Re: BLE Server and Client coexisting
Posted: Thu Dec 20, 2018 5:05 am
The same crash again with another dump....
==================== ESP32 CORE DUMP START ====================
================== CURRENT THREAD REGISTERS ===================
pc 0x40084835 0x40084835 <r_assert_param+309>
lbeg 0x4008476d 1074284397
lend 0x40084774 1074284404
lcount 0x0 0
sar 0x4 4
ps 0x60124 393508
threadptr <unavailable>
br <unavailable>
scompare1 <unavailable>
acclo <unavailable>
acchi <unavailable>
m0 <unavailable>
m1 <unavailable>
m2 <unavailable>
m3 <unavailable>
expstate <unavailable>
f64r_lo <unavailable>
f64r_hi <unavailable>
f64s <unavailable>
fcr <unavailable>
fsr <unavailable>
a0 0x40046350 1074029392
a1 0x3ffe12c0 1073615552
a2 0x1 1
a3 0x0 0
a4 0x0 0
a5 0x60008054 1610645588
a6 0x3ffbdcd0 1073470672
a7 0x60008050 1610645584
a8 0x80084835 -2146940875
a9 0x3ffe12a0 1073615520
a10 0x4 4
a11 0x0 0
a12 0x6000804c 1610645580
a13 0xffffffff -1
a14 0x0 0
a15 0xfffffffc -4
==================== CURRENT THREAD STACK =====================
#0 0x40084835 in r_assert_param ()
Backtrace stopped: Cannot access memory at address 0x40046350
======================== THREADS INFO =========================
Id Target Id Frame
30 process 29 0x40093761 in xQueueGenericReceive (xQueue=0x3ffb79f8, pvBuffer=0x0, xTicksToWait=4294967295, xJustPeeking=0) at C:/msys32/home/EthanA/esp-idf-master/components/freertos/queue.c:1591
29 process 28 0x40093761 in xQueueGenericReceive (xQueue=0x3ffd1240, pvBuffer=0x3ffd2670, xTicksToWait=42949 67295, xJustPeeking=0) at C:/msys32/home/EthanA/esp-idf-master/components/freertos/queue.c:1591
28 process 27 0x40093761 in xQueueGenericReceive (xQueue=0x3ffaff64, pvBuffer=0x0, xTicksToWait=4294967295, xJustPeeking=0) at C:/msys32/home/EthanA/esp-idf-master/components/freertos/queue.c:1591
27 process 26 0x40093761 in xQueueGenericReceive (xQueue=0x3ffb9a3c, pvBuffer=0x0, xTicksToWait=4294967295, xJustPeeking=0) at C:/msys32/home/EthanA/esp-idf-master/components/freertos/queue.c:1591
26 process 25 0x40093761 in xQueueGenericReceive (xQueue=0x3ffd00e8, pvBuffer=0x3ffd1160, xTicksToWait=42949 67295, xJustPeeking=0) at C:/msys32/home/EthanA/esp-idf-master/components/freertos/queue.c:1591
25 process 24 0x40093f30 in prvProcessTimerOrBlockTask (xNextExpireTime=<optimized out>, xListWasEmpty=<opti mized out>) at C:/msys32/home/EthanA/esp-idf-master/components/freertos/timers.c:588
24 process 23 0x4009218e in vTaskDelay (xTicksToDelay=<optimized out>) at C:/msys32/home/EthanA/esp-idf-mast er/components/freertos/tasks.c:1484
23 process 22 0x4009218e in vTaskDelay (xTicksToDelay=<optimized out>) at C:/msys32/home/EthanA/esp-idf-mast er/components/freertos/tasks.c:1484
22 process 21 0x4009218e in vTaskDelay (xTicksToDelay=<optimized out>) at C:/msys32/home/EthanA/esp-idf-mast er/components/freertos/tasks.c:1484
