Good idea. I'll look at that for the final code.
Thanks for your help.
Andy
ESP32 will not output PWM signal
andy_wharton_uk
Re: ESP32 will not output PWM signal
For reference, here's a version of the code which does work. When I was working on this I struggled to find any example so hopefully this will help if anyone else is looking. Thanks for all the help.
Ta
Ta
// Test code to identify the configuration and control of motors using MCPWM on an ESP32-WROOM-32
// This code uses the LATEST mcpwm_prelude.h driver code as the old mcpwm.h has been depreciated.
// Definitely hurt my brain to understand this so apologies if this is not the right way.
// The code is to drive FOUR motors via TWO DBH-12V H-Bridges
Andy Wharton - November 2024
#include "driver/mcpwm_prelude.h"
#include <soc/gpio_struct.h>
#include <hal/gpio_ll.h>
#define VERSION 1.20
/*-----( Declare Constants and Pin Numbers )-----*/
#define DEBUG_SETUP true
#define DEBUG_LOOP true
// Motor GPIO pin assignments
#define GPIO_PWM0A_OUT 16 // Define GPIO 16 as PWM0A - Motor 0 H-Bridge 1
#define GPIO_PWM0B_OUT 17 // Define GPIO 17 as PWM0B - Motor 1 H-Bridge 2
#define GPIO_PWM1A_OUT 18 // Define GPIO 18 as PWM1A - Motor 2 H-Bridge 2
#define GPIO_PWM1B_OUT 19 // Define GPIO 19 as PWM1B - Motor 3 H-Bridge 1
#define ZERO 0
#define MAINDELAY 5000
// We need the folowing for the DBH-12V H-Bridge...
// PWM frequency of 16kHz
// Duty Cycle in steps of 100 - MAX 98% though so limit at 95% for extra safety
// PWM outputs from each Operator are symmetric but independent
// Use the same timer for both Operators - MCPWM_UNIT_0
#define PWM_FREQUENCY0 16384 * 100 // 1.6MHz resolution_hz value
#define PWM_DUTY_STEPS0 100 // and period_ticks of 100 gives a Frequency of 100/1.6MHz = 16kHz
//============= DEBUG stuff
extern gpio_dev_t GPIO;
bool pd, //PULLUP
pu, //PULLDOWN
ie, //INPUT
oe, //OUTPUT
od, //OPEN_DRAIN
slp_sel; //sleep mode magic
uint32_t
drv, // drive capability
fun_sel, // iomux & gpio matrix magic
sig_out; // iomux & gpio matrix magic
// Define all the instances for MCPWM
// Timers, one for the main motors and one for the side motors
mcpwm_timer_handle_t timer0;
// Define an instance of the timer config structure and set values for the Main Motors
mcpwm_timer_config_t timer_config0 = {
.group_id = 0,
.clk_src = MCPWM_TIMER_CLK_SRC_DEFAULT,
.resolution_hz = PWM_FREQUENCY0,
.count_mode = MCPWM_TIMER_COUNT_MODE_UP, // Count Up
.period_ticks = PWM_DUTY_STEPS0,
.flags = {
.update_period_on_empty = false,
.update_period_on_sync = true,
// Operators - one each for the Main motor pairs
mcpwm_oper_handle_t operator0, operator1;
// Define instances of the operator config structures. Sets them to the same group as the timer
mcpwm_operator_config_t operator_config0 = {
.group_id = 0, // operator must be in the same group to the timer. Everything else defaults
mcpwm_operator_config_t operator_config1 = {
// Comparators for the main motors
mcpwm_cmpr_handle_t comparator1, comparator2, comparator3, comparator4;
// Create Comparator configurations - only 1 needed as they are all the same
mcpwm_comparator_config_t comparator_config1 = {
.flags = {
.update_cmp_on_tep = 1, // Update compare threshold when timer counts to peak
mcpwm_comparator_config_t comparator_config2 = {
.flags = {
mcpwm_comparator_config_t comparator_config3 = {
.flags = {
mcpwm_comparator_config_t comparator_config4 = {
.flags = {
// FOUR generators for the main motors
mcpwm_gen_handle_t generator1, generator2, generator3, generator4;
// Generators - One generator per PWM
// define instances of their configurations - only the GPIO assignments change
mcpwm_generator_config_t generator_config1 = {
.gen_gpio_num = GPIO_PWM0A_OUT,
mcpwm_generator_config_t generator_config2 = {
.gen_gpio_num = GPIO_PWM0B_OUT,
mcpwm_generator_config_t generator_config3 = {
.gen_gpio_num = GPIO_PWM1A_OUT,
mcpwm_generator_config_t generator_config4 = {
.gen_gpio_num = GPIO_PWM1B_OUT,
/*-----( Declare User-written Functions )-----*/
void setup_Main_Motors()
if (DEBUG_SETUP) {
Serial.print(F("Create Timers."));
Serial.println(" ");
// MCPWM Initialise the timer
ESP_ERROR_CHECK(mcpwm_new_timer(&timer_config0, &timer0)); // Main Motors
if (DEBUG_SETUP) {
Serial.print(F("Create Operators."));
// Initialise the Operators
ESP_ERROR_CHECK(mcpwm_new_operator(&operator_config0, &operator0)); // Main Motors Same config
ESP_ERROR_CHECK(mcpwm_new_operator(&operator_config1, &operator1)); // Main motors Same config
if (DEBUG_SETUP) {
Serial.print(F("Connect Timers and Operators."));
// Connect the Operators to the single Timer
ESP_ERROR_CHECK(mcpwm_operator_connect_timer(operator0, timer0)); // Main Motors
ESP_ERROR_CHECK(mcpwm_operator_connect_timer(operator1, timer0)); // Main Motors
if (DEBUG_SETUP) {
Serial.print(F("Create Comparators."));
// Create the comparators which define the duty cycle.
