Socket connect fails with ERRNO 113 with http client
Ritesh
Contact:
Re: Socket connect fails with ERRNO 113 with http client
Postby Ritesh » Wed Oct 24, 2018 3:57 am
The other thing you can try, which is strongly recommended, is to checkout the "release/v2.1" branch (currently at commit c70a613127). Compared to updating to v3.x, this shouldn't require any code changes, but there are a number of fixes in that branch including fixes for problems writing to SPI flash.
(For an explanation of what a release branch represents, see here in the master branch docs).
Thanks a lot for your suggestions regarding same.
@Rahul,
Would you please provide update of regression test with that release branch so that we can have idea to apply those changes into our existing IDF?
Regards,
Ritesh Prajapati
rahul.b.patel
Postby rahul.b.patel » Wed Oct 24, 2018 4:12 am
Hello Angus,
I have tested the scenario with "release/v2.1" branch with almost more then 65 times and got failure of 4-5 times. Its way better then with IDFv2.1 Tag firmware which is reproducing the issue in almost each time. Still I will also try the same with IDFv3.1 and will get back you.
Let me know if you have any other suggestions for the same.
thanks.
Users browsing this forum: meta-externalagent, PetalBot and 7 guests
