimentation on this data collection and it was a waste of time.
Manoel and me are not questioning Espressif usb hid mouse driver, but where that scroll wheel data can be read from those mice that (seemingly) don't comply to a usual/simple standard.
As I said in my previous reply, a separate report is likely, but it also seems to me that mouse's driver send mouse some report to activate/signal something that will make mouse send the scroll wheel data. Why do I say that? Because no event is got from mouse that could be related to the scroll wheel.
chegewara
Postby chegewara » Thu Jan 23, 2025 4:36 am
Ok, i see i cant explain it better than that:
You cant get any "signals" from espressif component you because it is not supporting this kind of devices (it is not universal driver).
PS it is possible to make mouse which will report X and Y axis in separate report/packet, which will works perfectly fine on any OS, but wont work at all on esp32 due to driver limitations
Manoel
Postby Manoel » Thu Jan 23, 2025 11:15 am
There is a possibility that it might be a device that is not fully compatible with HID, but I really don't believe that because, in my case, I tested more than six different manufacturers (all simple three-button mice), and only one of them worked. Unless the vast majority of manufacturers have decided to stop using HID, which seems unlikely. I reported three of them so we can better understand them. In my opinion, the issue lies in how the ESP is receiving (or indicating how it should receive) the data—always with 4 BYTES.
Example of Hid data received MOUSE 1:
Right button pressed: Windows = 0200000000; ESP32 = 02000000
Left button pressed: Windows = 0100000000; ESP32 = 01000000
Result:
ESP32: Scroll does not work (Information is in the last Byte and is not received)
Windows: Everything works normally.
Example of Hid data received MOUSE 2:
Right button pressed: Windows = 02000000; ESP32 = 02000000
Left button pressed: Windows = 01000000; ESP32 = 01000000
Result:
ESP32: Everything works normally.
Example of Hid data received MOUSE 3:
Right button pressed: Windows = 010200000000; ESP32 = 02000000
Left button pressed: Windows = 010100000000; ESP32 = 01000000
Result:
HID Report.
Mouse 1
0x1c, 0x00, 0x10, 0xd0, 0x54, 0x43, 0x8e, 0xd9, 0xff, 0xff, 0x00, 0x00, 0x00, 0x00, 0x08, 0x00,
0x01, 0x01, 0x00, 0x2c, 0x00, 0x80, 0x02, 0x40, 0x00, 0x00, 0x00, 0x03, 0x05, 0x01, 0x09, 0x02,
0xa1, 0x01, 0x09, 0x01, 0xa1, 0x00, 0x05, 0x09, 0x19, 0x01, 0x29, 0x03, 0x15, 0x00, 0x25, 0x01,
0x95, 0x03, 0x75, 0x01, 0x81, 0x02, 0x95, 0x01, 0x75, 0x05, 0x81, 0x01, 0x05, 0x01, 0x09, 0x30,
0x09, 0x31, 0x16, 0x00, 0xf8, 0x26, 0xff, 0x07, 0x75, 0x0c, 0x95, 0x02, 0x81, 0x06, 0x09, 0x38,
0x15, 0x81, 0x25, 0x7f, 0x75, 0x08, 0x95, 0x01, 0x81, 0x06, 0xc0, 0xc0
0x1C,              // Unknown (bTag: 0x01, bType: 0x03)
0x00,              // Unknown (bTag: 0x00, bType: 0x00)
0x10,              // Unknown (bTag: 0x01, bType: 0x00)
0xD0,              // Unknown (bTag: 0x0D, bType: 0x00)
