DMA example for UART communication for ESP32
WiFive
Re: DMA example for UART communication for ESP32
Postby WiFive » Sat Feb 17, 2018 6:36 pm
If the baud is 115200 then the tout interrupt will come approx 90us after end of frame.
Ritesh
Contact:
Postby Ritesh » Mon Feb 19, 2018 6:01 pm
Would you please provide any sample example to receive and handle received data with dynamic size and dynamic interval coming from UART module without DMA?
Because we had tried without DMA just to read data continuesly at every 100 msec and at that time we are facing Task Watchdog Timeout error after some amount of interval.
Hope you will understand my concern regarding this.
Regards,
Ritesh Prajapati
WiFive
Postby WiFive » Mon Feb 19, 2018 8:06 pm
If you are using uart_read_bytes with nonzero wait time the task should unblock when tout interrupt pushes bytes to ringbuffer
Ritesh
Contact:
Postby Ritesh » Tue Feb 20, 2018 3:22 am
Thanks for Reply.
I am just little bit confuse here regarding tout interrupt. would you please let me know tout interrupt is same as UART Receive Byte Interrupt or it is different?
Below is out UART configuration code.
uart_config_t uart_config = {
          .baud_rate = baud_rate,
         .flow_ctrl = hw_flow,
          .rx_flow_ctrl_thresh = 122,
    vTaskDelay(10 / portTICK_RATE_MS);
	uart_status =  uart_param_config(uart_num, &uart_config);
	if(uart_status == ESP_OK)
		DEBUG_LOGI(UART,TAG1,"UART %d configured successfully...",uart_num);
		if(hw_flow==GW_UART_HW_FLOWCTRL_DISABLE)
			uart_status=uart_set_pin(uart_num,tx ,rx,UART_PIN_NO_CHANGE,UART_PIN_NO_CHANGE );
		else if(hw_flow==GW_UART_HW_FLOWCTRL_RTS)
			uart_status=uart_set_pin(uart_num,tx ,rx,rts,UART_PIN_NO_CHANGE );
		else if(hw_flow==GW_UART_HW_FLOWCTRL_CTS)
			uart_status=uart_set_pin(uart_num,tx ,rx,UART_PIN_NO_CHANGE,cts);
		else
			uart_status=uart_set_pin(uart_num,tx ,rx,rts,cts);
	else
		DEBUG_LOGI(UART,TAG1, "ERROR :  UART%d failed to configure...",uart_num);
		return false;
	if(uart_status==ESP_OK)
		uart_status=uart_driver_install(uart_num, 1024 * 2, 1024*4, 128, &uart_queue[uart_num], 0);
		uart_flush(uart_num);
	else
		DEBUG_LOGE(UART,TAG1,"UART%d set pin error",uart_num);
		return false;
xTaskCreate(uart0_task, "uart_0", UART_TASK_SIZE, (void*)uart_num, UART_TASK_PRIO, &uart_handler[GW_UART0]);
void uart0_task(void *arg)
	int uart_num = (int)arg;
     uart_event_t event;
	//int len;
     uart_data[uart_num]=(uint8_t*)malloc(PACK_SIZE);
	if(uart_data[uart_num] == NULL)
		DEBUG_LOGE(UART,TAG1,"Memory allocation failed");
		vTaskDelete(NULL);
    uart_ring_buf[uart_num]=(uint8_t*)malloc(RING_BUFF_SIZE);
	if(uart_ring_buf[uart_num]==NULL)
		free(uart_data[uart_num]);
		vTaskDelete(NULL);
	if(rb_init(&rb_uart[uart_num],uart_ring_buf[uart_num],RING_BUFF_SIZE,1)==-1)
		DEBUG_LOGE(UART,TAG1,"Ring buffer init failed");
		free(uart_ring_buf[uart_num]);
		vTaskDelete(NULL);
	DEBUG_LOGI(UART,TAG1,"***UART0 Task Started***");
      for(;;) {
		  #ifdef CONFIG_ESP32
         //Waiting for UART0 event.
