Practical usage of the built-in hall sensor
jcsbanks
Re: Practical usage of the built-in hall sensor
Postby jcsbanks » Mon Dec 03, 2018 10:19 pm
Could an external capacitor be used to add some filtering to the noisy readings?
lucas77
Postby lucas77 » Wed May 20, 2020 2:41 am
Hi, anyone has used the built in hall effect sensor with interrupts? my goal is to count revolutions of a wheel (Bicycle), son can calculate speed. So, I want to use the built in sensor, and got 2 problems: first, can´t figure out how to make an interrupt on each revolution, lots of projects already solved the problem using an external sensor; the second problem, is that the initial value of the sensor (without and magnet near) is different for my 4 Esp43 Wroom 32U boards, so the function I made doesn´t work well for all of them.
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