0x54,              // Unit Exponent
0x43, 0x8E, 0xD9, 0xFF, 0xFF,  // Unknown (bTag: 0x04, bType: 0x00)
0x08,              // Usage
0x01, 0x01,        // Unknown (bTag: 0x00, bType: 0x00)
0x2C,              // Unknown (bTag: 0x02, bType: 0x03)
0x80,              // Input
0x02, 0x40, 0x00,  // Unknown (bTag: 0x00, bType: 0x00)
0x03, 0x05, 0x01, 0x09, 0x02,  // Unknown (bTag: 0x00, bType: 0x00)
0xA1, 0x01,        // Collection (Application)
0x09, 0x01,        //   Usage (0x01)
0xA1, 0x00,        //   Collection (Physical)
0x05, 0x09,        //     Usage Page (Button)
0x19, 0x01,        //     Usage Minimum (0x01)
0x29, 0x03,        //     Usage Maximum (0x03)
0x15, 0x00,        //     Logical Minimum (0)
0x25, 0x01,        //     Logical Maximum (1)
0x95, 0x03,        //     Report Count (3)
0x75, 0x01,        //     Report Size (1)
0x81, 0x02,        //     Input (Data,Var,Abs,No Wrap,Linear,Preferred State,No Null Position)
0x95, 0x01,        //     Report Count (1)
0x75, 0x05,        //     Report Size (5)
0x81, 0x01,        //     Input (Const,Array,Abs,No Wrap,Linear,Preferred State,No Null Position)
0x05, 0x01,        //     Usage Page (Generic Desktop Ctrls)
0x09, 0x30,        //     Usage (X)
0x09, 0x31,        //     Usage (Y)
0x16, 0x00, 0xF8,  //     Logical Minimum (-2048)
0x26, 0xFF, 0x07,  //     Logical Maximum (2047)
0x75, 0x0C,        //     Report Size (12)
0x95, 0x02,        //     Report Count (2)
0x81, 0x06,        //     Input (Data,Var,Rel,No Wrap,Linear,Preferred State,No Null Position)
0x09, 0x38,        //     Usage (Wheel)
0x15, 0x81,        //     Logical Minimum (-127)
0x25, 0x7F,        //     Logical Maximum (127)
0x75, 0x08,        //     Report Size (8)
0xC0,              //   End Collection
Mouse 2
0x1c, 0x00, 0x20, 0xd9, 0xed, 0x3c, 0x8e, 0xd9, 0xff, 0xff, 0x00, 0x00, 0x00, 0x00, 0x08, 0x00,
0x01, 0x01, 0x00, 0x2d, 0x00, 0x80, 0x02, 0x34, 0x00, 0x00, 0x00, 0x03, 0x05, 0x01, 0x09, 0x02,
0xa1, 0x01, 0x09, 0x01, 0xa1, 0x00, 0x05, 0x09, 0x19, 0x01, 0x29, 0x05, 0x15, 0x00, 0x25, 0x01,
0x95, 0x05, 0x75, 0x01, 0x81, 0x02, 0x95, 0x01, 0x75, 0x03, 0x81, 0x01, 0x05, 0x01, 0x09, 0x30,
0x09, 0x31, 0x09, 0x38, 0x15, 0x81, 0x25, 0x7f, 0x75, 0x08, 0x95, 0x03, 0x81, 0x06, 0xc0, 0xc0
0x20,              // Unknown (bTag: 0x02, bType: 0x00)
0xD9, 0xED,        // Unknown (bTag: 0x0D, bType: 0x02)
0x3C,              // Unknown (bTag: 0x03, bType: 0x03)
0x8E, 0xD9, 0xFF,  // Unknown (bTag: 0x08, bType: 0x03)
0xFF, 0x00, 0x00, 0x00, 0x00,  // Unknown (bTag: 0x0F, bType: 0x03)
0x08,              // Usage
0x2D, 0x00,        // Unknown (bTag: 0x02, bType: 0x03)
0x80,              // Input
0x02, 0x34, 0x00,  // Unknown (bTag: 0x00, bType: 0x00)
0x29, 0x05,        //     Usage Maximum (0x05)
0x95, 0x05,        //     Report Count (5)
0x75, 0x03,        //     Report Size (3)
Mouse 3
0x1c, 0x00, 0x60, 0x6a, 0xda, 0x43, 0x8e, 0xd9, 0xff, 0xff, 0x00, 0x00, 0x00, 0x00, 0x08, 0x00,
0x01, 0x01, 0x00, 0x2f, 0x00, 0x80, 0x02, 0x42, 0x00, 0x00, 0x00, 0x03, 0x05, 0x01, 0x09, 0x02,