          if(xQueueReceive(uart_queue[0], (void * )&event, 100)) {
			int len; // Not used in the code
            //  DEBUG_LOGI(UART,TAG1, "uart[%d] event:", uart_num);
              switch(event.type) {
                  //Event of UART0 receving data
                  case UART_DATA:
						memset(uart_data[uart_num],0,PACK_SIZE);
						len = uart_read_bytes(uart_num, uart_data[uart_num], event.size, 10);
						DEBUG_LOGD(UART,TAG1,"UART0 RECEIVED DATA LENGTH:%d, DATA:'%s'",event.size,uart_data[uart_num]);
						rb_write(&rb_uart[uart_num],uart_data[uart_num],len);
                  //Event of HW FIFO overflow detected
                  case UART_FIFO_OVF:
                      DEBUG_LOGE(UART,TAG1, " uart_0 hw fifo overflow\n");
                  //Event of UART ring buffer full
                  case UART_BUFFER_FULL:
                      DEBUG_LOGE(UART,TAG1, " uart_0 ring buffer full\n");
                  //Event of UART RX break detected
                  case UART_BREAK:
                      DEBUG_LOGE(UART,TAG1, "uart_0 rx break\n");
                  //Event of UART parity check error
                  case UART_PARITY_ERR:
                      DEBUG_LOGE(UART,TAG1, "uart_0 parity error\n");
                  //Event of UART frame error
                  case UART_FRAME_ERR:
                      DEBUG_LOGE(UART,TAG1, "uart_0 frame error\n");
                  //Others
                  default:
                      DEBUG_LOGI(UART,TAG1, "uart_0 event type: %d\n", event.type);
		 #endif
		#ifdef CONFIG_NUVOTON
		 vTaskDelay(100 / portTICK_RATE_MS);
		#endif
    vTaskDelete(NULL);
Let me know if we had did anything wrong which is creating Task Watchdog Trigger Issue while reading data with dynamic interval and size from UART Module attached with ESP32.
Regards,
Ritesh Prajapati
WiFive
Postby WiFive » Tue Feb 20, 2018 4:32 am
Yes tout interrupt generates UART_DATA event. Other than changing the wait timeouts not really. But you may want to ask do you need to use event queue and double buffered data or can you just do like this https://github.com/espressif/esp-idf/tr ... _rxtxtasks
Ritesh
Contact:
Postby Ritesh » Tue Feb 20, 2018 6:02 pm
Hi
In short, I just want to read data from UART module over Interrupt continuously with dynamic size and interval.
So, Please suggest me to achieve it either using queue or directly using UART driver API for faster Communication.
Regards,
Ritesh Prajapati
JISHNUE
Postby JISHNUE » Tue Nov 02, 2021 9:54 am
Hello Is anyone update this question? I also facing problem with uart.My requirement is send large amount of data (greater than 120 bytes) through uart2.could you please help me to clearout my doubt? :?:
Ritesh
Contact:
Postby Ritesh » Tue Nov 09, 2021 10:21 am
what kind of issue are you facing while sending large amount of data? can you please send logs with error or more details.
Because we are able to send data with 512 Bytes of chunk without any issue over UART1
Regards,
Ritesh Prajapati
mm_1993
Postby mm_1993 » Tue Mar 14, 2023 7:13 am
Hi
does Anyone Run DMA UART?
I want to read data from UART0 and transfer it using UART1 and vice versa, I'm using ESP32-C3 Module.
I run the uart_events example and uart_async_rxtxtasks example But in the output, I have data loss and missing data.
so I need UART DMA.
can somebody help? or is there any doc?
Regards
MicroController
Postby MicroController » Thu Mar 16, 2023 1:14 am
What bitrate do you need?
Do you already have one dedicated task for sending in each direction, each accepting the data provided by the RX event listener of the respective other UART?
Users browsing this forum: Qwantbot, Semrush [Bot] and 1 guest
