Any way to override MBEDTLS_PLATFORM_MEMORY define?
vonnieda
Re: Any way to override MBEDTLS_PLATFORM_MEMORY define?
Postby vonnieda » Mon Jul 30, 2018 5:16 pm
I don't have CONFIG_SPIRAM_ALLOW_STACK_EXTERNAL_MEMORY enabled, so unless I misunderstand, none of my stacks should be in SPI RAM. The help in menuconfig says:
" for this reason xTaskCreate and friends always allocate stack in internal memory and xTaskCreateStatic will check if the memory passed to it is in internal memory"
I don't use xTaskCreateStatic, I only use xTaskCreate, so to my understanding all my stacks should be in internal RAM.
You're entirely correct, I mis-remembered how task stack allocation works in my earlier post (have edited it).
I still think it would be worth setting SPIRAM_MALLOC_RESERVE_INTERNAL to the value to the size of all stacks, plus headroom for buffers, and seeing if the memory situation resolves itself.
I'll also take another look at the MBEDTLS_PLATFORM_MEMORY PR, ASAP.
Hi Angus,
Are you suggesting to set SPIRAM_MALLOC_RESERVE_INTERNAL to the total of stack tasks + wifi static and dynamic buffers + mbedtls buffers? If so, is 1.6k per wifi buffer correct? And 32k per active TLS connection?
Thanks,
Jason
vonnieda
Postby vonnieda » Mon Jul 30, 2018 5:54 pm
Went ahead and tried that, and the CPU won't boot:
I (605) cpu_start: Pro cpu up.
I (609) cpu_start: Single core mode
I (613) heap_init: Initializing. RAM available for dynamic allocation:
I (620) heap_init: At 3FFAFF10 len 000000F0 (0 KiB): DRAM
I (626) heap_init: At 3FFCEF20 len 000110E0 (68 KiB): DRAM
I (632) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (638) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (645) heap_init: At 40096DE8 len 00009218 (36 KiB): IRAM
I (651) cpu_start: Pro cpu start user code
I (656) spiram: Adding pool of 4096K of external SPI memory to heap allocator
I (664) spiram: Reserving pool of 118K of internal memory for DMA/internal allocations
E (672) cpu_start: Could not reserve internal/DMA pool!
abort() was called at PC 0x400811ae on core 0
0x400811ae: start_cpu0_default at /Users/jason/esp/esp-idf/components/esp32/./cpu_start.c:265 (discriminator 1)
Backtrace: 0x400902e4:0x3ffe3b90 0x4009040b:0x3ffe3bb0 0x400811ae:0x3ffe3bd0 0x400813c7:0x3ffe3c00 0x40078c6a:0x3ffe3c40 0x40078d1d:0x3ffe3c70 0x40078f8e:0x3ffe3cb0 0x400790d6:0x3ffe3e70 0x40007c31:0x3ffe3eb0 0x4000073d:0x3ffe3f20
0x400902e4: invoke_abort at /Users/jason/esp/esp-idf/components/esp32/./panic.c:572
0x4009040b: abort at /Users/jason/esp/esp-idf/components/esp32/./panic.c:572
0x400813c7: call_start_cpu0 at /Users/jason/esp/esp-idf/components/esp32/./cpu_start.c:203 (discriminator 1)
E (703) esp_core_dump: Core dump flash config is corrupted! CRC=0xffffffff instead of 0x0
Rebooting...
I suspect there is no single internal memory block big enough. I set the value to 120832. I calculated this as:
- 89k for stacks
- 6 + 6 static buffers + 6 dynamic buffers = 18 buffers * 1.6k = 28.8k
- total: ~118k * 1024 = 120832
I tried some other increasingly smaller numbers until I got down to 64k which did allow the chip to boot, but quickly resulted in the same wifi "null" error, as soon as I tried to connect the TLS. Here is what that looks like:
I (617) heap_init: Initializing. RAM available for dynamic allocation:
I (624) heap_init: At 3FFAFF10 len 000000F0 (0 KiB): DRAM
I (630) heap_init: At 3FFCEF20 len 000110E0 (68 KiB): DRAM
I (636) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (643) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (649) heap_init: At 40096DE4 len 0000921C (36 KiB): IRAM
I (655) cpu_start: Pro cpu start user code
I (660) spiram: Adding pool of 4096K of external SPI memory to heap allocator
I (668) spiram: Reserving pool of 64K of internal memory for DMA/internal allocations
I (23) cpu_start: Starting scheduler on PRO CPU.
I (950) wifi: wifi firmware version: de47fad
I (950) wifi: config NVS flash: disabled
I (950) wifi: config nano formating: disabled
I (950) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (960) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (970) wifi: Init dynamic tx buffer num: 32
I (970) wifi: Init data frame dynamic rx buffer num: 6
I (980) wifi: Init management frame dynamic rx buffer num: 6
I (990) wifi: Init static tx buffer num: 6
I (990) wifi: wifi driver task: 3ffe828c, prio:23, stack:3584
I (990) wifi: Init static rx buffer num: 6
I (1000) wifi: Init dynamic rx buffer num: 6
I (1000) wifi: wifi power manager task: 0x3ffeb67c prio: 21 stack: 2560
I (1040) phy: phy_version: 3662, 711a97c, May  9 2018, 14:29:06, 0, 0
I (1040) wifi: mode : sta (30:ae:a4:5f:99:24)
I (1040) wifi: sleep enable
I (1040) wifi: type: 1
S (1050)  xx_wifi.c:331  (0x0000) WiFi connecting to "xx".