0xa1, 0x01, 0x85, 0x01, 0x09, 0x01, 0xa1, 0x00, 0x05, 0x09, 0x19, 0x01, 0x29, 0x03, 0x15, 0x00,
0x25, 0x01, 0x95, 0x03, 0x75, 0x01, 0x81, 0x02, 0x95, 0x01, 0x75, 0x05, 0x81, 0x01, 0x05, 0x01,
0x09, 0x30, 0x09, 0x31, 0x16, 0x00, 0xf8, 0x26, 0xff, 0x07, 0x75, 0x0c, 0x95, 0x02, 0x81, 0x06,
0x09, 0x38, 0x15, 0x81, 0x25, 0x7f, 0x75, 0x08, 0x95, 0x01, 0x81, 0x06, 0xc0, 0xc0
0x60,              // Unknown (bTag: 0x06, bType: 0x00)
0x6A, 0xDA, 0x43,  // Unknown (bTag: 0x06, bType: 0x02)
0x08,              // Usage
0x2F, 0x00, 0x80, 0x02, 0x42,  // Unknown (bTag: 0x02, bType: 0x03)
0x85, 0x01,        //   Report ID (1)
chegewara
Postby chegewara » Thu Jan 23, 2025 11:41 am
Ok, this is explanation:
this website is very good to check descriptors
https://eleccelerator.com/usbdescreqparser/
mouse 1 HID report/descriptor (for some reason it is not correct up)
0x09, 0x02,        // Usage (0x02)
// 62 bytes
- 1st byte is to report buttons state, 3 bits - 3 buttons and 5 bits reserved
- bytes 2-4 - 2x12 bits to report X and Y mouse movement (resolution 11 bit)
- last byte, 8 bits, to report wheel
mouse 2 HID report
// 50 bytes
- 1st byte - 5 bits buttons state, 3 bits reserved
- bytes 2-3 mouse move, X and Y (resolution 7 bits)
- last byte wheel
mouse 3 is interesting, because 1st byte is report ID - there is only one report ID and its value is always 1
// 64 bytes
- 1st byte report ID - always 1, because there is only 1 report ID in this descriptor
- bytes 2-5 like in mouse 1
I can only guessing that espressif component/driver is not handling properly data when values are not 8 bits aligned, but this is should espressif answer.
sraposo
Postby sraposo » Thu Jan 23, 2025 2:07 pm
@Manoel
Yep, there's something missing in ESP32 USB driver or it complies to some early version of HID specification, since Windows and Ubuntu are able to interpret scroll wheel moves even from these mice that only use 3 bytes to report mouse controls stati returned by function hid_host_device_get_raw_input_report_data.
I was not lucky enough to find in my quest some hidden byte elsewhere that has its value changed when the wheel is spun...
@chegewara
I have used that "USB Descriptor and Request Parser". Very handy, but was not enough to solve the problem.
Although hid_host_device_get_raw_input_report_data returns always 4 bytes related to mouse controls stati, only the first 3 are useful on these "non-standard" mice, since the forth keeps zero.
Maybe @ESP_Sprite may bring some light on this.
chegewara
Postby chegewara » Thu Jan 23, 2025 2:19 pm
Without seeing your code not even president Elon Musk (or Trump) can help you with that.
If you can post relevant code and maybe logs that may help us help you.
Manoel
Postby Manoel » Sat Jan 25, 2025 7:58 pm
Sorry for the delay, I wasn't home these days. My code is the basic example from ESP32 (esp-idf/examples/peripherals/usb/host/hid) with an addition of code on line 322. This modification allows the HID data output to be displayed. Below is the complete code as well.
