see attached. Thanks.
ESP32 P4 EV Kit touch not working
Re: ESP32 P4 EV Kit touch not working
The flat on the camera board is inverted. The blue part should be on the top.
OMG! Yes, you are correct. Now working as it should. The camera works.
Watched this video for the cabling:
https://www.youtube.com/watch?v=pNR05RORfg8
We must have done it wrong. Thanks so much for the great support!
Q: We plan to use 4 Lane MIPI DSI (like iphone displays). Are any special config DCS commands other than resolution required to stream out pixels to the display? From our (limited) knowledge, send out pixel data in video mode to draw to the screen?
faisalhabdeen
Hello , I have the same problem as you and I attached it correct but the touch still not working is there any problem with wire connection or what ?? Thank you
- IMG_9739.jpeg (3.51 MiB) Viewed 2065 times
- IMG_9740.jpeg (3.46 MiB) Viewed 2065 times
- IMG_9741.jpeg (2.88 MiB) Viewed 2065 times
Yes, same problem.
Change the direction of the camera flat cable. As you can see on the display flat, the blue part should be on the same side.