// Set the duty cycle using mcpwm_comparator_set_compare_value()
// One comparator per Operator
// Main Motors
ESP_ERROR_CHECK(mcpwm_new_comparator(operator0, &comparator_config1, &comparator1));
ESP_ERROR_CHECK(mcpwm_new_comparator(operator0, &comparator_config2, &comparator2));
ESP_ERROR_CHECK(mcpwm_new_comparator(operator1, &comparator_config3, &comparator3));
ESP_ERROR_CHECK(mcpwm_new_comparator(operator1, &comparator_config4, &comparator4));
if (DEBUG_SETUP) {
Serial.print(F("Create Generators."));
// Create the generators
// Main Motors
ESP_ERROR_CHECK(mcpwm_new_generator(operator0, &generator_config1, &generator1));
ESP_ERROR_CHECK(mcpwm_new_generator(operator0, &generator_config2, &generator2));
ESP_ERROR_CHECK(mcpwm_new_generator(operator1, &generator_config3, &generator3));
ESP_ERROR_CHECK(mcpwm_new_generator(operator1, &generator_config4, &generator4));
if (DEBUG_SETUP) {
Serial.print(F("Set the generator event actions."));
// Now set the generators to carry out the correct actions based on their direction and the timer event
// Each generator will get an event when it's operator/comparator hits the duty_cycle
// >> Main Motors <<
// Generator 1
// First go high when the counter is empty
ESP_ERROR_CHECK(mcpwm_generator_set_action_on_timer_event(generator1,
MCPWM_GEN_TIMER_EVENT_ACTION(MCPWM_TIMER_DIRECTION_UP, MCPWM_TIMER_EVENT_EMPTY, MCPWM_GEN_ACTION_HIGH)));
// Then go LOW when the counter hits the duty cycle threshold.
ESP_ERROR_CHECK(mcpwm_generator_set_action_on_compare_event(generator1,
MCPWM_GEN_COMPARE_EVENT_ACTION(MCPWM_TIMER_DIRECTION_UP, comparator1, MCPWM_GEN_ACTION_LOW)));
// Generator 2
ESP_ERROR_CHECK(mcpwm_generator_set_action_on_timer_event(generator2,
ESP_ERROR_CHECK(mcpwm_generator_set_action_on_compare_event(generator2,
MCPWM_GEN_COMPARE_EVENT_ACTION(MCPWM_TIMER_DIRECTION_UP, comparator2, MCPWM_GEN_ACTION_LOW)));
// Generator 3
ESP_ERROR_CHECK(mcpwm_generator_set_action_on_timer_event(generator3,
ESP_ERROR_CHECK(mcpwm_generator_set_action_on_compare_event(generator3,
MCPWM_GEN_COMPARE_EVENT_ACTION(MCPWM_TIMER_DIRECTION_UP, comparator3, MCPWM_GEN_ACTION_LOW)));
// Generator 4
ESP_ERROR_CHECK(mcpwm_generator_set_action_on_timer_event(generator4,
ESP_ERROR_CHECK(mcpwm_generator_set_action_on_compare_event(generator4,
MCPWM_GEN_COMPARE_EVENT_ACTION(MCPWM_TIMER_DIRECTION_UP, comparator4, MCPWM_GEN_ACTION_LOW)));
if (DEBUG_SETUP) {
Serial.print(F("Enable and Start Timer."));
// Enable the timers and start them
ESP_ERROR_CHECK(mcpwm_timer_enable(timer0));
ESP_ERROR_CHECK(mcpwm_timer_start_stop(timer0, MCPWM_TIMER_START_NO_STOP));
if (DEBUG_SETUP) {
Serial.print(F("Set the duty cycle to 0 (Stop)."));
// Set the initial duty cycle to ZERO for all motors
ESP_ERROR_CHECK(mcpwm_comparator_set_compare_value(comparator1, ZERO));
ESP_ERROR_CHECK(mcpwm_comparator_set_compare_value(comparator2, ZERO));
ESP_ERROR_CHECK(mcpwm_comparator_set_compare_value(comparator3, ZERO));
ESP_ERROR_CHECK(mcpwm_comparator_set_compare_value(comparator4, ZERO));