static void hid_host_mouse_report_callback(const uint8_t *const data, const int length)
	for (int i = 0; i < length; i++) {
    printf("%02X", data[i]);
    putchar('\n');
    hid_mouse_input_report_boot_t *mouse_report = (hid_mouse_input_report_boot_t *)data;
    if (length < sizeof(hid_mouse_input_report_boot_t)) {
        return;
    static int x_pos = 0;
    static int y_pos = 0;
    // Calculate absolute position from displacement
    x_pos += mouse_report->x_displacement;
    y_pos += mouse_report->y_displacement;
    hid_print_new_device_report_header(HID_PROTOCOL_MOUSE);
    printf("X: %06d\tY: %06d\t|%c|%c|\r",
           x_pos, y_pos,
           (mouse_report->buttons.button1 ? 'o' : ' '),
           (mouse_report->buttons.button2 ? 'o' : ' '));
    fflush(stdout);
Complete code:
 * SPDX-FileCopyrightText: 2022-2023 Espressif Systems (Shanghai) CO LTD
 * SPDX-License-Identifier: Unlicense OR CC0-1.0
#include <stdio.h>
#include <stdbool.h>
#include <string.h>
#include <unistd.h>
#include "freertos/task.h"
#include "freertos/queue.h"
#include "esp_err.h"
#include "esp_log.h"
#include "usb/usb_host.h"
#include "errno.h"
#include "driver/gpio.h"
#include "usb/hid_host.h"
#include "usb/hid_usage_keyboard.h"
#include "usb/hid_usage_mouse.h"
/* GPIO Pin number for quit from example logic */
#define APP_QUIT_PIN                GPIO_NUM_0
static const char *TAG = "example";
QueueHandle_t app_event_queue = NULL;
 * @brief APP event group
 * Application logic can be different. There is a one among other ways to distingiush the
 * event by application event group.
 * In this example we have two event groups:
 * APP_EVENT            - General event, which is APP_QUIT_PIN press event (Generally, it is IO0).
 * APP_EVENT_HID_HOST   - HID Host Driver event, such as device connection/disconnection or input report.
typedef enum {
    APP_EVENT = 0,
    APP_EVENT_HID_HOST
} app_event_group_t;
 * @brief APP event queue
 * This event is used for delivering the HID Host event from callback to a task.
typedef struct {
    app_event_group_t event_group;
    /* HID Host - Device related info */
    struct {
        hid_host_device_handle_t handle;
        hid_host_driver_event_t event;
        void *arg;
    } hid_host_device;
} app_event_queue_t;
 * @brief HID Protocol string names
static const char *hid_proto_name_str[] = {
    "NONE",
    "KEYBOARD",
    "MOUSE"
 * @brief Key event
typedef struct {
    enum key_state {
        KEY_STATE_PRESSED = 0x00,
        KEY_STATE_RELEASED = 0x01
    } state;
    uint8_t modifier;
    uint8_t key_code;
} key_event_t;
/* Main char symbol for ENTER key */
#define KEYBOARD_ENTER_MAIN_CHAR    '\r'
/* When set to 1 pressing ENTER will be extending with LineFeed during serial debug output */
#define KEYBOARD_ENTER_LF_EXTEND    1
 * @brief Scancode to ascii table
const uint8_t keycode2ascii [57][2] = {
    {0, 0}, /* HID_KEY_NO_PRESS        */
    {0, 0}, /* HID_KEY_ROLLOVER        */
    {0, 0}, /* HID_KEY_POST_FAIL       */
    {0, 0}, /* HID_KEY_ERROR_UNDEFINED */
    {'a', 'A'}, /* HID_KEY_A               */
    {'b', 'B'}, /* HID_KEY_B               */
    {'c', 'C'}, /* HID_KEY_C               */
    {'d', 'D'}, /* HID_KEY_D               */
    {'e', 'E'}, /* HID_KEY_E               */
    {'f', 'F'}, /* HID_KEY_F               */
    {'g', 'G'}, /* HID_KEY_G               */
    {'h', 'H'}, /* HID_KEY_H               */
    {'i', 'I'}, /* HID_KEY_I               */
    {'j', 'J'}, /* HID_KEY_J               */
    {'k', 'K'}, /* HID_KEY_K               */
    {'l', 'L'}, /* HID_KEY_L               */
    {'m', 'M'}, /* HID_KEY_M               */
    {'n', 'N'}, /* HID_KEY_N               */
    {'o', 'O'}, /* HID_KEY_O               */
    {'p', 'P'}, /* HID_KEY_P               */
    {'q', 'Q'}, /* HID_KEY_Q               */
    {'r', 'R'}, /* HID_KEY_R               */
