esp_register_freertos_tick_hook() verus FreeRTOS vApplicationTickHook()
snahmad75
Re: esp_register_freertos_tick_hook() verus FreeRTOS vApplicationTickHook()
Postby snahmad75 » Mon Oct 29, 2018 9:19 am
Maybe use the timer peripheral to generate sub millisecond interrupts, then modify ledc pwm in an ISR?
I did not get. can you explain more with example code.
Dazza0
Postby Dazza0 » Mon Oct 29, 2018 11:12 am
Take a look at the 64-Bit Timers chapter in the Technical Reference Manual, then take a look at the driver documentation and the Timer Group Example.
The idea is to use a hardware timer to generate a sub milli second interrupt periodically (auto reload), and using the interrupt service routine to change your ledc frequency.
grtschnk
Postby grtschnk » Thu Nov 01, 2018 2:07 am
Do we need to worry about the IRAM_ATTR when using esp_register_freertos_tick_hook()?
I am asking because I experience the following error: "Guru Meditation Error: Core 0 panic'ed (Cache disabled but cached memory region accessed)"
I attach a tick_hook to increment the time in a library/component. However when I try to connect to my WiFi WPA2 Enterprise network the above-mentioned crash occurs. My guess is: the ESP32 is so quite busy during the WiFi handling, and either *RAM gets quite full and/or the flash gets disabled for a brief moment, so that the tick-interrupt (is it an ISR/interrupt?) can't find the next instruction.
GDB/JTAG throws the exception at the head of my static function in main.c which I registered with esp_register_freertos_tick_hook.
I am currently looking through the documents relating to ISR, IRAM_ATTR etc., but it would help to have a bit of guidance or a starting point.
Apart from this direct issue: Is it possible that WPA2 Enterprise is still quite flaky? I cannot get my board (ESP32 Wrover Kit v3) to run stable over more than an hour. Updated to master, finally running smooth :)
Kind regards,
grtschnk
Users browsing this forum: Bing [Bot], Qwantbot, Semrush [Bot] and 2 guests