void setup()
// Start the built-in serial port, probably to Serial Monitor
if (DEBUG_SETUP) {
Serial.begin(9600);
delay(200);
Serial.print(F("ESP32 MCPWM Debug Output - V"));
Serial.println(VERSION);
// Now set up PWM on the 4 main motors
setup_Main_Motors();
void gpio_Print(int GPIO_PIN)
gpio_ll_get_io_config(&GPIO, GPIO_PIN ,&pu, &pd, &ie, &oe, &od,&drv, &fun_sel, &sig_out, &slp_sel);
Serial.print("GPIO ");
Serial.print(GPIO_PIN);
Serial.println(" Settings: PU, PD, IN, OUT, OD, SMM, drv, FS, SO ");
Serial.print(" ");
Serial.print(pu);
Serial.print(", ");
Serial.print(pd);
Serial.print(", ");
Serial.print(ie);
Serial.print(", ");
Serial.print(oe);
Serial.print(", ");
Serial.print(od);
Serial.print(", ");
Serial.print(slp_sel);
Serial.print(", ");
Serial.print(drv);
Serial.print(", ");
Serial.print(fun_sel);
Serial.print(", ");
Serial.print(sig_out);
void cycle_Motor_UP(int MotorID, int Cycle)
// Loop and ramp the motors up then down
if (DEBUG_LOOP) {
Serial.print(F("Cycle UP - Motor Steps"));
Serial.println(F(" "));
Serial.print(MotorID);
Serial.print(" ");
Serial.print(Cycle);
// Motor Ramp UP
for (int duty_Cycle = 0; duty_Cycle <= Cycle; duty_Cycle++ )
if (DEBUG_LOOP) {
Serial.print(F("Motor - "));
Serial.print(F(" Duty Cycle = "));
Serial.print(duty_Cycle);
// Set the initial duty cycle to the required duty cycle
switch(MotorID) {
case 0:
gpio_Print(GPIO_PWM0A_OUT);
ESP_ERROR_CHECK(mcpwm_comparator_set_compare_value(comparator1, duty_Cycle));
case 1:
gpio_Print(GPIO_PWM0B_OUT);
ESP_ERROR_CHECK(mcpwm_comparator_set_compare_value(comparator2, duty_Cycle));
case 2:
gpio_Print(GPIO_PWM1A_OUT);
ESP_ERROR_CHECK(mcpwm_comparator_set_compare_value(comparator3, duty_Cycle));
case 3:
gpio_Print(GPIO_PWM1B_OUT);
ESP_ERROR_CHECK(mcpwm_comparator_set_compare_value(comparator4, duty_Cycle));
default:
break; // Do nothing
delay(200); // Delay 200ms
void cycle_Motor_DOWN(int MotorID, int Cycle)
if (DEBUG_LOOP) {
Serial.println(F("Cycle DOWN - Motor Steps"));
Serial.print(F(" "));
Serial.print(" ");
// Motor Ramp DOWN
for (int duty_Cycle = Cycle; duty_Cycle >= 0; duty_Cycle-- )
if (DEBUG_LOOP) {
switch(MotorID) {
case 0:
case 1:
case 2:
case 3:
default:
delay(100); // Delay 100ms
void loop()
delay(5000); // Delay 5s
// Call Loops to ramp the motors up then down one at a time
// Max Duty Cycle of 95% of the available steps
if (DEBUG_LOOP) {
Serial.print(F("Motor 0, GP16"));
cycle_Motor_UP(0, PWM_DUTY_STEPS0 * 0.95);
delay(MAINDELAY); // Delay 5s
cycle_Motor_DOWN(0, PWM_DUTY_STEPS0 * 0.95);
delay(MAINDELAY); // Delay 10s - allows me to move my scope probes
if (DEBUG_LOOP) {
Serial.print(F("Motor 1, GP17"));
cycle_Motor_UP(1, PWM_DUTY_STEPS0 * 0.95);
cycle_Motor_DOWN(1, PWM_DUTY_STEPS0 * 0.95);
if (DEBUG_LOOP) {
Serial.print(F("Motor 2, GP18"));
cycle_Motor_UP(2, PWM_DUTY_STEPS0 * 0.95);
cycle_Motor_DOWN(2, PWM_DUTY_STEPS0 * 0.95);
if (DEBUG_LOOP) {
Serial.print(F("Motor 3, GP19"));
cycle_Motor_UP(3, PWM_DUTY_STEPS0 * 0.95);
cycle_Motor_DOWN(3, PWM_DUTY_STEPS0 * 0.95);