    {'s', 'S'}, /* HID_KEY_S               */
    {'t', 'T'}, /* HID_KEY_T               */
    {'u', 'U'}, /* HID_KEY_U               */
    {'v', 'V'}, /* HID_KEY_V               */
    {'w', 'W'}, /* HID_KEY_W               */
    {'x', 'X'}, /* HID_KEY_X               */
    {'y', 'Y'}, /* HID_KEY_Y               */
    {'z', 'Z'}, /* HID_KEY_Z               */
    {'1', '!'}, /* HID_KEY_1               */
    {'2', '@'}, /* HID_KEY_2               */
    {'3', '#'}, /* HID_KEY_3               */
    {'4', '$'}, /* HID_KEY_4               */
    {'5', '%'}, /* HID_KEY_5               */
    {'6', '^'}, /* HID_KEY_6               */
    {'7', '&'}, /* HID_KEY_7               */
    {'8', '*'}, /* HID_KEY_8               */
    {'9', '('}, /* HID_KEY_9               */
    {'0', ')'}, /* HID_KEY_0               */
    {KEYBOARD_ENTER_MAIN_CHAR, KEYBOARD_ENTER_MAIN_CHAR}, /* HID_KEY_ENTER           */
    {0, 0}, /* HID_KEY_ESC             */
    {'\b', 0}, /* HID_KEY_DEL             */
    {0, 0}, /* HID_KEY_TAB             */
    {' ', ' '}, /* HID_KEY_SPACE           */
    {'-', '_'}, /* HID_KEY_MINUS           */
    {'=', '+'}, /* HID_KEY_EQUAL           */
    {'[', '{'}, /* HID_KEY_OPEN_BRACKET    */
    {']', '}'}, /* HID_KEY_CLOSE_BRACKET   */
    {'\\', '|'}, /* HID_KEY_BACK_SLASH      */
    {'\\', '|'}, /* HID_KEY_SHARP           */  // HOTFIX: for NonUS Keyboards repeat HID_KEY_BACK_SLASH
    {';', ':'}, /* HID_KEY_COLON           */
    {'\'', '"'}, /* HID_KEY_QUOTE           */
    {'`', '~'}, /* HID_KEY_TILDE           */
    {',', '<'}, /* HID_KEY_LESS            */
    {'.', '>'}, /* HID_KEY_GREATER         */
    {'/', '?'} /* HID_KEY_SLASH           */
 * @brief Makes new line depending on report output protocol type
 * @param[in] proto Current protocol to output
static void hid_print_new_device_report_header(hid_protocol_t proto)
    static hid_protocol_t prev_proto_output = -1;
    if (prev_proto_output != proto) {
        prev_proto_output = proto;
        printf("\r\n");
        if (proto == HID_PROTOCOL_MOUSE) {
            printf("Mouse\r\n");
        } else if (proto == HID_PROTOCOL_KEYBOARD) {
            printf("Keyboard\r\n");
            printf("Generic\r\n");
        fflush(stdout);
 * @brief HID Keyboard modifier verification for capitalization application (right or left shift)
 * @param[in] modifier
 * @return true  Modifier was pressed (left or right shift)
 * @return false Modifier was not pressed (left or right shift)
static inline bool hid_keyboard_is_modifier_shift(uint8_t modifier)
    if (((modifier & HID_LEFT_SHIFT) == HID_LEFT_SHIFT) ||
            ((modifier & HID_RIGHT_SHIFT) == HID_RIGHT_SHIFT)) {
        return true;
    return false;
 * @brief HID Keyboard get char symbol from key code
 * @param[in] modifier  Keyboard modifier data
 * @param[in] key_code  Keyboard key code
 * @param[in] key_char  Pointer to key char data
 * @return true  Key scancode converted successfully
 * @return false Key scancode unknown
static inline bool hid_keyboard_get_char(uint8_t modifier,
                                         uint8_t key_code,
                                         unsigned char *key_char)
    uint8_t mod = (hid_keyboard_is_modifier_shift(modifier)) ? 1 : 0;
    if ((key_code >= HID_KEY_A) && (key_code <= HID_KEY_SLASH)) {
        *key_char = keycode2ascii[key_code][mod];
        // All other key pressed
        return false;
    return true;
 * @brief HID Keyboard print char symbol
 * @param[in] key_char  Keyboard char to stdout
static inline void hid_keyboard_print_char(unsigned int key_char)
    if (!!key_char) {
        putchar(key_char);
#if (KEYBOARD_ENTER_LF_EXTEND)
        if (KEYBOARD_ENTER_MAIN_CHAR == key_char) {
            putchar('\n');
#endif // KEYBOARD_ENTER_LF_EXTEND
        fflush(stdout);
 * @brief Key Event. Key event with the key code, state and modifier.
