[one part solved] which format as audio src for A2dp source example is supported?
shouenlee
Re: [one part solved] which format as audio src for A2dp source example is supported?
Postby shouenlee » Mon Dec 31, 2018 6:00 pm
Hi I'm new to the esp32 and I'm trying to learn how to use a2dp source to play music from an SD card to BT speaker. How did you connect your Sd to the esp using pins? and how did you stream the audio to a speaker?
Thanks!
Postby rudi ;-) » Tue Jan 01, 2019 7:11 pm
Thanks!
Happy New Year!
So many question are answered in one of the greatest project
and that components you find here
hope this helps
Users browsing this forum: Google [Bot] and 5 guests
