File upload using socket succeeds but not with esp_http_client
dima0905
Re: File upload using socket succeeds but not with esp_http_client
Postby dima0905 » Mon Jan 20, 2020 9:04 pm
Hi. I was trying to upload file but my server on clojure (ring.adapter.jetty) determines a error. I pointed on array with data in function esp_http_client_set_post_field(...)
eofeof
Postby eofeof » Tue Aug 18, 2020 8:44 am
Hi @amehta,
it would be perfect to see your solution as I am struggling to get it to work.
best regards and thanks in advance!!
eofeof
eofeof
Postby eofeof » Wed Aug 19, 2020 9:06 pm
yes I have completed the file upload function. Let me know if you need help.
I would be interested in you solution as well amehta.
Could you share it? Would be really nice!!
twinkle.goyal
Postby twinkle.goyal » Fri Jan 06, 2023 11:57 am
@ahmehta I am trying to do the exact same thing. Please let me know what fixed your error. Also, did you need to initialize a handler function for the esp_http_client object? I am new to esp32 so I am still learning.
Thanks in advance!
dmitrij999
Postby dmitrij999 » Tue Feb 21, 2023 11:25 am
Hello everyone!
I'm also trying to send large file from LittleFS to server using esp_http_client. Server responds the 400 error code, and "No file part". Server code works, tested with Postman
The code for sending using esp_http_client:
esp_err_t upload_file_to_server(string fname, string basename, int file_size) {
    ESP_LOGI(TAG, "Sending %s with size %d", basename.c_str(), file_size);
    esp_err_t err = ESP_OK;
    int status_code = 0;
    int content_length = 0;
	int total_read_len = 0, read_len = 0;
    int total_len_to_send = 0;
    char tmp_buf[256];
    char BODY[512];
    char END[128];
    memset(BODY, 0, sizeof(BODY));
    memset(END, 0, sizeof(END));
    memset(tmp_buf, 0, sizeof(tmp_buf));
    FILE * f = fopen(fname.c_str(), "rb");
    if (!f) {
        ESP_LOGE(TAG, "Cannot open file to upload!");
        return ESP_FAIL;
    uint8_t * send_buffer = (uint8_t*)malloc(MAX_HTTP_OUTPUT_BUFFER*sizeof(uint8_t));
    if (!send_buffer) {
        ESP_LOGE(TAG, "Cannot allocate mem for temp buffer!");
        err = ESP_ERR_NO_MEM;
        goto file_upload_buffer_allocate_failed;
    bzero(send_buffer, MAX_HTTP_OUTPUT_BUFFER);
    esp_http_client_set_method(wav_sender_client, HTTP_METHOD_POST);
    sprintf(tmp_buf, "multipart/form-data; boundary=%s", WAV_FILE_BOUNDARY);
    esp_http_client_set_header(wav_sender_client, "Content-Type", tmp_buf);
    sprintf(tmp_buf, "%d", file_size);
    esp_http_client_set_header(wav_sender_client, "Content-Length", tmp_buf);
    // memset(tmp_buf, 0, sizeof(tmp_buf));
    // sprintf(tmp_buf, "attachment; name=\"file\"; filename=\"%s\"", basename.c_str());
    // esp_http_client_set_header(wav_sender_client, "Content-Disposition", tmp_buf);
    esp_http_client_set_header(wav_sender_client, "Accept", "*/*");
    sprintf(tmp_buf, "--%s\r\n", WAV_FILE_BOUNDARY);
    strcpy(BODY, tmp_buf);
    sprintf(tmp_buf, "Content-Disposition: form-data; name=\"file\"; filename=\"%s\"\r\n", basename.c_str());
    strcat(BODY, tmp_buf);
    sprintf(tmp_buf, "Content-Type: application/octet-stream\r\n\r\n");
    sprintf(tmp_buf, "\r\n%s--\r\n\r\n", WAV_FILE_BOUNDARY);
    strcpy(END, tmp_buf);
    total_len_to_send = file_size+strlen(BODY)+strlen(END);
    sprintf(tmp_buf, "%d", total_len_to_send);
    printf("%s", BODY);
    printf("%s", END);
    if ((err = esp_http_client_open(wav_sender_client, total_len_to_send)) != ESP_OK) {
		ESP_LOGE(TAG, "Failed to open HTTP connection: %s", esp_err_to_name(err));
		goto file_upload_connection_failed;
    ESP_LOGI(TAG, "Connection opened");
    // vTaskDelay(pdMS_TO_TICKS(100));
    if (esp_http_client_write(wav_sender_client, BODY, sizeof(BODY)) == ESP_FAIL) {
        ESP_LOGE(TAG, "Cannot send BODY preamble");
        goto file_upload_connection_end;
    while (fread(&send_buffer[0], sizeof(uint8_t), MAX_HTTP_OUTPUT_BUFFER, f) > 0) {
		int snt = esp_http_client_write(wav_sender_client, (char*)send_buffer, MAX_HTTP_OUTPUT_BUFFER);
        if (snt == ESP_FAIL) {
            ESP_LOGE(TAG, "Cannot send part");
    if (esp_http_client_write(wav_sender_client, END, sizeof(END)) == ESP_FAIL) {
        ESP_LOGE(TAG, "Cannot send END preamble");
    content_length =  esp_http_client_fetch_headers(wav_sender_client);
	total_read_len = 0;
    if (total_read_len < content_length && content_length <= MAX_HTTP_OUTPUT_BUFFER) {
		read_len = esp_http_client_read(wav_sender_client, (char*)send_buffer, content_length);
		if (read_len <= 0) {
			ESP_LOGE(TAG, "Error read data");
            err = ESP_FAIL;
		send_buffer[read_len] = 0;
		ESP_LOGI(TAG, "read_len = %d", read_len);
    status_code = esp_http_client_get_status_code(wav_sender_client);
	ESP_LOGI(TAG, "HTTP Status = %d, content_length = %d",
	                    status_code,
	                    esp_http_client_get_content_length(wav_sender_client));
    if (status_code >= 400) {
        ESP_LOGE(TAG, "Error sending file!");
        err = ESP_FAIL;
file_upload_connection_end:
    esp_http_client_close(wav_sender_client);
    ESP_LOGI(TAG, "Connection closed");
file_upload_connection_failed:
    esp_http_client_delete_header(wav_sender_client, "Content-Type");
    esp_http_client_delete_header(wav_sender_client, "Content-Length");
    esp_http_client_delete_header(wav_sender_client, "Content-Disposition");
    esp_http_client_delete_header(wav_sender_client, "Accept");
    free(send_buffer);
file_upload_buffer_allocate_failed:
    fclose(f);
    return err;
The server code:
@app.route('/upload-record', methods=['POST'])
def upload_record():
    # check if the post request has the file part
    if 'file' not in request.files:
        print("No file part")
        return make_response('No file part', 400)
    file = request.files['file']
    # if user does not select file, browser also
    # submit an empty part without filename
    if file.filename == '':
        print("No selected file")
        return make_response('No selected file', 400)
    if file and allowed_file(file.filename):
        filename = secure_filename(file.filename)
        file.save(os.path.join(app.config['UPLOAD_FOLDER'], filename))
        return "Record uploaded!"
    else:
        return make_response('Wrong file or its format', 400)