 * @param[in] key_event Pointer to Key Event structure
static void key_event_callback(key_event_t *key_event)
    unsigned char key_char;
    hid_print_new_device_report_header(HID_PROTOCOL_KEYBOARD);
    if (KEY_STATE_PRESSED == key_event->state) {
        if (hid_keyboard_get_char(key_event->modifier,
                                  key_event->key_code, &key_char)) {
            hid_keyboard_print_char(key_char);
 * @brief Key buffer scan code search.
 * @param[in] src       Pointer to source buffer where to search
 * @param[in] key       Key scancode to search
 * @param[in] length    Size of the source buffer
static inline bool key_found(const uint8_t *const src,
                             uint8_t key,
                             unsigned int length)
    for (unsigned int i = 0; i < length; i++) {
        if (src[i] == key) {
            return true;
    return false;
 * @brief USB HID Host Keyboard Interface report callback handler
 * @param[in] data    Pointer to input report data buffer
 * @param[in] length  Length of input report data buffer
static void hid_host_keyboard_report_callback(const uint8_t *const data, const int length)
    hid_keyboard_input_report_boot_t *kb_report = (hid_keyboard_input_report_boot_t *)data;
    if (length < sizeof(hid_keyboard_input_report_boot_t)) {
        return;
    static uint8_t prev_keys[HID_KEYBOARD_KEY_MAX] = { 0 };
    key_event_t key_event;
    for (int i = 0; i < HID_KEYBOARD_KEY_MAX; i++) {
        // key has been released verification
        if (prev_keys[i] > HID_KEY_ERROR_UNDEFINED &&
                !key_found(kb_report->key, prev_keys[i], HID_KEYBOARD_KEY_MAX)) {
            key_event.key_code = prev_keys[i];
            key_event.modifier = 0;
            key_event.state = KEY_STATE_RELEASED;
            key_event_callback(&key_event);
        // key has been pressed verification
        if (kb_report->key[i] > HID_KEY_ERROR_UNDEFINED &&
                !key_found(prev_keys, kb_report->key[i], HID_KEYBOARD_KEY_MAX)) {
            key_event.key_code = kb_report->key[i];
            key_event.modifier = kb_report->modifier.val;
            key_event.state = KEY_STATE_PRESSED;
    memcpy(prev_keys, &kb_report->key, HID_KEYBOARD_KEY_MAX);
 * @brief USB HID Host Mouse Interface report callback handler
    putchar('\n');
        return;
           x_pos, y_pos,
    fflush(stdout);
 * @brief USB HID Host Generic Interface report callback handler
 * 'generic' means anything else than mouse or keyboard
static void hid_host_generic_report_callback(const uint8_t *const data, const int length)
    hid_print_new_device_report_header(HID_PROTOCOL_NONE);
    putchar('\r');
 * @brief USB HID Host interface callback
 * @param[in] hid_device_handle  HID Device handle
 * @param[in] event              HID Host interface event
 * @param[in] arg                Pointer to arguments, does not used
void hid_host_interface_callback(hid_host_device_handle_t hid_device_handle,
                                 const hid_host_interface_event_t event,
                                 void *arg)
    uint8_t data[64] = { 0 };
    size_t data_length = 0;
    hid_host_dev_params_t dev_params;
    ESP_ERROR_CHECK(hid_host_device_get_params(hid_device_handle, &dev_params));
    switch (event) {
    case HID_HOST_INTERFACE_EVENT_INPUT_REPORT:
        ESP_ERROR_CHECK(hid_host_device_get_raw_input_report_data(hid_device_handle,
        data,
        64,
        &data_length));
        if (HID_SUBCLASS_BOOT_INTERFACE == dev_params.sub_class) {