21 process 20 0x4009218e in vTaskDelay (xTicksToDelay=<optimized out>) at C:/msys32/home/EthanA/esp-idf-mast er/components/freertos/tasks.c:1484
20 process 19 0x4009218e in vTaskDelay (xTicksToDelay=<optimized out>) at C:/msys32/home/EthanA/esp-idf-mast er/components/freertos/tasks.c:1484
19 process 18 0x4009218e in vTaskDelay (xTicksToDelay=<optimized out>) at C:/msys32/home/EthanA/esp-idf-mast er/components/freertos/tasks.c:1484
18 process 17 0x4009218e in vTaskDelay (xTicksToDelay=<optimized out>) at C:/msys32/home/EthanA/esp-idf-mast er/components/freertos/tasks.c:1484
17 process 16 0x4009218e in vTaskDelay (xTicksToDelay=<optimized out>) at C:/msys32/home/EthanA/esp-idf-mast er/components/freertos/tasks.c:1484
16 process 15 0x4009218e in vTaskDelay (xTicksToDelay=<optimized out>) at C:/msys32/home/EthanA/esp-idf-mast er/components/freertos/tasks.c:1484
15 process 14 0x4009218e in vTaskDelay (xTicksToDelay=<optimized out>) at C:/msys32/home/EthanA/esp-idf-mast er/components/freertos/tasks.c:1484
14 process 13 0x4009218e in vTaskDelay (xTicksToDelay=<optimized out>) at C:/msys32/home/EthanA/esp-idf-mast er/components/freertos/tasks.c:1484
13 process 12 0x40082368 in esp_crosscore_int_send (core_id=<optimized out>, reason_mask=<optimized out>) at C:/msys32/home/EthanA/esp-idf-master/components/esp32/crosscore_int.c:104
12 process 11 0x40093761 in xQueueGenericReceive (xQueue=0x3ffbd5f0, pvBuffer=0x3ffd0030, xTicksToWait=11, x JustPeeking=0) at C:/msys32/home/EthanA/esp-idf-master/components/freertos/queue.c:1591
11 process 10 0x4009218e in vTaskDelay (xTicksToDelay=<optimized out>) at C:/msys32/home/EthanA/esp-idf-mast er/components/freertos/tasks.c:1484
10 process 9 0x4009218e in vTaskDelay (xTicksToDelay=<optimized out>) at C:/msys32/home/EthanA/esp-idf-mast er/components/freertos/tasks.c:1484
9 process 8 0x4009218e in vTaskDelay (xTicksToDelay=<optimized out>) at C:/msys32/home/EthanA/esp-idf-mast er/components/freertos/tasks.c:1484
8 process 7 0x4009218e in vTaskDelay (xTicksToDelay=<optimized out>) at C:/msys32/home/EthanA/esp-idf-mast er/components/freertos/tasks.c:1484
7 process 6 0x400d331b in esp_vApplicationIdleHook () at C:/msys32/home/EthanA/esp-idf-master/components/e sp32/freertos_hooks.c:51
6 process 5 0x4019f1e6 in esp_pm_impl_waiti () at C:/msys32/home/EthanA/esp-idf-master/components/esp32/pm _esp32.c:487
5 process 4 0x4000bff0 in ?? ()
4 process 3 0x4000bff0 in ?? ()
3 process 2 0x40093761 in xQueueGenericReceive (xQueue=0x3ffdff8c, pvBuffer=0x3ffe8e00, xTicksToWait=42949 67295, xJustPeeking=0) at C:/msys32/home/EthanA/esp-idf-master/components/freertos/queue.c:1591
2 process 1 cause_sw_intr_to_core_wrapper (core_id=0, intr_no=7) at C:/msys32/home/EthanA/esp-idf-master/c omponents/bt/bt.c:698
* 1 <main task> 0x40084835 in r_assert_param ()
======================= ALL MEMORY REGIONS ========================
Name Address Size Attrs