I (1170) BTDM_INIT: BT controller compile version [44e9e66]
I (1170) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (1410)  xx_mqtt.c:212  (0x0000) WiFi not connected, waiting for it.
| 8BIT  | 32BIT | 32BIT - 8BIT | INTERNAL | SPIRAM |  DMA  | Heap Total | Used  | Free  | SOA Used | Free  |  HW   |
|1705480|1742848|         37368|     68220| 1674628|  30852|     4325684|2625416|1700268|         1|  32767|  32592|
I (2440) wifi: n:11 0, o:1 0, ap:255 255, sta:11 0, prof:1
I (3200) wifi: state: init -> auth (b0)
I (3210) wifi: state: auth -> assoc (0)
|1697548|1734916|         37368|     64852| 1670064|  27484|     4325684|2625416|1700268|         1|  32767|  32592|
I (3220) wifi: state: assoc -> run (10)
I (3230) wifi: connected with xxLabs5G, channel 11
S (3240)  xx_wifi.c:181  (0x0000) SYSTEM_EVENT_STA_CONNECTED ssid "xxLabs5G", bssid 80:2a:a8:03:0d:5b, channel 11, authmode WIFI_AUTH_WPA2_PSK.
|1701664|1739032|         37368|     64584| 1674448|  27216|     4325684|2625416|1700268|         1|  32767|  32592|
I (5150) event: sta ip: 192.168.10.141, mask: 255.255.255.0, gw: 192.168.10.1
S (5150)  xx_wifi.c:200  (0x0000) SYSTEM_EVENT_STA_GOT_IP IP 192.168.10.141, GW 192.168.10.1, Netmask 255.255.255.0.
I (5170)  xx_mqtt.c:115  (0x0000) Connecting to MQTT at xx.io:8883, use_tls = 1
|1689892|1727260|         37368|     55144| 1672116|  17776|     4325684|2625416|1700268|         1|  32767|  32592|
I (6220) wifi: pm start, type:1
|1603440|1640808|         37368|     42396| 1598412|   5028|     4325684|2625416|1700268|         1|  32767|  32592|
W (6460) wifi: alloc eb len=24 type=3 fail
W (6460) wifi: m f null
|1598952|1636320|         37368|     42352| 1593968|   4984|     4325684|2625416|1700268|         1|  32767|  32592|
|1583452|1620756|         37368|     42488| 1578060|   5120|     4325684|2625416|1700268|         1|  32767|  32592|
|1592304|1629672|         37368|     42504| 1587168|   5136|     4325684|2625416|1700268|         1|  32767|  32592|
|1590492|1627860|         37368|     42504| 1585356|   5136|     4325684|2625416|1700268|         1|  32767|  32592|
|1588616|1625984|         37368|     42448| 1583536|   5080|     4325684|2625416|1700268|         1|  32767|  32592|
|1589264|1626632|         37368|     42472| 1584160|   5104|     4325684|2625416|1700268|         1|  32767|  32592|
|1589344|1626712|         37368|     42472| 1584240|   5104|     4325684|2625416|1700268|         1|  32767|  32592|
E (15800) xx_MQTT_ESP32: mbedtls_ssl_handshake client: -0x7880 - SSL - The peer notified us that the connection is going to be closed
E (15810)  xx_mqtt.c:137  (0xffff8780) xx_mqtt_initialize: NetworkConnectTLS failed
E (15840)  xx_mqtt.c:223  (0xffff8780) MQTT connect failed
|1588696|1626064|         37368|     42448| 1583616|   5080|     4325684|2625416|1700268|         1|  32767|  32592|
|1589268|1626636|         37368|     42472| 1584164|   5104|     4325684|2625416|1700268|         1|  32767|  32592|
I (20840)  xx_mqtt.c:115  (0x0000) Connecting to MQTT at xx.io:8883, use_tls = 1
So, in this case, I had about 64k of internal, and 27k of DMA memory free. As soon as I attempted to open a TLS connection to my MQTT server it went down to 42k internal and 5k DMA and WiFi bombed with the "null" message.
So, I think the bottom line here is that unless I can get like 64k or more of DMA memory free, this won't work for me. Moving TLS into SPI solves the problem entirely, as far as I can tell, with very little performance hit.
Thanks,
Jason
Angus
Postby Angus » Mon Jul 30, 2018 11:58 pm
OK, thanks for trying this out. I think you're right that the heap is too fragmented for a single large block of this kind.
Will think about what we can do to solve this problem generically in the future, but the TLS-in-SPI solution does seem like the best one for now. Thanks again for bearing with me on this.
Angus
Postby Angus » Wed Aug 01, 2018 1:33 am
An update, the MBEDTLS_PLATFORM_MEMORY PR is queued for merging.
There is also a change in internal review for SPIRAM_MALLOC_RESERVE_INTERNAL, to allow this pool to be allocated from multiple non-contiguous regions if needed, to make up the complete size. It also increases the maximum reservation size to 256KB, and allocates the pool a little later in the boot process so that the startup stack region (which is not available as heap in early boot) can be used as well.
vonnieda
Postby vonnieda » Wed Aug 01, 2018 1:34 am
That's great news, thank you for your help!
Users browsing this forum: Bytespider, Google [Bot], PetalBot, Semrush [Bot] and 2 guests