            if (HID_PROTOCOL_KEYBOARD == dev_params.proto) {
                hid_host_keyboard_report_callback(data, data_length);
            } else if (HID_PROTOCOL_MOUSE == dev_params.proto) {
                hid_host_mouse_report_callback(data, data_length);
            hid_host_generic_report_callback(data, data_length);
    case HID_HOST_INTERFACE_EVENT_DISCONNECTED:
        ESP_LOGI(TAG, "HID Device, protocol '%s' DISCONNECTED",
                 hid_proto_name_str[dev_params.proto]);
        ESP_ERROR_CHECK(hid_host_device_close(hid_device_handle));
    case HID_HOST_INTERFACE_EVENT_TRANSFER_ERROR:
        ESP_LOGI(TAG, "HID Device, protocol '%s' TRANSFER_ERROR",
    default:
        ESP_LOGE(TAG, "HID Device, protocol '%s' Unhandled event",
 * @brief USB HID Host Device event
 * @param[in] event              HID Host Device event
void hid_host_device_event(hid_host_device_handle_t hid_device_handle,
                           const hid_host_driver_event_t event,
                           void *arg)
    switch (event) {
    case HID_HOST_DRIVER_EVENT_CONNECTED:
        ESP_LOGI(TAG, "HID Device, protocol '%s' CONNECTED",
        const hid_host_device_config_t dev_config = {
            .callback = hid_host_interface_callback,
            .callback_arg = NULL
        ESP_ERROR_CHECK(hid_host_device_open(hid_device_handle, &dev_config));
            ESP_ERROR_CHECK(hid_class_request_set_protocol(hid_device_handle, HID_REPORT_PROTOCOL_BOOT));
                ESP_ERROR_CHECK(hid_class_request_set_idle(hid_device_handle, 0, 0));
        ESP_ERROR_CHECK(hid_host_device_start(hid_device_handle));
    default:
 * @brief Start USB Host install and handle common USB host library events while app pin not low
 * @param[in] arg  Not used
static void usb_lib_task(void *arg)
    const usb_host_config_t host_config = {
        .skip_phy_setup = false,
        .intr_flags = ESP_INTR_FLAG_LEVEL1,
    ESP_ERROR_CHECK(usb_host_install(&host_config));
    xTaskNotifyGive(arg);
    while (true) {
        uint32_t event_flags;
        usb_host_lib_handle_events(portMAX_DELAY, &event_flags);
        // In this example, there is only one client registered
        // So, once we deregister the client, this call must succeed with ESP_OK
        if (event_flags & USB_HOST_LIB_EVENT_FLAGS_NO_CLIENTS) {
            ESP_ERROR_CHECK(usb_host_device_free_all());
    ESP_LOGI(TAG, "USB shutdown");
    // Clean up USB Host
    vTaskDelay(10); // Short delay to allow clients clean-up
    ESP_ERROR_CHECK(usb_host_uninstall());
    vTaskDelete(NULL);
 * @brief BOOT button pressed callback
 * Signal application to exit the HID Host task
 * @param[in] arg Unused
static void gpio_isr_cb(void *arg)
    BaseType_t xTaskWoken = pdFALSE;
    const app_event_queue_t evt_queue = {
        .event_group = APP_EVENT,
    if (app_event_queue) {
        xQueueSendFromISR(app_event_queue, &evt_queue, &xTaskWoken);
    if (xTaskWoken == pdTRUE) {
        portYIELD_FROM_ISR();
 * @brief HID Host Device callback
 * Puts new HID Device event to the queue
 * @param[in] event             HID Device event
void hid_host_device_callback(hid_host_device_handle_t hid_device_handle,
                              void *arg)
        .event_group = APP_EVENT_HID_HOST,
        // HID Host Device related info
        .hid_host_device.handle = hid_device_handle,
        .hid_host_device.event = event,
        .hid_host_device.arg = arg
        xQueueSend(app_event_queue, &evt_queue, 0);
void app_main(void)