.rtc.text 0x400c0000 0x0 RW
.rtc.dummy 0x3ff80000 0x0 RW
.rtc.force_fast 0x3ff80000 0x0 RW
.rtc_noinit 0x50000000 0x0 RW
.rtc.force_slow 0x50000000 0x0 RW
.iram0.vectors 0x40080000 0x400 R XA
.iram0.text 0x40080400 0x17b74 RWXA
.dram0.data 0x3ffbdb60 0x3b0c RW A
.noinit 0x3ffc166c 0x0 RW
.flash.rodata 0x3f400020 0x27cfc RW A
.flash.text 0x400d0018 0xd2328 R XA
.coredump.tasks.data 0x3ffb5770 0x164 RW
.coredump.tasks.data 0x3ffe1200 0x258 RW
.coredump.tasks.data 0x3ffb5fb4 0x164 RW
.coredump.tasks.data 0x3ffe35c0 0x2a0 RW
.coredump.tasks.data 0x3ffe3868 0x164 RW
.coredump.tasks.data 0x3ffe8d00 0x1bc RW
.coredump.tasks.data 0x3ffe3cd0 0x164 RW
.coredump.tasks.data 0x3ffea120 0x314 RW
.coredump.tasks.data 0x3ffb5b60 0x164 RW
.coredump.tasks.data 0x3ffe2bb0 0x2ac RW
.coredump.tasks.data 0x3ffbc4a0 0x164 RW
.coredump.tasks.data 0x3ffbc2f0 0x1a8 RW
.coredump.tasks.data 0x3ffbbd34 0x164 RW
.coredump.tasks.data 0x3ffbbba0 0x18c RW
.coredump.tasks.data 0x3ffef3f4 0x164 RW
.coredump.tasks.data 0x3ffef260 0x18c RW
.coredump.tasks.data 0x3ffecf84 0x164 RW
.coredump.tasks.data 0x3ffecdc0 0x1bc RW
.coredump.tasks.data 0x3ffd75a4 0x164 RW
.coredump.tasks.data 0x3ffd8cd0 0xb30 RW
.coredump.tasks.data 0x3ffdf680 0x164 RW
.coredump.tasks.data 0x3ffdf4f0 0x188 RW
.coredump.tasks.data 0x3ffbd6c4 0x164 RW
.coredump.tasks.data 0x3ffcfee0 0x200 RW
.coredump.tasks.data 0x3ffee41c 0x164 RW
.coredump.tasks.data 0x3ffee230 0x1e4 RW
.coredump.tasks.data 0x3fff1338 0x164 RW
.coredump.tasks.data 0x3fff11b0 0x180 RW
.coredump.tasks.data 0x3ffeee88 0x164 RW
.coredump.tasks.data 0x3ffeecf0 0x190 RW
.coredump.tasks.data 0x3ffeb050 0x164 RW
.coredump.tasks.data 0x3ffec1e0 0x184 RW
.coredump.tasks.data 0x3fff1da4 0x164 RW
.coredump.tasks.data 0x3fff1c10 0x18c RW
.coredump.tasks.data 0x3ffed8f0 0x164 RW
.coredump.tasks.data 0x3ffed760 0x188 RW
.coredump.tasks.data 0x3fff327c 0x164 RW
.coredump.tasks.data 0x3fff30f0 0x184 RW
.coredump.tasks.data 0x3fff55b4 0x164 RW
.coredump.tasks.data 0x3fff5410 0x19c RW
.coredump.tasks.data 0x3fff08cc 0x164 RW
.coredump.tasks.data 0x3fff0720 0x1a4 RW
.coredump.tasks.data 0x3ffefe60 0x164 RW
.coredump.tasks.data 0x3ffefcb0 0x1a8 RW
.coredump.tasks.data 0x3fff2810 0x164 RW
.coredump.tasks.data 0x3fff2660 0x1a8 RW
.coredump.tasks.data 0x3fff3be8 0x164 RW
.coredump.tasks.data 0x3fff3a60 0x180 RW
.coredump.tasks.data 0x3ffbcf00 0x164 RW
.coredump.tasks.data 0x3ffbcd50 0x1a8 RW
.coredump.tasks.data 0x3ffbd8f8 0x164 RW
.coredump.tasks.data 0x3ffd1060 0x1d8 RW
.coredump.tasks.data 0x3ffb9e94 0x164 RW
.coredump.tasks.data 0x3ffb9ce0 0x1ac RW
.coredump.tasks.data 0x3ffb7730 0x164 RW
.coredump.tasks.data 0x3ffb7580 0x1a8 RW
.coredump.tasks.data 0x3ffd272c 0x164 RW
.coredump.tasks.data 0x3ffd2540 0x1e4 RW
.coredump.tasks.data 0x3ffb7e50 0x164 RW
.coredump.tasks.data 0x3ffb7ca0 0x1a8 RW
===================== ESP32 CORE DUMP END =====================
