Re: ESP Coredump in Flash Cannot be Read
Posted: Mon Aug 11, 2025 10:25 am
Tried this on a few boards, all ESP32 and I get the same results.
Regards,
Mark
Regards,
Mark
ESP IDF, v5.5-1-gb66b5448e0-dirtyWhat tools are you using, and what version?
idf.py build flash monitor
MacOS, latest version, fully patched.What operating system?
ESP-WROVER-KIT (ESP32-D0WDQ6 (revision v1.0))What development boards, and what chip is on them?
From a code perspective I am forcing an application fault. I have used the getting started/hello world example. I have turned code dump on, sdkconfig is:How did you create those coredumps?
CONFIG_ESP_COREDUMP_ENABLE_TO_FLASH=y
# CONFIG_ESP_COREDUMP_ENABLE_TO_UART is not set
# CONFIG_ESP_COREDUMP_ENABLE_TO_NONE is not set
# CONFIG_ESP_COREDUMP_DATA_FORMAT_BIN is not set
CONFIG_ESP_COREDUMP_DATA_FORMAT_ELF=y
# CONFIG_ESP_COREDUMP_CHECKSUM_CRC32 is not set
CONFIG_ESP_COREDUMP_CHECKSUM_SHA256=y
# CONFIG_ESP_COREDUMP_CAPTURE_DRAM is not set
CONFIG_ESP_COREDUMP_CHECK_BOOT=y
CONFIG_ESP_COREDUMP_ENABLE=y
CONFIG_ESP_COREDUMP_LOGS=y
CONFIG_ESP_COREDUMP_MAX_TASKS_NUM=32
# CONFIG_ESP_COREDUMP_FLASH_NO_OVERWRITE is not set
CONFIG_ESP_COREDUMP_STACK_SIZE=4096
So application output:How are you invoking those tools and what error are you seeing?
I (187) esp_core_dump_flash: Init core dump to flash
I (192) esp_core_dump_flash: Found partition 'coredump' @ 10000 65536 bytes
I (210) esp_core_dump_flash: Core dump data checksum is correct
I (211) esp_core_dump_flash: Found core dump 7744 bytes in flash @ 0x10000
I (213) main_task: Started on CPU0
I (223) main_task: Calling app_main()
Hello world!
This is esp32 chip with 2 CPU core(s), WiFi/BTBLE, silicon revision v3.0, 4MB external flash
Minimum free heap size: 297072 bytes
Restarting in 100 seconds...
Restarting in 99 seconds...
Restarting in 98 seconds...
Restarting in 97 seconds...
Restarting in 96 seconds...
Restarting in 95 seconds...
Restarting in 94 seconds...
Restarting in 93 seconds...
Restarting in 92 seconds...
Restarting in 91 seconds...
Guru Meditation Error: Core 0 panic'ed (StoreProhibited). Exception was unhandled.
Core 0 register dump:
PC : 0x400d4e8d PS : 0x00060830 A0 : 0x800e2ba3 A1 : 0x3ffb57d0
--- 0x400d4e8d: app_main at /Users/markstevens/Public/CoreDumpTest/main/hello_world_main.c:49
A2 : 0x00000003 A3 : 0x3f401cd1 A4 : 0x3f401d19 A5 : 0x000000df
A6 : 0x3f401cd1 A7 : 0x0000005a A8 : 0x00000000 A9 : 0x3ffb57b0
A10 : 0x00000064 A11 : 0x0000005b A12 : 0x3f403b75 A13 : 0x3f403b4b
A14 : 0x3f4056a9 A15 : 0x3f4056ae SAR : 0x00000004 EXCCAUSE: 0x0000001d
EXCVADDR: 0x00000000 LBEG : 0x400014fd LEND : 0x4000150d LCOUNT : 0xfffffffe
--- 0x400014fd: strlen in ROM
--- 0x4000150d: strlen in ROM
Backtrace: 0x400d4e8a:0x3ffb57d0 0x400e2ba0:0x3ffb5810 0x4008513d:0x3ffb5840
--- 0x400d4e8a: app_main at /Users/markstevens/Public/CoreDumpTest/main/hello_world_main.c:49
--- 0x400e2ba0: main_task at /Users/markstevens/esp/esp-idf/components/freertos/app_startup.c:208
--- 0x4008513d: vPortTaskWrapper at /Users/markstevens/esp/esp-idf/components/freertos/FreeRTOS-Kernel/portable/xtensa/port.c:139
ELF file SHA256: 81631309cda357fa
I (10290) esp_core_dump_flash: Save core dump to flash...
