Websocket Async Messages
MicroController
Re: Websocket Async Messages
Postby MicroController » Mon Feb 02, 2026 4:17 pm
So i need to add queue work in the reception handler too ?
Only if there is a chance that two tasks may try to operate (send WS packets) on the same sockfd at the same time.
Baldhead
Postby Baldhead » Thu Feb 05, 2026 10:45 pm
I returned from vacation and went to test the code with the new handler `.ws_pre_handshake_cb = get_clients_open_connection_handler` along with the "old" handler, and now it gives an error saying that the packet is not binary, "WebSocket Type Not Binary!!!".
The packet is being interpreted as continue and packet final false.
I haven't changed my mobile app.
I installed esp-idf v5.5.2
static esp_err_t get_clients_open_connection_handler(httpd_req_t* req)
    char message[50];
    int sockfd = httpd_req_to_sockfd(req);
    ESP_LOGI(TAG, LOG_USER("New Connection Was Opened"));
    ESP_LOGI(TAG, LOG_USER("New Connection Socket: %d\n"), sockfd);
    bool code = ws_server_users_login(req, message, sizeof(message));
    if (code)
        add_ws_client_to_list(sockfd);
        resp_Ws_Error_Message_Sync(req, message, command_error);
        return ESP_OK;
    else
        ESP_LOGI(TAG, LOG_USER("Message: %s\n"), message);
        ESP_LOGI(TAG, LOG_USER("SEND CLOSE FRAME"));
        esp_err_t ret = send_close_frame(unexpected_condition_code, message, sockfd);  // send_close_frame( normal_closure, NULL, sockfd );
        ESP_LOGI(TAG, LOG_USER("Send Close Frame: %s\n"), esp_err_to_name(ret));
        return ESP_FAIL;
.handler   = get_clients_message_handler
static esp_err_t get_clients_message_handler(httpd_req_t* req)
    ESP_LOGI(TAG, LOG_USER("FUNCTION: %s"), __func__);
    ESP_LOGI(TAG, LOG_USER("[%s]req->method = %d\n"), __func__, req->method);
    httpd_ws_frame_t ws_pkt;
    memset(&ws_pkt, 0, sizeof(httpd_ws_frame_t));
    // Primeira chamada: apenas para ler o cabeçalho (tipo e tamanho)
    esp_err_t ret = httpd_ws_recv_frame(req, &ws_pkt, 0);
    if (ret != ESP_OK)
        ESP_LOGW(TAG, "httpd_ws_recv_frame() falhou ao ler cabecalho: %s", esp_err_to_name(ret));
        return ret;
#if enable_handle_ws_control_frames
    // Se for controle com ZERO bytes, desvia direto para o handler
    if (ws_pkt.len == 0 && (ws_pkt.type == HTTPD_WS_TYPE_PING || ws_pkt.type == HTTPD_WS_TYPE_PONG || ws_pkt.type == HTTPD_WS_TYPE_CLOSE))
        return control_frames_handler(req, &ws_pkt);
#endif
    if (ws_pkt.len > 125)
        ESP_LOGW(TAG, "Mensagem muito grande: %d bytes. Rejeitando.", ws_pkt.len);
        return ESP_OK;
    // Aloca buffer na stack se houver payload
    size_t buf_capacity = (ws_pkt.len > 0) ? ws_pkt.len : 1;
    uint8_t buf[buf_capacity];
    memset(buf, 0, buf_capacity);
    ws_pkt.payload = buf;
    // Segunda chamada: le o payload apenas se len > 0 (evita bug de fechar socket)
    if (ws_pkt.len > 0)
        ret = httpd_ws_recv_frame(req, &ws_pkt, ws_pkt.len);
        if (ret != ESP_OK)
            #if webSocketDebug
                ESP_LOGI(TAG, "Erro ao ler payload: %s", esp_err_to_name(ret));
            #endif
            return ret;
#if webSocketDebug
    printFrame(&ws_pkt, "Received Client Frame", req);
#endif
    // Se for controle com payload > 0, chama o handler apos a leitura
    if (ws_pkt.type == HTTPD_WS_TYPE_PING || ws_pkt.type == HTTPD_WS_TYPE_PONG || ws_pkt.type == HTTPD_WS_TYPE_CLOSE)
#endif
    // Tratamento de frames de dados (Binary/Text)
    if (ws_pkt.type != HTTPD_WS_TYPE_BINARY)
        int fd = httpd_req_to_sockfd(req);
        ESP_LOGI(TAG, "Tipo nao binario: %d | Socket: %d", ws_pkt.type, fd);
        resp_Ws_Error_Message_Sync(req, "WebSocket Type Not Binary!!!", command_error);
        return ESP_FAIL;
    // Processa comando se houver payload
    if (ws_pkt.len > 0)
        uint8_t comando = ws_pkt.payload[0];
        if (comando < web_comm_t_array_size_t)
            ret = func_pointer[comando](req, comando, &ws_pkt);
            #if webSocketDebug
                ESP_LOGI(TAG, "ret select_func = %d", ret);
            #endif
            return ESP_OK;
        else
            static const char msg[] = "Erro: Comando invalido = ";
            static const size_t MAX_UINT8_DECIMAL_DIGITS = 3;  // uint8_t max decimal convertido para texto.
            static const size_t size = sizeof(msg) + MAX_UINT8_DECIMAL_DIGITS;
            char err_msg[size];
            snprintf(err_msg, size, "%s%hhu", msg, comando);  // %hhu é o especificador exato para uint8_t
            resp_Ws_Error_Message_Sync(req, err_msg, command_error);
            return ESP_FAIL;
    else
        ESP_LOGW(TAG, "Frame binario vazio. Ignorando.");
    return ESP_OK;
Note:
ESP-IDF version: v5.5.2
Baldhead
Postby Baldhead » Fri Feb 06, 2026 8:33 pm
I found the problem, in the function .handler = get_clients_message_handler, still need to check:
if (req->method == HTTP_GET)
        ESP_LOGI(TAG, "Handshake done, the new connection was opened");
        ESP_LOGI(TAG, LOG_USER("New Connection Socket: %d\n"), httpd_req_to_sockfd(req));
        return ESP_OK;
https://github.com/espressif/esp-idf/issues/18215
