I'm using an AHT20 sensor on a battery-driven board.
As already recommended here I power the sensor with a GPIO pin. After powering I wait 50ms by calling v
TaskDelay( 50 / portTICK_PERIOD_MS );
to get the sensor up.
One hint for hidden power consumers:
On one board I needed to call rtc_gpio_isolate() for a connected onboard LED before going to deep sleep. Without that the LED showed "some light".
ESP32 interfaced with AHT10 sensor
Re: ESP32 interfaced with AHT10 sensor
What LCD?!
How much power?
If you want to actually completely switch off power (3.3V) of external devices (which you can't power directly from a GPIO pin like the AHT10), the easiest way is indeed to just hook up a P-channel MOSFET to 3.3V and a GPIO output ("high-side switch").
The LCD I have used is JHD202C, a DS3231M RTC module, AHT10 sensor and we have to save as much power as possible.
Also which specific MOSFETs can be used?What LCD?!
How much power?
MicroController
Any P-channel MOSFET with a V[th] significantly less than 3.3V (or greater than -3.3V depending on the convention used) which can conduct enough current for your needs at V[gs] = -3.3V.Also which specific MOSFETs can be used?
The AO3401A, for example, with a V[th] of -0.9V (typ.) is cheap, available, comes in SOT23 (=small but hand-solderable), can switch a few amperes, and has ~50-60mOhm of R[ds] at -3.3V of V[gs].
(Just remember to not leave the FET's gate floating while sleeping.)
so in the deep sleep mode, the power consumed must be in microamperes. how to manage that using ESP32Devkitc V4 and a MOSFET?Any P-channel MOSFET with a V[th] significantly less than 3.3V (or greater than -3.3V depending on the convention used) which can conduct enough current for your needs at V[gs] = -3.3V.Also which specific MOSFETs can be used?
MicroController
Not going to happen -> viewtopic.php?t=46102#p149079power consumed must be in microamperes. how to manage that using ESP32Devkitc V4 and a MOSFET?
so according to you is it not possible to bring the consumption down to microamperes using standard devkit boards? since most of them use a AMS1117 LDO?Not going to happen -> viewtopic.php?t=46102#p149079power consumed must be in microamperes. how to manage that using ESP32Devkitc V4 and a MOSFET?
JoeSensoric
I'm powering my boards with an external battery pack and a low power Step-Down Voltage Regulator (Pololu 3.3V, 500mA D24V5F3). It's connected to the 3.3V pin of the board, so the build-in LDO will not be active. But there can be other components on the board using some power.so according to you is it not possible to bring the consumption down to microamperes using standard devkit boards? since most of them use a AMS1117 LDO?Not going to happen -> viewtopic.php?t=46102#p149079power consumed must be in microamperes. how to manage that using ESP32Devkitc V4 and a MOSFET?
But in my case I am using an LCD display as well which requires 5V so I don't think this would work for meI'm powering my boards with an external battery pack and a low power Step-Down Voltage Regulator (Pololu 3.3V, 500mA D24V5F3). It's connected to the 3.3V pin of the board, so the build-in LDO will not be active. But there can be other components on the board using some power.so according to you is it not possible to bring the consumption down to microamperes using standard devkit boards? since most of them use a AMS1117 LDO?