    BaseType_t task_created;
    app_event_queue_t evt_queue;
    ESP_LOGI(TAG, "HID Host example");
    // Init BOOT button: Pressing the button simulates app request to exit
    // It will disconnect the USB device and uninstall the HID driver and USB Host Lib
    const gpio_config_t input_pin = {
        .pin_bit_mask = BIT64(APP_QUIT_PIN),
        .mode = GPIO_MODE_INPUT,
        .pull_up_en = GPIO_PULLUP_ENABLE,
        .intr_type = GPIO_INTR_NEGEDGE,
    ESP_ERROR_CHECK(gpio_config(&input_pin));
    ESP_ERROR_CHECK(gpio_install_isr_service(ESP_INTR_FLAG_LEVEL1));
    ESP_ERROR_CHECK(gpio_isr_handler_add(APP_QUIT_PIN, gpio_isr_cb, NULL));
    * Create usb_lib_task to:
    * - initialize USB Host library
    * - Handle USB Host events while APP pin in in HIGH state
    task_created = xTaskCreatePinnedToCore(usb_lib_task,
                                           "usb_events",
                                           4096,
                                           xTaskGetCurrentTaskHandle(),
                                           2, NULL, 0);
    assert(task_created == pdTRUE);
    // Wait for notification from usb_lib_task to proceed
    ulTaskNotifyTake(false, 1000);
    * HID host driver configuration
    * - create background task for handling low level event inside the HID driver
    * - provide the device callback to get new HID Device connection event
    const hid_host_driver_config_t hid_host_driver_config = {
        .create_background_task = true,
        .task_priority = 5,
        .stack_size = 4096,
        .core_id = 0,
        .callback = hid_host_device_callback,
    ESP_ERROR_CHECK(hid_host_install(&hid_host_driver_config));
    // Create queue
    app_event_queue = xQueueCreate(10, sizeof(app_event_queue_t));
    ESP_LOGI(TAG, "Waiting for HID Device to be connected");
    while (1) {
        // Wait queue
        if (xQueueReceive(app_event_queue, &evt_queue, portMAX_DELAY)) {
            if (APP_EVENT == evt_queue.event_group) {
                // User pressed button
                usb_host_lib_info_t lib_info;
                ESP_ERROR_CHECK(usb_host_lib_info(&lib_info));
                if (lib_info.num_devices == 0) {
                    // End while cycle
                    ESP_LOGW(TAG, "To shutdown example, remove all USB devices and press button again.");
                    // Keep polling
            if (APP_EVENT_HID_HOST ==  evt_queue.event_group) {
                hid_host_device_event(evt_queue.hid_host_device.handle,
                                      evt_queue.hid_host_device.event,
                                      evt_queue.hid_host_device.arg);
    ESP_LOGI(TAG, "HID Driver uninstall");
    ESP_ERROR_CHECK(hid_host_uninstall());
    gpio_isr_handler_remove(APP_QUIT_PIN);
    xQueueReset(app_event_queue);
    vQueueDelete(app_event_queue);
Manoel
Postby Manoel » Sat Jan 25, 2025 8:08 pm
I recorded a video demonstrating the problem (disregard the fact that I'm using the Arduino IDE, it's just for debugging, as my ESP32 is an S2 Mini).
https://www.youtube.com/watch?v=a5JflUhiGdU
chegewara
Postby chegewara » Mon Jan 27, 2025 3:33 pm
Can you grab USB info for that mouse, something like this?
This is actually wireless mouse, but can give us more info.
Also it would be fine to connect logic analyzer to see data when you use wheel.
Screenshot from 2025-01-27 16-31-13.png (62.23 KiB) Viewed 1561 times
Users browsing this forum: Amazon [Bot], Bing [Bot], Bytespider, ChatGPT-User, Google [Bot] and 6 guests
