Note that these are silicon resistors, so that value of 45KOhm has some extremely large error bars and probably varies a bit with temperature, supply voltage etc.And as a bonus hard-to-find figure, the internal pull-up and pull-down resistors are 45kOhms each.
Current Limits
Re: Current Limits
DIYTinkerer
Re: Current Limits
Hi when you say
Thanks.
do you mean per pin or a maximum load across all pins that the power domain supplies?This domain can SOURCE 40mA and SINK up to 28mA on STRENGTH 3
Thanks.
Re: Current Limits
That's per pin.Hi when you saydo you mean per pin or a maximum load across all pins that the power domain supplies?This domain can SOURCE 40mA and SINK up to 28mA on STRENGTH 3
Thanks.