I (10295) esp_core_dump_common: Backing up stack @ 0x3ffb5650 and use core dump stack @ 0x3ffb3d40
I (10304) esp_core_dump_flash: Erase flash 8192 bytes @ 0x10000
I (10431) esp_core_dump_flash: Write end offset 0x1e40, check sum length 32
I (10432) esp_core_dump_common: Core dump used 1280 bytes on stack. 2900 bytes left free.
I (10435) esp_core_dump_common: Restoring stack @ 0x3ffb5650
I (10440) esp_core_dump_flash: Core dump has been saved to flash.
CPU halted.
parttool.py --port /dev/tty.usbserial-0001 read_partition --partition-name coredump --output coredump.bin
esptool.py v4.9.0
Serial port /dev/tty.usbserial-0001
Connecting....
Detecting chip type... Unsupported detection protocol, switching and trying again...
Connecting.......
Detecting chip type... ESP32
Chip is ESP32-D0WD-V3 (revision v3.0)
WARNING: Detected crystal freq 41.01MHz is quite different to normalized freq 40MHz. Unsupported crystal in use?
Crystal is 40MHz
MAC: e0:5a:1b:77:8c:6c
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
3072 (100 %)
3072 (100 %)
Read 3072 bytes at 0x00008000 in 0.3 seconds (86.5 kbit/s)...
Hard resetting via RTS pin...
Running /Users/markstevens/.espressif/python_env/idf5.5_py3.12_env/bin/python /Users/markstevens/esp/esp-idf/components/esptool_py/esptool/esptool.py --port /dev/tty.usbserial-0001 read_flash 65536 65536 coredump.bin...
esptool.py v4.9.0
Connecting......
Connecting....
Crystal is 40MHz
Uploading stub...
Running stub...
Stub running...
65536 (100 %)
65536 (100 %)
Read 65536 bytes at 0x00010000 in 5.9 seconds (88.6 kbit/s)...
Read partition 'coredump' contents from device at offset 0x10000 to file 'coredump.bin'
esp-coredump --chip esp32 info_corefile coredump.bin
raise ConstError(f"parsing expected {repr(self.value)} but parsed {repr(obj)}", path=path)
construct.core.ConstError: Error in path (parsing) -> elf_header -> e_ident -> EI_MAG
parsing expected b'\x7fELF' but parsed b'@\x1e\x00\x00'
idf.py coredump-info
Executing action: coredump-info
Serial port /dev/cu.usbserial-101
Connecting....
Connecting....
WARNING:root:The core dump image offset is not specified. Use partition offset: 0x10000.
Failed to load core dump: esptool script execution failed with error 2, failed command was: '['/Users/markstevens/.espressif/python_env/idf5.5_py3.12_env/bin/python', '-m', 'esptool', '-c', 'auto', '-p', '/dev/cu.usbserial-101', '-b', '460800', 'read_flash', '65536', '7744', '/var/folders/m4/sw8tgkhs20549s7f__sz62l40000gn/T/tmp6m5tbcol']'
┌────── Additional information about the error:
│ esptool.py v4.9.0
│ Serial port /dev/cu.usbserial-101
│ Connecting.......
│ Detecting chip type... Unsupported detection protocol, switching and trying again...
│ Connecting....
│ Detecting chip type... ESP32
│ Chip is ESP32-D0WDQ6 (revision v1.0)
│ Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, BLK3 partially reserved, Coding Scheme 3/4
│ Crystal is 40MHz
│ MAC: 84:0d:8e:18:5b:08
│ Uploading stub...
│ Running stub...
│ Stub running...
│ Changing baud rate to 460800
│ Changed.
│ Configuring flash size...
│ A fatal error occurred: Corrupt data, expected 0x1000 bytes but received 0xfed bytes
└────── end of additional information about the error.
espcoredump.py info_corefile -t raw -c /path/to/coredump.bin /path/to/firmware.elf
