Many IR receivers on a single ESP32 using RMT?
ok-home
Contact:
Re: Many IR receivers on a single ESP32 using RMT?
Postby ok-home » Wed Dec 04, 2024 1:07 pm
For the 16 gpio in parallel in dma mode: can we go above 56Khz? what would be the maximum khz?
it depends on your algorithms - how fast you process
16 i2s/dma channels - will take data down to 40 mhz. minimum 2 samples per bit -- 20 mhz, but you won't have time to process this stream
michcfr
Postby michcfr » Wed Dec 04, 2024 1:43 pm
So finally it can work for 16 I2S/DMA channels for simultaneous 15Mhz per IR receiver?
The processing can be done by the other Core while the first is dedicated to the sampling
Does it makes sense?
ok-home
Contact:
Postby ok-home » Wed Dec 04, 2024 2:13 pm
I do not have an answer to this question, you can try,
take the data and see the time of their processing
parallel capture of 16 channels
https://github.com/ok-home/logic_analyzer
if necessary ring buffer and continuous flow is made
Users browsing this forum: Bytespider, Semrush [Bot] and 2 guests
